The correct way to do a Linearity and Stability Study on a Critical Dimension
P
Priss80
The customer request to conduct bias, linearity and stability for the special characteristic. I conduct bias, linearity and stability study by using production part. I use the part as master and pick 3 measurement as master and periodically measure the same part and compare to the master. Is this the correct way i conduct the study? Some of the people buy a master block to conduct the study which to me is not measuring to the customer special characteristic. Use production part or master block is more appropriate? If we use master block we will add calibration cost, isn't it?
Please help i am a bit confuse :confused:
t.PoN
Re: Linearity and stability Study
Using the production part:
How do you its true value or reference value?
if you have a good source for estimating the reference value of your production part, then I think its ok to use it!
P
Priss80
The referance value is measured by more than one same type of calibrated measuring equipment to confirm part dimension is correct.
t.PoN
As long as you have traceability of your measurment then I can't find a reason why not!
Your uncertainity will increase but that's all
t.PoN
I just want to add this:
Make sure that you the goal of study is clearly defined!
i say this because re-reading your post I was not sure if you are having the study for your measurment method or your products!
if the goal is the bias of the measurment method then using master block or tracebale product part is ok
but if the goal is to measure the stability of your production, the you should conduct the measurment using your product part not your master block! your master block can be used to determine the bias for the method in this case
P
Priss80
Referring to the aiag MSA manual, only mention to take from production part. Can I understand that the manual is considering to measure the product stability instead of equipment or method?
t.PoN
The MSA is targeting the industrial world.
The measurement system is usually inetrrupted as the production process as you can see in the attached image.
but yes, the MSA usually talks about the stability of your production process (including the equipment used to manfacture the products).
It can be used as well to measure the stability of your actual measurment/test/analysis method (including the equipment used to capture the data (such as a caliper).
I think your customer is intersted in your production and not your measurment/analysis method.
smkeilman
I think you may be misinterpreting what is being asked. The bias and linearity are more associated with measurement system analysis than manufacturing process analysis. Stability could apply to either. If you're being asked for a straight MSA on this characteristic, then the only relevance to the production part is on WHICH measurement system you choose. The MSA is performed on the measurement system in a vacuum, not the production process.
P
Priss80
For stability study, i use production part to perform MSA, i need to identify the specification of the characteristic but what is the tolerance i should put? exm: 2.50+/-__?__
If i use master block to perform stability, what should the specification be?:thanx:
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
R What is the correct way to refer to NIST? Calibration Frequency (Interval) 4
M NANDO codes of products - These are not the GMDN codes, correct? EU Medical Device Regulations 4
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
JoshuaFroud How important is using the "correct" GMDN? Other Medical Device Regulations World-Wide 14
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
A Safety Shoes & Temporary Workers - Is it correct to reuse again or not? Occupational Health & Safety Management Standards 11
S Definition MTBF and MCBF Correct Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
T What is the correct UMDNS Code for Tracheostomy Tube? Other Medical Device Regulations World-Wide 2
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
D The correct way to analyze Skewed Data using Minitab Using Minitab Software 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
E Database search is correct to capture medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J TS 16949 - Which definition of Automotive is correct? IATF 16949 - Automotive Quality Systems Standard 3
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Correct Cable Ports After Work and Weekend Discussion Topics 2
S Is it gramatically correct to say Singapore people or Singaporeans ? Coffee Break and Water Cooler Discussions 12
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K AS9102 Form 3 for Assemblies - Verification that the Assembly is Correct AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J MSA Emergency - PV%=100(PV/TOL)in American? And that is correct? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
J Are my Cpk and Cp Calculations Correct? Capability, Accuracy and Stability - Processes, Machines, etc. 4
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
T Correct use of NPT (National Pipe Thread) Thread Gages General Measurement Device and Calibration Topics 15
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
C Correct Tool for Gage R&R - Assay Dilutions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B How to Correct Bad Employee Performance-Attendance and/or Tardiness Quality Manager and Management Related Issues 84
R How to determine the correct Sample Frequency for SPC Features Statistical Analysis Tools, Techniques and SPC 66
Q Latest ISO 9001:2008 Rev. E - Correct? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
bobdoering The CORRECT steps to implement an SPC chart Imported Legacy Blogs 16
E Orthographic Projection - Which view is correct? Coffee Break and Water Cooler Discussions 4
