Test failure Root cause not found
#11
It's not a bad thing to tell a customer that you've exhausted all of the possibilities and are unable to duplicate the failure. The important thing is to explain in detail what you've done in trying to identify the cause. Again, it's important to understand the customer's test method(s) and compare them to your own. Was the product DOA, or did it fail in burn-in testing, for example. Do the best you can, then tell the truth.
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Spot weld - Peel test failure Manufacturing and Related Processes 3
R Will multi-time flashovers constitute a failure of Hi-Pot test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
B IPCD Sterility test failure during MPQ (EO sterilization validation) ISO 13485:2016 - Medical Device Quality Management Systems 2
T Weibull analysis of life time test of 8 electric motors until failure Reliability Analysis - Predictions, Testing and Standards 9
C Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test" FMEA and Control Plans 1
R 5% to 95% Non-Condensing Humidity Storage Test Conditions and Failure Modes APQP and PPAP 2
J FDA 510K - Justifying Fatigue Test results - 3rd Party Component Failure US Food and Drug Administration (FDA) 7
Q Semiconductor Inductor Failure - Will HAAS/HALT or any other test detect it? Manufacturing and Related Processes 4
R Steel Casting defects - Again - Pressure Test Failure Manufacturing and Related Processes 10
R Sample Failure/Qualification Test Failure? - A few units were tested many years ago! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
J TFRR - What is actually required to be TEST FAILURE RESOLUTION REPORT Various Other Specifications, Standards, and related Requirements 2
J Seeking Excel Spreadsheet to help with cycle test for Weibull failure rates Excel .xls Spreadsheet Templates and Tools 2
G PFMEA failure modes for Process Function of Inspection/test FMEA and Control Plans 10
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
