Test of Means or Medians for Non Normal Populations?
Brad Gover
HI All, I have a number of paired data sets of various characteristics that per my Anderson Darling test one or both of the sets are not normally distributed at a 95% confidence level. I would like to see at that same confidence level if the means are different. I don't think I can use a two sided t test in this case. Is there a test for the means on non normally distributed data? Should I use the Mann-Whitney U test or Mood's Median test?
Thanks for the advise
Brad :bigwave:
Statistical Steven
Statistician
Brad :bigwave:
If you have PAIRED data, then the differences of the pairs should be approxminately normal if the two set of data came from the same distribtion. If so, you can use the paired t-test.
Brad Gover
I believe the data is paired in so far that one instrument measured the exact same point as the other. Unfortunately I only have one set of measured data from both instruments. One company measured each characteristic once as did the other company. Each point corresponds to the exact same area so ideally they should be identical. I will try to post an excel file of the two data sets.
Thanks,
Brad
N
NumberCruncher
Hi Brad
I've looked at your data. Most of the differences are approximately normally distributed, but there are a few serious outliers in both data sets.
A simple t test suggests that data set 1 is not significantly different to zero, but data set 2 is significantly different to zero. My concern is that, when I take out just 2 outliers, from data set 1, the t test tells me that this is also significantly different to zero.
I am not happy with the t test because of these outliers.
I would suggest using the Mann-Whitney test on the data and see if this confirms the above conclusions.
NC
Brad: your data is still matched pairs. The fact that you have only one reading from each supplier means that the suppliers individual repeatability is confounded with the between supplier reproducibility. If the total measurement error is acceptable in relation to the specifications then all is well. If it isn't then you need to determine if one or both suppliers has substantial repeatability problems. (what is the specification limit?)
I have attached a spreadsheet with the Youden analysis, Matched pair analysis (and I also threw in a gratuitous distribution analysis).
You have a small bias between the two measuremetns in data set 2 but it is very small compared to the total error.
There is no bias between the two measurements in data set 1.
As an aside, the lack of fit to a Normal distribution is very minor. t tests and ANOVAs are relatively unnaffected by this lack of fit. And in any case a simple plot of the data tells you what you need to know. No need for fretting about mathematical precision.
I think that we have collectively forgotten how to plot and think about our data now that sophisticated statistics can be done in milliseconds with JMP or Minitab...
P Question on Table 6 "Test voltages for solid insulation forming a MEANS OF PROTECTION IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T ESD test 50% flashover discharge - Do anyone know that 50% flashover discharge means? Reliability Analysis - Predictions, Testing and Standards 6
D T tests - To test for central measure (means) - Steel supplier Statistical Analysis Tools, Techniques and SPC 8
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R Regulatory Affairs Certification (RAC) prep - Practice test versus actual exam Professional Certifications and Degrees 1
R SAT (System Accuracy Test) temperature according to AMS2750E AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
A Earth leakage current test for Permanently installed Large scale MEE IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Bench test report translation to English for 510(k) submission Other US Medical Device Regulations 2
J Production Line Test Brasil - High Voltage Dielectric Strenght Test Other Medical Device Regulations World-Wide 5
