Teeth Sharpness Measurement - Broaching into a flat aluminum piece
Q
QCAce
I need to find a method/equipment (preferably something small enough I could take with me in a case), that will measure the sharpness of teeth we are broaching into a flat aluminum piece. The teeth will only be about .060" tall and .060" spaced apart.
Anyone know of equipment I could look for to do this?
How would you measure sharpness?
Re: Teeth Sharpness Measurement
How is the sharpness specified?
Wes Bucey
I would imagine teeth (like saw blades and knurls) might be measured by angles. If the blade is chisel shape - just the chamfer. Use a hand held optical comparator/magnifier to check for burrs and have a reticle with the desired angle etched in to check for the proper angle of the cutting edge or points of the teeth.
Edmund is a good beginning search for such optics
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1428&search=1
Q
QCAce
There is no sharpness specified on the drawing, yet. I don't believe engineering knows exactly how they want to specify it just yet. They are looking to me to provide a variable measurement, and they know they want the teeth as sharp as possible at this point.
These straps are up a against a rotating, painted, alum-diecast housing. Once the housing is rotated to the proper angle, bolts tighten the straps against the housing. They want the teeth to dig into the paint and provide holding force to keep the housing at its desired angle.
Saw teeth, looking at the strap from the side is a good way to describe what the teeth look like. I don't have a comparitor with enough magnification to get a large enough view of the teeth. I have a microscope on order but it has a long lead time, and I'm trying to see if there is an alternate method.
My initial thoughts to measure sharpness would be to intersect the two lines off of each side of the tooth to find a theoretical peak. Then measure from the theoretical peck down to the top of the tooth. The shorter the distance, the sharper the tooth.
I have no feel for the size of the thing you're talking about, but it seems like a loupe/reticle such as Wes described might be useful. There might be a problem measuring angles though, because of the difficulty in establishing the reference plane.
Tim Folkerts
Here's just a few stray thoughts....
Make a set of set of "chisels" that have varying angles on the tip. The points that are either too sharp or too blunt will be loose in the teeth, but the best fit should be fairly snug. Granted the teeth are only 1/16" deep, but you should be able to tell by feel which fits best.
Since you are interested in how well the teeth dig in, you could measure that directly. Make a little jig where you can press the part with the teeth down onto a blank chunk of aluminum. Measure, for example, the force (or torque on a bolt) required to press the teeth 0.020 into the blank.
Tim F
I'd be more than a little worried that teeth biting into paint on a housing was being used to secure something:mg: It would be better from a purely engineering standpoint to bear into the unfinished casting and then paint over (if needed for protection).;)
Andy, I'd be going back to the engineers who dreamed this one up and getting them to change the spec., not trying to find an elegant solution to measuring teeth sharpness;)
Andy
Q
QCAce
Andy
The paint is needed for protection. But it would be an interesting study to measure the holding force on a part that had the strap area masked off.
Thanks,
R Class 1 Convenience kits for home teeth impression, NOT smile direct or other for alignment purposes Canada Medical Device Regulations 0
P How to Measure Gear Teeth and Pinions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
Y Using PC-DMIS to measure True Position of the teeth of a Spline Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Ring Gauges P.D Formula using "Ball Rounded Teeth" General Measurement Device and Calibration Topics 13
H Porosity in Aluminum Bronze Cast Gear Teeth Manufacturing and Related Processes 2
P Are artificial teeth medical devices? If so, which class do they belong to? ISO 13485:2016 - Medical Device Quality Management Systems 3
T How to put some teeth into a Non-Conformance Program Nonconformance and Corrective Action 17
S Are Teeth Important in Making Good First Impressions? Coffee Break and Water Cooler Discussions 31
V Implementing ISO 9001 in a customised product environment - We make artificial teeth ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C Teeth for AS9100 - Third party registration requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F Physical Part Measurement General Measurement Device and Calibration Topics 4
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
Ron Rompen Measurement of residual magnetism General Measurement Device and Calibration Topics 2
M Surgical angle measurement guide device with an application software Medical Device and FDA Regulations and Standards News 1
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Most versatile measurement device General Measurement Device and Calibration Topics 2
P Surface scratch measurement General Measurement Device and Calibration Topics 1
P Thermo-Hygrometer - Measurement of 10DegC @10%RH ISO 17025 related Discussions 4
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
T How to “validate/qualify” a new measurement equipment? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Bev D Verification and Validation of Measurement Systems Misc. Quality Assurance and Business Systems Related Topics 0
F How do you add accuracies for tools with different measurement devices? General Measurement Device and Calibration Topics 1
M Viable count Measurement ISO Standard Other Medical Device Related Standards 1
W Air Quality Measurement Hardware and Software General Measurement Device and Calibration Topics 11
O Dimension Measurement Tool Recommendation General Measurement Device and Calibration Topics 21
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
R Measurement Uncertainties Budget for Thermometer Measurement Uncertainty (MU) 6
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
G What information to put on measurement Dimensional Results APQP and PPAP 7
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
F Electrical Metrology (Source/Generation and Measurement) General Measurement Device and Calibration Topics 1
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
