Testing a US device in Europe to prove Equivalence in a ?head-to-head? Study
P
pschnoor9
Testing a US device in Europe to prove Equivalence in a “head-to-head” Study
We have identified a US device as our predicate for a medical device being produced in Europe. In order to prove equivalence in a “head-to-head” study, we would like to bring some of these devices to Europe for testing.
Is there anyone with knowledge or experience regarding clinical studies (not trials) that involve the use in Europe of a non-CE marked device from the US? These devices will not be put on the market in Europe and will remain the property of our company. Also, the agreement with the study participants will follow GCP, including the requirement for return of the device at the end of the study.
Is it appropriate to use the 510k clearance of the US device as a basis for a “safe to use” claim?
Any advice or guidance is appreciated.
Stijloor
Re: Testing a US device in Europe to prove Equivalence in a “head-to-head” Study
A Quick Bump!
Can someone help?
Thank you very much!!
c.mitch
I answer you because I saw the quick bump! Perhaps other guys could give more information.
Clinical trials with MD that are not CE marked are regulated by article 15 of 93/42 EC directive. To do so, you shall build a technical file according to annex VII and ask the authorization to do clinical tests to the ethical commitee of the country where you want to do the tests.
The technical file should be easy to build, picking up data from your Fda clearance. The authorization should be easy or hard to obtain, depending on the "mood" of the authority.
P
PaulGr
From your post it is not clear if the 'identified US device' is your device or a competitors device. If it's the latter, you will have an issue with building the required file (see post of c.mitch) as key documents like the risk analysis and test report will not be directly available.
In that case I would suggest to check if you could proof equivalence based on intended use, technology, specifications from the manual and bench testing or other non-clinical testing.
Or, if you really need the clinical testing, consider running the tests in the US.
(ISO 14155)Clinical Investigation-
any designed and planned systematic study in human subjects undertaken to verify the safety and/or performance of a specific device.
Any studies that use humans are classed as Clinical Investigations. As c.mitch highlights these are regulated by annex VIII (and annex X). As part of that you will need to have your Clinical Investigation Plan authorised by the Ethics Committee of the institution involved and by the national Competent Authority (in the UK this is the MHRA). Detailed within your plan will need to be descriptions of equipment involved. The use of non-CE marked devices will need to be highlighted.
The authorisation to use such devices will depend upon the risks involved. If the device is marketed in the USA (with FDA clearance) this would give a high degree of confidence that the device would not represent significant unknown risk.
P
pschnoor9
:thanx: Thank you to all three respondents - the information is very helpful. The device is a competitor device, so a technical file is not possible; we have written our rationale for allowing this study, but it seems the biggest concern is the possibility that we will be perceived to be "placing this (non CE marked) device on the market". We have stipulated that we will control access to the devices, but no approval yet.
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Release testing for Combination Drug-Medical Device Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
lilybef Number of lots required for stability testing of a Class II device in the 510(k) Qualification and Validation (including 21 CFR Part 11) 3
S IEC 60601-1-2 Radiated E-Field Emission Testing - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Medical Device Endotoxin Testing for ANSI/AAMI ST72:2011/2016 Other Medical Device Related Standards 1
K Substantial Equivalence Predicate Device Testing Other US Medical Device Regulations 1
M Medical Device News Health Canada update - Applications for Medical Device Investigational Testing Authorizations Canada Medical Device Regulations 0
Sam Lazzara Time Zero testing in med device aging studies Qualification and Validation (including 21 CFR Part 11) 3
S Testing my ECG device as per IEC 60601-2-25 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Routine Testing for Class I Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 24
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Investigational Testing - Does the Medical Device have to be "sold"? Canada Medical Device Regulations 7
M Testing a Low Current (Battery) DC Medical Device Other Medical Device Related Standards 4
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
J IEC 60601 Medical Device Testing House Costs IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
N Class 2 Medical Device Use Life Testing Reliability Analysis - Predictions, Testing and Standards 1
J Blood glucose monitoring device testing - GLP or GCP Other US Medical Device Regulations 1
ScottK Importing medical device for use in fit testing of packaging Other US Medical Device Regulations 3
J Clinical Testing - NSR Device Other US Medical Device Regulations 2
S Sample performance testing for a software-only medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M EMC Testing for a US-only, Home-Based Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Medical Device Testing for Airport Security US Food and Drug Administration (FDA) 5
S Testing software-only device on hardware - What are the hardware parameters? Software Quality Assurance 6
W Is IEC 60601-1-2 compliance/testing required for battery powered Class I Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Medical Device Software - Final Field Testing Best Practices IEC 62304 - Medical Device Software Life Cycle Processes 5
N Critical Analysis of Medical Device Bench Testing data ISO 13485:2016 - Medical Device Quality Management Systems 6
A Beta Testing FDA Regulated Medical Device Software vs. Nonconforming product? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Human Factors Testing for CE Marking of a Cosmetic Device CE Marking (Conformité Européene) / CB Scheme 9
M IEC 60601-1 testing for device with its own 2V battery power supply necessary? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
F Wireless Dongle - Include in Medical Device Testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L Medical Device Stability Testing Requirements EU Medical Device Regulations 1
I Biocompatibility Testing Requirements for a Class I device - Does not contact patient 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J EMC Testing for Medical Device with Solenoid Valves IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
G Margin of Safety for Medical Device Fatigue Testing Reliability Analysis - Predictions, Testing and Standards 5
D Testing to determine Life Cycle of a Medical Device Reliability Analysis - Predictions, Testing and Standards 7
J Biological Evaluation requirements per ISO 10993 - Medical Device Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
K High Risk Medical Device Type Testing (China Requirements) China Medical Device Regulations 5
K High Risk Medical Device Type Testing in Korea (Requirements) Other Medical Device Regulations World-Wide 5
A Taguchi Inner and Outer Array Design for Medical Device Testing Quality Tools, Improvement and Analysis 1
M Brazilian Requirements for Medical Device Production Testing to IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Separate Medical Device 12V Power Source - What inspection and testing is required? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
