Testing Emergency procedures in real life.
#11
Yep, real life *is* the best drill
I think that if the company did have a drill / testing schedule, then you are right, Dave, there was nothing to 'get away with' and they did meet the requirements (as long as they evaluated the effectiveness of the response). The fear is that they were relying on real life emergencies to test their system. I don't think any of us would want to count on live emergency situations to see how our system works.
Amen to that....
Yep, real life *is* the best drill. If they had a drill scheduled, cancelled it after the real emergency and then went on to evaluate it and implemented the actions decided on that basis... then I think all is well... As I said I don't have that information, but it's certainly a topic worth discussion, because this won't be the last time this happens.
/Claes
#12
A little clarification
The use of "real" emergencies in lieu of “test” emergencies can be a bit tricky. After reading Dean’s response:
I can see where he is going, and I agree. My comments were more from the standpoint that if a test was scheduled for Tuesday, and we had an emergency on Monday, then we have met the requirements for Tuesday's test. I must make this clear... at NO TIME would I suggest using real emergencies as the only method! But if a real emergency does occur, I think you can count it as a "test".
As far as registration before you can demonstrate the EMS works, may it never be! But Alas...
G
Gusman - 2005
#14
A few questions regarding emergency preparedness and response procedures...not sure if it belongs in this thread, but will post it here anyway.
1. Are emergency preparedness procedures only required for significant aspects?
1a. For example, if we have drums of oil on the loading dock as an aspect, but have determined them insignificant because our current control measures eliminate the possiblity of any environmental impact, do we need an emergency response procedure?
2. What if we do have emergency procedures in place that do not apply to significant aspects, s hould those be included within our EMS?
:confused:
Dean P.
#15
My answers:
1. Emergency procedures are required for any potential emergencies, not sig. aspects. There is a relation there, as an emergency (i.e. a spill) could create a significant aspect, but the procedures should be focusing on the emergency itself, not whether or not an aspect is involved.
1a. On your shipping dock, you may have control measures which reduce the potential of an emergency, but there is still some potential for a spill into the environment, so you should have procedures in place. The potential may be very low, but is still there. And I would think that, even though your drum storage area is not deemed significant as is, a spill would probably create a significant aspect.
2. Other emergency procedures (such as injury response, machine entrapment, etc.) may not be a part of your EMS, but it would be useful to include them into this program, if only for the fact that it formalizes the procedures and brings them under document control.
Hope this helps.
Dean
#16
:confused:
Excellent questions! Although the standard revolves around your “significant” aspects, I think you would not have an effective EMS, if you only included accidents and emergencies that relate to your significant. I think the reason that the standard does not specify accidents and emergency situation that do not involve significant aspects it this. If you have an accident, say, you spill your cup of coffee. A several questions arise:
1) What is the impact of the spill?
2) Would this fall into the category of an “emergency”?
3) Do need to respond to the spill?
4) How should you respond?
Any accident or emergency situation that would result in a “crisis”, should deal with a “significant” aspect. Now, by crisis, I do not mean that you have to get a change of clothes.
As far as your drums of oil, should something run into them, and rupture a few, would that create a “significant” aspect? The level of control shouldn’t dictate whether they are significant. Their potential impact should.
As far as emergency plans that are not associated with significant aspects, I would encourage you to include them. If they are important enough to have a plan, then they should be important enough to audit and ensure they are capable.
-----added----------
Wow! Dean. You posted, as I was writing, and we kinda ran along parallel lines. Man, has your credibility just taken a hit! :bigwave:
G
Gusman - 2005
#17
Good, quick answers.
I understand that the potential for an impact requires consideration in significance and emergency preparedness (which are totally unrelated),
but now have a follow-up question.
Our current significance rating procedure incorporates control measures into the process. My thoughts are "if there are control measures in place to avert the potential for impact and these measures are 'fail-safe,' then is the aspect truly significant?
Is this a correct/acceptable procedure?
#18
My quick answer is no. The fact that you dealt with the aspect doesn't change its potential severity. If you think of an FMEA (provided you know what an FMEA is), we can make sure the failure does not occur, and we can increase the ability to detect it before it occurs, but should it occur, we probably can't do a lot about the severity. Significance is like that. I can do everything possible to contain the oil that is in the drum, but what if it gets out? What is the impact.
Now, before you go nuts. Just because you now call the oil significant, does not mean you have to do ANYTHING different! You have the controls in place, and you might be able to leave it at that, provided you adhere to the controls. Audits would confirm this.
My take anyway. Dean..anything to add?
G
Gusman - 2005
#19
To be honest, this conflicts with my understanding of how significance determination works...
I understand your line of reasoning concerning the potential impact - what if it does get out? - but the potential for this happening is so miniscule...(we have not only operation controls, but curbing and slopes to eliminate the impact to the environment). I'm not sure I can succumb to the thought that it is significant because it is there.
On a parallel line (and kind of off subject) is a prisoner in a maximum security prison, chained to his bed, guarded by dogs, electrical currents, and rifles and significant threat to society just because he is there?
G
Gusman - 2005
#20
To continue my original thought,
our significance determination process takes into consideration more than just potential impact. We consider
1. the concern of interested parties,
2. Regulatory Risk,
3. Severity,
4. Frequency, and
5. Control.
What do you think of this?
M Testing criteria - where to place Design and Development of Products and Processes 1
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
P Testing cloud-based backups IT (Information Technology) Service Management 7
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Flammability Testing of Aircraft Interior Materials Federal Aviation Administration (FAA) Standards and Requirements 0
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
M Inter-operator Variability Testing - Requirements for EU Medical Device Regulations 5
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
