Test Standards for Compression Springs
silentrunning
#11
On a compression spring the most linear range is just after the end coils have been compressed to complete contact and are parallel with the plattens, and then compressing it until the penultimate coils begin to close. Once the closing of the body coils begins the rate increases and the spring rate becomes less linear. The ideal way to specify a spring is to specify a load at minimum compression and a load at maximum compression. You then check the rate between the two compression lengths.
trisp
#12
doesnt the spring constant remain same for a spring? isnt it an inherent property of a spring(its stiffness)...
you mean to say its "K"(stifness) varies with compression?
silentrunning
#13
Yes, even though K is refered to as the "spring constant", it isn't. As a spring is compressed towards solid height, the number of active coils is reduced. This in turn increases the K (rate). On some springs this increase is quite dramatic on others it is almost immeasurable. It depends on the spring design.
K
krayworth
#14
What are the dimensions of the spring? Equipment designed to test springs must have the appropriate mechanical motion control and force measurement capability. Engineers who require a material testing system are faced with a wide array of possibilities. The decision around what system to choose should be based on the specific spring application, the cost, and the value to the spring manufacturer of their investment over time. I wouldn't compromise on a universal system but instead invest in a system configured to the specific needs.
Englishman Abroad
#15
Hello all,
Compression springs have a force vector that is not neccessarily along the spring body centreline. The force vector will change based on the how the end coils touch the supports, and how the subsequent coils touches the support (and the coils touch themselves) as the spring compresses.
The norm is for the designer to specify a distance tolerance at a fixed load (or the opposite), and a spring rate (with a rate tolerance) between 2 fixed loads or distances (based on the working requirements of the spring in the system).
If you have an complicated spring system you may need to think about how to specify the force vector also (this is normally specified as a zone through which the vector must pass at either end of the spring).
However to say that a compression spring is linear from the free state to the solid (all coils touching each other) state is an over simplification that we all learnt in school.
S IVF medical devices standards and test methods Medical Device and FDA Regulations and Standards News 4
D IEC EN 61326 Dated Standards - Dated standards for test protocols CE Marking (Conformité Européene) / CB Scheme 3
E Particular standards, essential performance in EMC Immunity Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J International Standards governing Test Method Validations ISO 13485:2016 - Medical Device Quality Management Systems 1
P List of Standards for different Electrical/Medical Parts or any Test Procedures Other Medical Device Related Standards 4
L Find the right Test to fail method according to the standards of LV 124 FMEA and Control Plans 1
S UK Test Certification Houses for Electrical Medical Devices ? Multiple Standards Test Other ISO and International Standards and European Regulations 2
T Tensile / Pull test standards / Specimens - 14 mil vinyl interior products Quality Tools, Improvement and Analysis 6
J Old "outdated?" standards - Seeking an ASE J964 "grind lead test method" Other ISO and International Standards and European Regulations 6
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
