Terminating an Internal Audit - Area totally out of control
Bob Bonville
I recently entered an assembly area where I immediately discovered the area to be totally out of control. Obvious, glaring findings were virtually everywhere. This particular area was given a one week advance notice of my planned audit.
After spending only 15 minutes, I decided to terminate the audit. I notified the area supervor & manager and my director of my action. At the outbrief I told the functional leaders that I would return in 1 week, and would complete my audit.
Question: Have any of you experienced this type of situation and what would you have done under similar circumstances?
Thank you
Bob
P
Phil Fields
Re: Terminating an Internal Audit
Bob,
Fortunately I have not experienced this type of situation. By stopping the audit, with the plan of returning in one week, do you expect much will change?
Looking at it from the outside, it may have been better to continue longer, collect the objective evidence, and then write up the nonconformances.
Phil
D.Scott
Thank you
Bob
Hard to know if any of my audits were as bad as the one you had but I think you were justified in what you did. I trust you documented everything you found during the audit. Those findings should be communicated to upper management the same as any other findings.
When you go back to "finish up", be careful you don't carry an attitude. Be objective and try not to nit-pick. Look carefully at your findings. Try to group what can be grouped rather than writing up everything separately. Piling on won't help in this situation. Management needs to know the situation but it won't help to beat a dead horse. Audit fairly, document and report the facts. It is probably obvious there is a deeper problem in that area that management will want to investigate. Be sure they have good objective evidence to work with.
Good luck,
Dave
Thank you
Bob
I think it would be good to turn the subjective "totally out of control" into objective evidence, meaning I probably would have proceeded and documented what I found. You might have come out of it with a fairly prodigious list of findings, but the list would be helpful in prioritizing improvements.
Coury Ferguson
Moderator here to help
Thank you
Bob
Why terminate the Audit? You are identifying issues that could affect the output of the product (assuming it was process/product related), and you wanted to stop the Audit? :confused: :nope:
I would have not stopped the audit, but that is just me.
Ajit Basrur
I agree with Coury - since its an Internal Audit, I shall try to find all NCs and summarize in a report and shall have an additional surprise audit at a later date.
Just my :2cents:
I have seen similar situations, but have not yet terminated an audit for that reason (I have done so when I was quite unable to get hold of any key staff despite prior agreements, though). However, sometimes 15 minutes can be quite enough to decide that a process is out of control, complete with objective evidence and all.
To continue racking up findings in that situation may do more harm than good, as Dave noted. It will simply be overkill.
SteelMaiden
If you should choose to continue the audit, you may want to think about paring down the scope. If you overwhelm your auditees with trying to audit every portion of every process they may may be involved with, you might just get them into a hole they cannot dig out of. You can always go back several times to audit to a narrower scope, giving them time to fix a portion at a time. If you overwhelm them you face the risk of them being resentful for a very long time, where if you take small chunks and give them time to assimilate the "culture" they will probably be able to see the value instead of the proverbial "cannot see the forest for the trees."
Bob Bonville
A little more background for the curious.
The particular audit area was supervised by people who were well aware of the requirements and had let the place go since the last audit 3 months prior. They had totally disregarded my "notice of audit" by not policing their area and performing some preparation. My rational for terminating the audit was that I wasn't going to waste my already taxed audit resources to document this mess when these people knew better. By the way, I have never performed a suprise or unannounced audit. I don't feel it should be necessary.
Coury Ferguson
That is still not a reason to terminate an Internal Audit.
C Consequences of terminating a subcontractor re continuity of supply CE Marking (Conformité Européene) / CB Scheme 0
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
M ISO13485:2016, MDSAP and Internal Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
S Would this be a second site for the purposes of internal and third party audits? General Auditing Discussions 4
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
J ISMS - Internal Audits Internal Auditing 3
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
D CB and customer audits considered as internal audits? General Auditing Discussions 9
E MDR internal audit Internal Auditing 1
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
F Internal transfer of work from one line to another? Qualification and Validation (including 21 CFR Part 11) 3
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
M Major vs. Minor for Internal Audits? Internal Auditing 10
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
C Internal Audits in a tiny Dx Company Internal Auditing 33
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
A QMS Overhaul - Reorganizing and Renaming Documents - Internal References Document Control Systems, Procedures, Forms and Templates 24
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
S Risk based internal auditing Internal Auditing 6
O Informational Scaling back internal audits due to corona virus while avoiding a NC Internal Auditing 7
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Software for Supplier Charge back and internal PPM General Information Resources 2
G Internal Audits and Employee engagement Internal Auditing 16
I What direction do you provide your internal auditors on OFIs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
