The difference between ?Aircraft Return to Service? and ?Aircraft Airworthiness"
U
usa2000
The difference between “Aircraft Return to Service” and “Aircraft Airworthiness"
Hi guys,
What the difference between “aircraft return to service” and “aircraft airworthiness release” after accomplishment of maintenance or inspection work?
thanks
Stijloor
Re: The difference between “Aircraft Return to Service” and “Aircraft Airworthiness"
Can someone help with this?
Thank you very much!
Stijloor.
In our business, we return articles to service using an authorized release certificate, FAA Form 8130-3. The 8130-3 form is also commonly referred to as a "return to service tag".
Chaz243
Stijloor.
You must make a determination of "Airworthiness' before you can issue a "Return to Service"... A return to service insinuates that the article has been removed from service for maintenance, cycle limits or due to deficiencies such as damage.
For example: A part is inspected and determined to be airworthy by a properly certificated repair station. The repair station then issues a "Return to Service" for that part. The part can now be installed on an aircraft.
Keep in mind that the return to service is only valid for the work accomplished by the repair station as requested on the customers work order. There may be discrepancies that are unrelated to the specific inspection that was accomplished, but the part is airworthy. Something else that MUST be taken into consideration is if there are any outstanding airworthiness directives issued to the specific part.
I hope this helps,
Charlie
M Difference between Component Maintenance and Aircraft Maintenance Manual (CMM/AMM) Federal Aviation Administration (FAA) Standards and Requirements 2
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 2
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
G What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 5
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 2
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 5
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
Q What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
A Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
A ISO 9001:2015 - The difference between 6.1.1b and 6.1.1d - IMHO, d) implies b) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Difference between requirement for 4.4.1a (inputs) and 4.4.1d (resources needed)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R The difference between Feasibility Assessment and Contract Review Contract Review Process 2
V Difference between Non-Conformance, Variance and Deviation ISO 13485:2016 - Medical Device Quality Management Systems 7
A Difference between Environmental Impact and Risk ISO 14001:2015 Specific Discussions 7
