The CORRECT steps to implement an SPC chart
bobdoering
Stop X-bar/R Madness!!
You might have had some SPC training in the past, but it probably skipped over the correct steps to implement charting on the shop floor. Check it out, here they are:
1. Develop the total variance equation (Yes! This is the very first step!)
2. Determine which variance factors are adjustable, which are noise, and which can be set as a constant.
3. Minimize the variation of each of the participating variables - get the process in a steady state and capable. This includes eliminating your "special causes".
4. Accurately determine the correct distribution of each of the remaining variances
5. Determine which of the remaining variance factors you are going to chart
6. Pick the correct chart to evaluate that variance factor (variable)
Did anyone share that with you in your SPC training? If not...you missed out on the important stuff...
Don't feel bad, it's common.:tg:
Sturmkind
Bob;
I have to hand it to you, you always get me to think! Thanks! A terrific addition to the steps you stepped out was the additional questions asked by Dorian Shainin: Is the primary variance within part, part-to-part, or lot-to-lot! Thanks again for the post!
bobdoering
One of the points I have made elsewhere in the cove that shows the importance of the Total Variance Equation is that it is the true origin of 6 Sigma. Sigma - the standard deviation - is the square root of the variance. So, therefore, the square root of the sum of all of the variances shows the critical importance of knowing what the factors of variance are to the proper implementation of the 6 Sigma tools. I bet you rarely see that in 6 Sigma training!
Whats more, it shows that virtually all processes are multi-modal - unless you can eliminate or make statistically significant ALL (or all but one) of the total variance factors! Unfortunately, the ones usually not minimized (and therefore masking all others) - is measurement and gage errors. They are typically normal, giving the false facade that the underlying process is, too - and that all of the normal statistics apply.
bobdoering
Erick Mirabel;bt756 said:
Hi Bob,
Can you share one particular example? To enlighten me more.. Hope you can...thanks!
Good idea. It will take some time to put an example together, but I will do that and add it to the blogs.
bobdoering
ISO-9001-2008 is a generic quality system specification, where TS 16949 is specifically for the automotive industry.
G
Guest
understand that, our company is looking into TS 16949. Guess what I wanted to ask was, how much of an upgrading do we need to do to pass/get certified TS 16949?
bobdoering
The move from ISO9001 to TS 16949 is very significant, with much more documentation overhead, and many more customer specific requirements no even listed in the requirements. It is extremely comprehensive, and will take much more resources to implement and maintain. Only do it if you are required to. You may want to get a gap analysis before deciding to dive in.
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
R What is the correct way to refer to NIST? Calibration Frequency (Interval) 4
M NANDO codes of products - These are not the GMDN codes, correct? EU Medical Device Regulations 4
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
JoshuaFroud How important is using the "correct" GMDN? Other Medical Device Regulations World-Wide 14
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
P The correct way to do a Linearity and Stability Study on a Critical Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
A Safety Shoes & Temporary Workers - Is it correct to reuse again or not? Occupational Health & Safety Management Standards 11
S Definition MTBF and MCBF Correct Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
T What is the correct UMDNS Code for Tracheostomy Tube? Other Medical Device Regulations World-Wide 2
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
D The correct way to analyze Skewed Data using Minitab Using Minitab Software 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
E Database search is correct to capture medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J TS 16949 - Which definition of Automotive is correct? IATF 16949 - Automotive Quality Systems Standard 3
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Correct Cable Ports After Work and Weekend Discussion Topics 2
S Is it gramatically correct to say Singapore people or Singaporeans ? Coffee Break and Water Cooler Discussions 12
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K AS9102 Form 3 for Assemblies - Verification that the Assembly is Correct AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J MSA Emergency - PV%=100(PV/TOL)in American? And that is correct? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
J Are my Cpk and Cp Calculations Correct? Capability, Accuracy and Stability - Processes, Machines, etc. 4
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
T Correct use of NPT (National Pipe Thread) Thread Gages General Measurement Device and Calibration Topics 15
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
C Correct Tool for Gage R&R - Assay Dilutions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B How to Correct Bad Employee Performance-Attendance and/or Tardiness Quality Manager and Management Related Issues 84
R How to determine the correct Sample Frequency for SPC Features Statistical Analysis Tools, Techniques and SPC 66
Q Latest ISO 9001:2008 Rev. E - Correct? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Orthographic Projection - Which view is correct? Coffee Break and Water Cooler Discussions 4
