Hi All,
I have a vendor wanting to run belt sanding tests to prove his belts can significantly decrease cost (over time) by running faster and increase longevity. He has requested to run 5 pieces (20ft in length and about 2" in diameter) repeatedly. These belts (4 in total and 5" wide each) are designed to give a grained appearance to the pipe. The belts will not differ between individual sanders. Each sander will have one belt. Here is my question:
Will running these same 5 pieces repeatedly give me a reliable result as to belt fatigue, load, wear out, etc.?
I would assume, dangerously enough, that once the initial grain has been achieved - on the first pass - that subsequent passes will be easier on the belts than running an unfinished piece each time (as we would in reality). Am I correct?
Thank you all very much!
