Testing Medical Equipment used in conjunction with Oxygen Rich Environments
Roland chung
Hello folks,
Does anyone have experience in testing of medical equipment used in oxygen rich environments?
According to clause 11.2.2.1 a) 5) of 60601-1:2005, spark ignition test apparatus (figure 34) is used to determine if a source of ignition exists. I am confusing how to choose electrical parameters for test (current, voltage, capacitance, inductance or resistance). Because the circuits in practice are complex, it is not easy to decide which electrical source shown in figure 35 to figure 37 should be used.
Any thoughts will be highly appreciated.
Roland
60601-1:2005 said:
NOTE 2 For ME EQUIPMENT that includes a circuit not addressed in Figure 35 to Figure 37 (inclusive), either the test voltage or current may be set at three times the worst case values with the other parameter set at the worst case value for determining whether ignition can occur.
Hope this helps.
Marcelo
Well, just to clarify things, the spark gap test is an alternative to evaluating the limits of figures 35 to 37 (which requires that you measure I x U, U x C and I x L of your circuit and compare them to the figures). And then only if you verified if 11.2.2.1 a) 1, 2, 3 and 4 do not happen (if so, the criteria for a sourcee of ignition to exist would be met and you would not even need to evaluate 11.2.2.1 a) 5)).
So you mean you verified 11.2.2.1 a), b) , c) and d) and no one can exist (in NC and SFC) and then, for 11.2.2.1 a) 5, you cannot measure and evaluate the limits according to figures 35-37?
Roland chung
11.2.2.1 a) is to determine the source of ignition. Any of a)1) to a)5) exist in NC and SFC shall be considered to be sufficient for ignition. I do not understand why we do not need to evaluate 11.2.2.1 a) 5) if verification per a)1 to a)4) has been done respectively.
Yes, it is clear that the spark test is an alternative of a)5). Since we do not have other test methods, we would like to follow this spark test.
My concern is how to use Figure 35 to 37. It would be better to give an example.
Marcelo
Oh sorry, I meant to say that if you evaluate 1-4 and there's a sourrce there, you will need to verify it first. You would then need to address 5 anyway, you are right.
Roland chung
Manufacturers of lung ventilators, anaesthetic systems and their associated devices (e.g. Respiratory humidifiers) would suffer from this situation.
Any thoughts?
Marcelo
The "normal" evaluation of a) 5) is an assessment, not a test. If your circuit approximates the model circuits of figures 35-37, you need to calculate the worst case situations of your circuit, including safety factors, and create a model circuit of your circuit and then compare the results with the reference curves on the figures. If the resulting circuit does not pass the limits, a) 5) is ok. This is the way to use the curves on the figures.
If you prefer to test instead of relying on the comparison, you will still need to calculate the resulting circuit (worst cases + safety factors), and then perform the test using the apparatus and the resulting circuit.
And then, as the mentioned note says -
Regarding which circuit to use....it depends on your model circuit, you need to evaluate if your circuit is purely resistive, capacitive or inductive and then use the right one.
You can also take a look at G.5.3 * Low-energy circuits - which uses the same idea.
K Is a 3V torch classified as medical electrical equipment needing EMI/EMC testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P Testing to clause 15.4.6 - Actuating parts of controls of Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Help with Electrical Safety Testing - Medical Equipment Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
M Informational US FDA draft guidance – Testing and Labeling Medical Devices for Safety in the Magnetic Resonance (MR) Environment Medical Device and FDA Regulations and Standards News 0
M Routine testing of medical electrical systems - What specific electrical safety tests should be performed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
K Release testing for Combination Drug-Medical Device Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
B Stability testing of medical devices as per ASTM F1980-16 CE Marking (Conformité Européene) / CB Scheme 0
S Medical Device Endotoxin Testing for ANSI/AAMI ST72:2011/2016 Other Medical Device Related Standards 1
M Medical Device News Health Canada update - Applications for Medical Device Investigational Testing Authorizations Canada Medical Device Regulations 0
S Routine Testing for Class I Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 24
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
M Investigational Testing - Does the Medical Device have to be "sold"? Canada Medical Device Regulations 7
M Testing a Low Current (Battery) DC Medical Device Other Medical Device Related Standards 4
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
J IEC 60601 Medical Device Testing House Costs IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
M Sampling Plan for for Chemical Analysis Testing of Medical Devices EU Medical Device Regulations 3
JoCam Portable Appliance Testing of Medical Devices EU Medical Device Regulations 4
N Class 2 Medical Device Use Life Testing Reliability Analysis - Predictions, Testing and Standards 1
ScottK Importing medical device for use in fit testing of packaging Other US Medical Device Regulations 3
S Sample performance testing for a software-only medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Biocompatibility testing for nasal prongs made of medical grade silicone 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M EMC Testing for a US-only, Home-Based Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Medical Device Testing for Airport Security US Food and Drug Administration (FDA) 5
T Testing bluetooth medical devices against Japan Radio Law requirements Japan Medical Device Regulations 2
P Serial Testing of Bioburden for Medical Devices Other Medical Device Related Standards 2
R Medical Device Software - Final Field Testing Best Practices IEC 62304 - Medical Device Software Life Cycle Processes 5
P ASTM-F2096 Medical Package Testing Various Other Specifications, Standards, and related Requirements 1
C Safety Tests Required for In-Process Testing of Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Critical Analysis of Medical Device Bench Testing data ISO 13485:2016 - Medical Device Quality Management Systems 6
A Beta Testing FDA Regulated Medical Device Software vs. Nonconforming product? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
F Wireless Dongle - Include in Medical Device Testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L Medical Device Stability Testing Requirements EU Medical Device Regulations 1
P Testing Standards - Regulatory agency doing Enforcement Testing of Medical Devices EU Medical Device Regulations 5
J EMC Testing for Medical Device with Solenoid Valves IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
G Margin of Safety for Medical Device Fatigue Testing Reliability Analysis - Predictions, Testing and Standards 5
D Testing to determine Life Cycle of a Medical Device Reliability Analysis - Predictions, Testing and Standards 7
J Biological Evaluation requirements per ISO 10993 - Medical Device Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
K High Risk Medical Device Type Testing (China Requirements) China Medical Device Regulations 5
K High Risk Medical Device Type Testing in Korea (Requirements) Other Medical Device Regulations World-Wide 5
A Taguchi Inner and Outer Array Design for Medical Device Testing Quality Tools, Improvement and Analysis 1
M Brazilian Requirements for Medical Device Production Testing to IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Separate Medical Device 12V Power Source - What inspection and testing is required? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Sam Lazzara Seeking Medical Device Luer Fitting Testing Laboratory Service Other Medical Device Related Standards 5
M Stability Testing of Medical Devices - Ambient Temperature and Long Term Storage 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C Applicability of ISO 13485 for Medical TESTING Company ISO 13485:2016 - Medical Device Quality Management Systems 3
E Reference Standard for Shelf Life Testing of Packaging for Sterilized Medical Device Other US Medical Device Regulations 3
