Testing Emergency procedures in real life.
#21
Gusman said:
On a parallel line (and kind of off subject) is a prisoner in a maximum security prison, chained to his bed, guarded by dogs, electrical currents, and rifles and significant threat to society just because he is there?
A quick answer is he was. That is why he is there. If I were to make a list of all known significant threats to society, I would put his name on the list. I would also annotate that he is currently in custody. Agencies do not have to spend any resources looking for this guy.
Gusman said:
To continue my original thought,
our significance determination process takes into consideration more than just potential impact. We consider
1. the concern of interested parties,
2. Regulatory Risk,
3. Severity,
4. Frequency, and
5. Control.
What do you think of this?
We use similar things. Although "control" isn't one of them, we do look at the probability of release.
Now, if I were auditing you, I doubt that I would write a nonconformance on the way you determine your significant aspects (based on the 1996 edition). I might ask a few questions about any emergency plans you have concerning the oil storage. I would also ask about the emergency plans that are not part of your EMS. But even then, I'm not certain I have sufficient evidence for any nonconformances. Perhaps an observation or two.
G
Gusman - 2005
#22
Thanks db.
I think this was a very valuable discussion from my perspective...it should change the way we evaluate our aspects as we are currently evaluating them.
Gus
W
Wilf from Sask
#23
Test vs. drill
Late spring we received a minor N/C for not testing the emergency response plan - which was true.
Our corrective action plan was to conduct a test in the summer (with a deadline) as the majority of activities are outdoor seasonally based. The auditor accepted this corrective action plan.
Our test was to conduct several unannounced spot inspection for forest fire fighting equipment and spill kits in our vehicles and quiz the staff on our EMS procedures for fire fighting and dealing with a spill. About 10% of our staff and vehicles were inspected and quizzed
It sounds like we are likely going to be written up during our external surveillance audit (it will be over later this week)
The auditor is concern that our test was not with our highest risk people, who are those who work for us under contract and actually handle fuel and are most likely to come across a forest fire.
I agree that we did not conduct a test with the contractors. – However, we did do a test of the emergency response procedure. Our staff knowledge was good and we discovered one vehicle had some deficiencies in emergency equipment.
Excuse the vent… …
My emergency response question is: does the standard differentiate between a drill and test?
Our auditor is hinting he likes mock simulations rather than a knowledge testing and equipment checks.
...Wilf
#24
Wilf from Sask said:
Our test was to conduct several unannounced spot inspection for forest fire fighting equipment and spill kits in our vehicles and quiz the staff on our EMS procedures for fire fighting and dealing with a spill. About 10% of our staff and vehicles were inspected and quizzed.
I'm not too certain this meets the requirements, even if you did 100%. Perhaps it is the way you worded it, or perhaps the way I read it, but it sounds more like you auditing rather than testing. I would think a test might be along the lines of you do an unannounced burn simulation to see how the group(s) respond. The important thing is to see if your emergency response system works, not to see if they have the equipment.
W
Wilf from Sask
#25
Good point.
I would have to agree that asking someone if they know how to use a shovel isn’t the same as using a shovel. It is quite possible that some individuals would not know that creating a mineral guard to prevent fire spread is usally a better method than covering a fire with dirt as the roots can smoulder for a long time.
#26
I'm not an expert in fighting forest fires, but I have worked a bit with emergency response. Another factor to consider is response time of each step in the process. How much time does it take from the event to initial notification? How much time from initial notification to initial response? How much time from initial response to arrival? Typically, the more time each step takes, the greater the impact.
Odd question, how does one minimize the impact of a fire?
Randy
#27
Get rid of the fuel source?
Change the path?
Put it out?
BTW...If your auditor has concerns tell him to show his butt up when a fire is going on to see if the procedures work.
#28
Change the path?
Put it out?
Okay, but that might limit size, but what about the severity (thinking FMEA here)?
I think this is more of a test of your auditor. There are a few (you and I, I think) that would not hesitate to jump in and grab a shovel. I do wonder how many would run...run far and run fast. :lmao:
Randy
#29
QUOTE]
That would go with limiting the access to fuel. Severity could also be limited by altering the path from high value areas like residential or improved locals.
Of course it would boil down to how severity is measured.
M Testing criteria - where to place Design and Development of Products and Processes 1
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
P Testing cloud-based backups IT (Information Technology) Service Management 7
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Flammability Testing of Aircraft Interior Materials Federal Aviation Administration (FAA) Standards and Requirements 0
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
M Inter-operator Variability Testing - Requirements for EU Medical Device Regulations 5
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
