The difference between SOP and Kaizen Standardization
Hello Guys;
I would like to ask about the difference between SOP and Kaizen standardization, and is it important to replace or gather SOPs & standardization in one place (eg. Warehouse), and is there a template or a structure to use Kaizen standardization?
Jen Kirley
Quality and Auditing Expert
Hello Guys;
Welcome to the Cove! :bigwave:
Given that Kaizen is a Japanese philosophy that focuses on continual improvement throughout all aspects of life, it does not seem it is one and the same as SOPs. SOPs can be a means to accomplish Kaizen; they just are not interchangeable. Nor would I want to standardize Kaizen; I would not want to limit myself to a set of methods because one approach does not suit all.
Kaizen (and 5S) is often used incorrectly to describe Lean. The terms are not synonymous. Kaizen and 5S are methodology elements within Lean.
I suspect that TarKEpa means “Standard Work” because of his reference to SOPs and “standardization”. Standard Work is often incorrectly confused with standardization. Again standardization is an element of Standard Work. Standard Work is a means of highly specifying the sequence, timing and outcome of any ‘operation’. It is not an SOP or Work instruction in the traditional sense, although it is often - but not always - captured on a SINGLE piece of paper and posted at the workstation. When posted, it is not for the employee but for the supervisor to ensure that work is done in accordance to the Standard Work. When posted, it contains very few words; it I dominated by pictures. In high speed operations such as automotive assembly lines where the ‘operations’ take ~60 seconds there is no ‘documented standard work as that would be excessive documentation. The work area is set up such that any deviation from the standard work will be immediately obvious to everyone. When we incorporate Kaizen we are continually improving the process which would make ‘keeping up’ the documention is very onerous. So standard work can and should replace work instructions but it is not a documentation exercise. Review, approval and ‘gathering’ is not done.
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
P Whats the difference between SOP and QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
R The difference between Deviation and Failure - Creating an SOP to handle them Food Safety - ISO 22000, HACCP (21 CFR 120) 24
S Difference between Control Plan and SOP (Standard Operating Procedure) Document Control Systems, Procedures, Forms and Templates 6
B What is the difference between SOP's, processes & procedures? Document Control Systems, Procedures, Forms and Templates 11
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
