Test Methods for Angle Blocks, Squares, Feeler Gages, Protractors, and Steel Rules
merrick65
My question is does anyone know what test methods (ASTM; Navair; etc) are used for the following items: Angle blocks; squares; feeler gages; protractors; and steel rules. In the past we have referenced MIL-STD120 on our calibration certificates. Can we continue to use MIL-STD120 even though it has been obsoleted? Along the same line would it be ok to use Fed Spec GGG-G-17 for radius gages?
harry
Re: Test Methods for Angle Blocks, Squares, Feeler Gages, Protractors, and Steel Rule
Any takers for this question??
merrick65
I did find a test method for steel rule/scale (GIDEP C2006). Still looking for help on the others.
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
S IVF medical devices standards and test methods Medical Device and FDA Regulations and Standards News 4
D Do Test Methods completed to a standard require validation? ISO 13485:2016 - Medical Device Quality Management Systems 7
0 Improvement and Standardization of Test Methods between Sites Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Comparing Two Test Methods - Acceptable Difference(s)? Statistical Analysis Tools, Techniques and SPC 3
M Biocompatibility Test Methods for Sensitization US Food and Drug Administration (FDA) 5
S Writing a Test Method Validation Procedure as well as Validation of Test Methods General Measurement Device and Calibration Topics 1
Z ISO 3108 Wire Rope Tensile Test Methods General Measurement Device and Calibration Topics 3
6 Fuel Testing Laboratory Test Equipment - Methods and Calibration General Measurement Device and Calibration Topics 2
C BS EN ISO 12952-1 thru 4 - Test methods for burning behaviour of bedding items Other ISO and International Standards and European Regulations 2
S Attribute vs. Variables Specifications - Test Methods Benchmarking 15
M Laboratory: Different Standard Designations for the Same Test Methods Design and Development of Products and Processes 7
M Assigning a PDF for Analog Resolutions - OIML R49-2 Test Methods for Cold Water Meter Measurement Uncertainty (MU) 3
Q Ford's for material test methods for tensile strength, compression deflection, etc. Customer and Company Specific Requirements 4
T ISO 7587 - Electroplated coatings of tin-lead alloys - Specification and test methods Various Other Specifications, Standards, and related Requirements 1
M Knowledge of test methods in order to conduct an internal audit to ISO 17025? ISO 17025 related Discussions 3
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 2
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
