Test Laboratory and Gage R&R Requirements
stlwtrs
Looking for some feedback. We have a test lab where we complete design testing, etc. In many cases calibrated tools are used to setup tests, etc. Some of the key processes used to setup a test mimic what is done in production. Is it necessary to complete Gage R &R on the calibrated tools used during test setup? If so, is there anything black and white that calls out this requirement?
Curtis317
Just a thought. Would not the validation requirements of the standard require you to do GRR to validate the measurement process?
H
Hanr3
The response is complicated.
Is your calibrated set-up equipment part of the traceability/MUA change for the test?
Is your calibrated set-up equipment calibrated in-house?
If your set-up equipment is found to be out of tolerance (OOT), could this affect your test results? IF so, it MUST be part of your traceability and MUA chain for that test, at minimum it must be determined if it provides any significant contribution to the MUA chain?
See 5.6.1 for the calibration traceability aspect.
See 5.4.6.2 for uncertaintiy of measurement.
See 5.5 for equipment requirements.
H
Hanr3
It would help tremendously to know the relationship between the set-up equipment and the test results.
For EXAMPLE:
A torque wrench is used to bolt cylinder heads to the block and your testing compression ratios. The torque wrench is part of the MUA chain and yes gage R&R should be performed.
Same torque wrench is used, however this time to bolt the engine to the test stand, still testing compression ratios. No the torque wrench is not part of the MUA and does not need to have gage R&R for the test.
However if it is in fact the same torque wrench used in both examples, the first example dictates that gage r&r, traceability to teh test etc. must be done.
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
A Pharmaceutical Manufacturer's obligations - Laboratory Test instruments General Measurement Device and Calibration Topics 0
M LDT (Laboratory Developed Test) Documentation Document Control Systems, Procedures, Forms and Templates 2
M Lot Numbers of Plastic Disposables in an LDT (laboratory developed test) ISO 13485:2016 - Medical Device Quality Management Systems 6
D US Laboratory which can do Bosch test F 02N P00 089 Contamination Spec VDA Standards - Germany's Automotive Standards 4
T Moving a Calibration/Test Laboratory to a new Location General Measurement Device and Calibration Topics 5
L How to set up a basic electronic test equipment calibration laboratory General Measurement Device and Calibration Topics 3
Ron Rompen Test Laboratory for Nanoscratch Testing General Measurement Device and Calibration Topics 1
M Is Notification of the Test Laboratory always necessary for Supplier Changes? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
D Calibration & Test Laboratory Non-Conformance Procedure Example wanted General Measurement Device and Calibration Topics 3
S AAMI EC57 for ECG Medical Device - Seeking 3rd Party Test Laboratory US Food and Drug Administration (FDA) 5
R Implementation of ISO/IEC 17025 Requirement for our Test Laboratory ISO 17025 related Discussions 2
Douglas E. Purdy Inspection & Test Laboratory Accreditation Requirements for AS 9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
6 Fuel Testing Laboratory Test Equipment - Methods and Calibration General Measurement Device and Calibration Topics 2
S Documents for ISO 17025 for Test Laboratory wanted ISO 17025 related Discussions 7
Z Laboratory Test Scheduling and Tracking Gantt chart Excel .xls Spreadsheet Templates and Tools 3
L Laboratory Testing for AS4259-1995 & AS5356-1:2004 - Seeking Test Lab Other Medical Device and Orthopedic Related Topics 5
B Is a certified microbiology test laboratory required? Milk and Cheese Processing Food Safety - ISO 22000, HACCP (21 CFR 120) 5
M China Test Laboratory - What are "CMA" and "CNAS"...? General Measurement Device and Calibration Topics 22
bio_subbu Choosing a laboratory for biocompatibility test ISO 13485:2016 - Medical Device Quality Management Systems 8
L EMC Engineer in a Test Laboratory Transitioning into Quality - Looking for Guidance Career and Occupation Discussions 4
S Testing Laboratory For Fire Resistance Test Reliability Analysis - Predictions, Testing and Standards 3
C EN 10247 Laboratory that can perform the non-metallic inclusions test on steel Various Other Specifications, Standards, and related Requirements 2
M Laboratory: Different Standard Designations for the Same Test Methods Design and Development of Products and Processes 7
K Accredited ISO 17025 Laboratory - Ultimate buyer insists on signing the Test Reports ISO 17025 related Discussions 8
M Ambient vs. controlled test laboratory environment Test Method Evaluation Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Is Temperature & Humidity monitoring in a Metrology / Test Laboratory required? General Measurement Device and Calibration Topics 28
D Is Wafer Probe (On Wafer Test) a Laboratory? Semiconductor Industry IATF 16949 - Automotive Quality Systems Standard 8
S Laboratory Test Reports ISO 17025 ISO 17025 related Discussions 7
Hershal PT/ILC - ISO 17025 section 5.9 - Proficiency Test/Inter-Laboratory Comparisons ISO 17025 related Discussions 27
J Advice on setting up an automotive test laboratory General Measurement Device and Calibration Topics 5
S 17025 Flexible Scopes of Accreditation - Laboratory to 'self-assess' new test method ISO 17025 related Discussions 2
D 50ml Syringe testing to ISO 7886-1:1997 - Seeking Test Laboratory Other ISO and International Standards and European Regulations 1
R Trying to find an ISO 17025 accredited testing laboratory to verify our test results ISO 17025 related Discussions 14
D Internal Laboratory - Defining the Laboratory Scope - Inspection, Test, Calibration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
C 17025 Accreditation Audit - Test Laboratory ISO 17025 related Discussions 42
K Test Laboratory Audit - A Calibrated Wall Clock? QS-9000 - American Automotive Manufacturers Standard 3
D Test Equipment at Work Station - Are Operator Daily Checks part of Laboratory Scope? General Measurement Device and Calibration Topics 7
Marc Engineers In The test Laboratory - Does this affect the Laboratory Scope? General Measurement Device and Calibration Topics 0
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
