In our hospital, a clinician has developed a software described as telemedicine.
It is intended for patients from the hospital to interact with the software when they have any kind of symptoms. Once the patient idenfies the symptoms and opens the software, it directly opens up a questionnaire that addresses those symptoms until they are almost completely described, and then a chat is popped-up allowing the comunication with the clinician (which has received the result from the questionnaire).
The clinician could diagnose or indicate a treatment to alleviate the symptoms through that chat.
In this case the software could be used to communicate symptoms, diagnostic or treatment. In this case, would the software be considered as a medical device?
If the chat is only open to tell the patient: give us your phone number and we will call you, then the software would be also considered medical device?
Should risks as cybersecurity attacks be a reason to consider the software as medical device?
Should risks as missdiagnostic that leads to further invasive or burdensome tests be a reason to consider the software as a medical device?
Thanks in advance
Thanks in advance
