Template for Vendor (Supplier) Qualification
chimie
#11
Re: Template for Vendor (Supplier) Qualification needed
Thank you but still looking for a simple procedure for the drug industry. Can I get away with a documentation audit and not have to visit the facility? Thanks!
v9991
#12
the minimum you could have is a documentation audit (self assessment questionnaire which outlines your interpretation of minimum GMP requirements...and once filled/completed, outlines the supplier's confirmation/commitment about fulfilling the pertinent requirements) this also helps you ensure that you verify/ensure certain standards are met...
this is then supplemented by technical/GMP agreement, which categorically signs-off the accountbilities of meeting respective activities...
above two procedural requirements, are supplemented/supported by the assessment of criticality of material to your product. (product/process assessment...)
here;s few quick references...
http :// apic. cefic. org/pub/guideline supplier qualification_dec09final .pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED
http :// www .tga.gov.au/pdf/manuf-twg-cm-supplier-qualification.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED
http://www.pharmtech.com/pharmtech/article/articleDetail.jsp?id=632990
http :// www .gmp-publishing.com/media/files/leseproben/Extract-18.H-Questionnaire-for-preparing-GMP-inspections.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED
http://www.who.int/3by5/en/who-edm-par-99-5.pdf
off late the VQ has been a key focus are in the regulatory audits...
Chance
#13
If the company fails to develop a supplier re-evaluation program then what is a true root cause that you can think of.
Perhaps you will dig deeper and find out why. We don't know what happened.
1. Is this requirement new to your orgnization? If yes, that is why there is no supplier qualificaiton, re-evaluation that exist. State that the organization is working on establishing it from now onwards.
2. If this is not a new requirement, we can't tell you why your organization failed to develop one. Perhaps, it was on the list but in the lower priority?
3. If this is not a new requirement, perhaps no one detected it before.
4. A weakness in the system but the organization is working on establishing it.:agree:
chimie
#14
v991,
Could you please elaborate a little bit more on the last two requirements or if you have a sample, that would be great. Also, do suppliers that are ISO certified need to be qualified?
Thanks!
v9991
#15
v991,
Thanks!
1) i guess you are asking about the product & process assessment...
*) (if required on multiple batches to show the consistency) assessment of an independent(inhouse qC) analysis and comparison of results against supplier provided COA
*) if material is critical, then usage of material in the product (a finished product ) and performance of the FP (both COA and if required stability)
2) sample template...can found online(even within elsmar) ...yet need to be customized to your specific defined procedure of your organization...
3) irrespective of accreditation or the even the regulatory audits, regulators expects you to operate within the purview of your own quality systems.... i.e., you must 'justify' the decision/procedure of not qualifying the suppliers with an accreditation. (or doing through alternative steps...viz., atleast postal audits, doing an assessment on complaints, regulatory observations etc)
hope that it helps...
chimie
#16
Thank you v9991. For a thorough documentation audit, I am requesting a survey to be filled out and the following items to be sent:
Certificate of ISO
QA manual
Industry references
Product samples with CofAs
What else am I missing for a thorough documentation audit? Thanks!
Also, in what instances would it be deemed necessary to do an on-site audit after completing a documentation audit?
v9991
#17
you can keep growing those general things..
apart from them, you questionnaire should actually allow user to confirm/commit the availability of suitable systems required to deliver a consistent product...(these can essentially evolve from your expectations of supplier's quality systems...)
just in case if you have not already seen these...
here's few quick references from net... http://www.gmpsop.com/forms/Form-385_Vendor_Audit_Questionnaire.pdf
http :// www. mageeplastics.com/airlines/pdf/QA-001%20Rev%20F%20Mail%20Audit.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED
http :// www .elbitsystems-us. com/sites/default/files/imported/corporate/suppliers/doc/CC-09-03%20Rev%20new%20-%20Supplier%20Quality%20System%20Audit%20Checklist%20_4_.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED
GMP Audit Checklist for GMP
also have a look at pg.1 of this very post....
hope this helps...
chimie
#18
v991,
Thank you. Would you happen to have the appendices that go along with this document? Thanks!
chimie
#19
Found the appendices. For ongoing monitoring, if we plan to do a quarterly and an annual assessment where the annual includes a full assessment of supplier performance, what should be included in a quarterly assessment at the minimum? I am trying to distinguish between the two assessments and trying to make quarterly assessments as brief as possible. Thanks!
K
kgott
#20
If I may, I would like to challenge your line of thought regarding the need for procedure(s). In accordance with ISO 13485:2003 clause 7.4.1 'the organization shall establish documented procedures to ensure that purchased product conforms to specified purchase requirements". Nowhere in the standard is there a requirement for a documented procedure for suppllier selection, so I am challenging the need for one within your organization.
The standard goes on to say "the organization shall evaluate and select suppliers based on their ability to supply product in accordance with the organization's requirements. Criteria for selection, evaluation and re-evaluation shall be established." .
I agree and I will add that it does not need to be complicated either.
In a previous role the safety department would send out multiple pages of questionnaires to all suppliers on the basis that they were 'qualifying them.' I opposed it vigorously. I took the view that we fulfilled the requirements of 7.4.1 just by saying that suppliers were approved using any criteria management deemed suitable (including the requirements of 7.4.1) and that they remained approved until they were unapproved.
In other words, until management decided to discontinue using a particular supplier, all suppliers remained approved and could continue to supply the company.
While we maintained a list of suppliers and their contacts and the services they provided, it was for ease of reference only.
N Vendor (Supplier) Notification template Document Control Systems, Procedures, Forms and Templates 7
F Vendor (Supplier) Survey template needed Supplier Quality Assurance and other Supplier Issues 5
A Can anyone share a Distribution Agreement template under MDR 2017/745? EU Medical Device Regulations 0
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
bryan willemot Looking for an Approved vendors list template Document Control Systems, Procedures, Forms and Templates 11
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
CharlieUK Informational ADCO MED EU DECLARATION OF CONFORMITY TEMPLATE CE Marking (Conformité Européene) / CB Scheme 0
Tagin Template or Checklist for Process Change Document Control Systems, Procedures, Forms and Templates 5
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
F MDR GSPR Checklist template EU Medical Device Regulations 7
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
C Ford's MMOG/le Template wanted Manufacturing and Related Processes 0
C SOP Template needed for ISO 13485 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 9
Q Example of the Risk Template Document Control Systems, Procedures, Forms and Templates 1
C Template for Excel Validation Reliability Analysis - Predictions, Testing and Standards 6
dgrainger Informational MDCG 2020:13 - Clinical evaluation assessment report template EU Medical Device Regulations 0
Q Internal audit plan template Internal Auditing 12
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
M Supplier Audit Report - Template for second party audit wanted Lean in Manufacturing and Service Industries 1
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 0
J Level 3 KPI Excel Template Manufacturing and Related Processes 1
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Informational EU – Manufacturer incident report (MIR) for serious incident- template 2020 (Directives and new regulations) version 7.2 and related documents Medical Device and FDA Regulations and Standards News 2
pashah Looking for Usability File Template acc. IEC 62366-1 and IEC 60601-1-6 IEC 62366 - Medical Device Usability Engineering 4
M PMS template for FDA submission (De novo submission for a Class II IVD) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Medical device Validation/Verification template ISO 13485:2016 - Medical Device Quality Management Systems 1
CPhelan Labeling template on QMS - Kitting and labeling documentation Manufacturing and Related Processes 9
M Post Market Surveillance Plan Template EU Medical Device Regulations 10
M PMCF (Post Market Clinical Followup)/ PSUR template EU Medical Device Regulations 8
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
Ashok sunder Need ISO 45001:2018 HIRA template Occupational Health & Safety Management Standards 9
optomist1 Share a DFMEA template please Document Control Systems, Procedures, Forms and Templates 2
P Looking for Risk Assessment Template - Not necessarily Asset based IEC 27001 - Information Security Management Systems (ISMS) 1
A Australia TGA Medical Device Sponsor Agreement - Example or Template Other Medical Device Regulations World-Wide 18
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
Ashok sunder ISO 45001:2018 Documentation template Occupational Health & Safety Management Standards 4
E Template of a Management Review Agenda or Report in compliance with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
