Testing Tensile Strength of Materials
Michael_M
We are being told we have to test our material properties more often than before. Last year we purchased a decent XRF gun for chemistry, and we have had a hardness tester for a while now to check Rockwell hardness of material. One of the questions now is tensile strength of material. I have done some research but most of the information I pull up is 'we will sell you.....' or 'we can perform this test'.
Do any of you have any real information on how tensile strength is tested and do you send material out to be tested or do you do it internally. If you do it internally, what do you use to test the material?
The requirements use to be chemistry only and we use to send to an outside, accredited, lab but we are trying to streamline and reduce the costs by doing these internally where possible.
Thank you,
Off-topic--I wonder how much of these material testing requirement happened because of the Kobe Steel incident?
Sidney Vianna
Post Responsibly
Tensile tests of metallic material is not an ordinary test; see below. You have to machine the specimens very carefully and the equipment is very specialized. Very few organizations have their own testing lab for this type of testing. You will likely be expected to send samples to be tested in ISO 17025 accredited AND Nadcap approved labs.
Marc
Hunkered Down for the Duration
I can't say, but I can say that way back in 1991 I was working with an automotive parts manufacturer and they had their own tester and it was a relatively small company. They used it for several things, including testing material coupons they got. They also has several holding fixtures for testing weld strength (essentially a "pull test").
As time (and advancements in science and technology) advance it will undoubtedly become more common for advanced measurement and material verification techniques to be required. Some of it will be from "learning" events as well.
Pancho
wikineer
Following Sidney’s comment, there are standard methods for testing various materials. For example, ASTM B557 specifies testing procedures for aluminum alloys and ASTM A370 for steel. We fabricate coupons to these standards and send them out to a certified lab to test.
Crusader
I use a Tensile Tester at work on a weekly basis. We bought a Thwing-Albert tensile tester from "Thwing-Albert". Materials Testing Equipment
There are built-in templates in this tester and the company can heIp customize the type of template that best fits your needs. We test in a group of 6 test samples. The material we pull-test is vinyl material that we fabricate from a batch liquid formula. We test for tensile strength. The upper and lower grip hold onto the 4" long strip (1" wide) and the machine pulls the vinyl until it breaks, then the machine records the tensile strength, break elongation, and other data then charts it automatically. The data can be exported.
Soooo to answer your question, I believe some orgs can do the testing for you if they have the appropriate test template and machinery. I don't recall the cost of our machine if you're curious. It was a good investment though. It does provide that warm-fuzzy feeling that your process is consistent. And it will tell you if you stray out of consistency.
AYDOSE
Thank you,
Tensile tests of metallic material is commonly used in drawing process, tensile test crucial especially in hard drawn wire (bare, plated, alloy etc.)and every manufacturer has tensile testing machine (e.g: some of producers: Zwick, Instron, Shimadzu, in their internal lab. You can directly contact with equipment manufacturer to find optimum solution according your requirement like load cell, grip types ....
Ronen E
Problem Solver
Moderator
It all comes down to the application and the requirements. In some cases the above is true, but not in all cases. There is a great variety in available equipment (low end to the very top) and prices vary accordingly. I've seen many manufacturers who have tensile testing setups in-house.
I'm happy to help anyone look at the specifics and choose appropriate equipment. I'm a qualified mechanical engineer (all mechanical engineers have to study this topic including labwork, I think in year 1 or 2 IIRC).
Edit: Forgot to mention - I have no affiliation whatsoever with any company making or selling tensile testing equipment.
A Tensile Strength Testing of Rubber Underwear Manufacturing and Related Processes 2
Q Tensile Testing Transfer from one site to another site Manufacturing and Related Processes 2
D Manual Tensile Testing Pull Rate Speed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Interpreting Level of Confidence - Round Robin for Tensile Testing - Help needed Statistical Analysis Tools, Techniques and SPC 4
S Wire Pull Tensile Testing - Splice with multiple wires Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q Stability & Variability Studies - Tensile Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
W MSA for Destructive Testing - Tensile tester - Welding Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Metallurgical or tensile testing for new PPAP's or tooling re-cuts Customer and Company Specific Requirements 2
K Tensile Standards used to Verify a Tensile Testing Machine General Measurement Device and Calibration Topics 3
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 2
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
M Inter-operator Variability Testing - Requirements for EU Medical Device Regulations 5
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
JoCam MDL in Canada without Canadian Electrical Testing Canada Medical Device Regulations 0
T HF testing / Summative evaluation for MDDS class I necessary? Human Factors and Ergonomics in Engineering 2
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 5
M Workplace Drug Testing in 2020 Misc. Quality Assurance and Business Systems Related Topics 9
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 4
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 8
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 3
T Qualification testing of Lead acid batteries Reliability Analysis - Predictions, Testing and Standards 0
D Sterility and BioBurden Testing for Plastics ISO 13485:2016 - Medical Device Quality Management Systems 5
DitchDigger IEC 60601-1 subclause 5.1 - Adequate evaluation in lieu of testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
MrTetris Are GLP required for testing cytotoxicity and soil remaining after sterilization of MD? Other Medical Device Related Standards 8
D Design Verification - Is testing required? Design and Development of Products and Processes 5
M Specific Absorption Rate (SAR) Testing - What Standard to Use? Other ISO and International Standards and European Regulations 1
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 1
T Spirometer - Pulmonary Function Testing - ATS/ERS:2005 EU Medical Device Regulations 5
M 510(k) 10993 Biocompability Testing Other US Medical Device Regulations 15
C Sterility and Bioburden Testing - LAL passed under 0.5EU/mL Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
P IEC 62304 - evaluation of integration and system testing IEC 62304 - Medical Device Software Life Cycle Processes 4
H EO Sterilization Validation - Sterility Testing and Load Configuration Other Medical Device Related Standards 1
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
W SOP examples wanted - Soil, Concrete and Asphalt testing ISO 17025 related Discussions 3
M Informational TGA Consultation: Review of the regulation of certain self-testing IVDs in Australia Medical Device and FDA Regulations and Standards News 0
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
K Mammography Machine Bench Testing - FDA 510(K) US Food and Drug Administration (FDA) 5
D Is Human Factors testing mandatory for a 510(k) submission? Human Factors and Ergonomics in Engineering 16
W My company is looking to start a materials testing lab that conforms to ISO17025:2017 ISO 17025 related Discussions 3
