The Elsmar Cove Wiki Questions Discussion Thread
Marc
#32
That's it:
Code:
http://Elsmar.com/Forums/search.php?do=process&titleonly=1&query=quality+manual
As you can see, add &titleonly=1 to the query string. I'm not sure sequence is important, but it may be.
I
isoreader - 2006
#33
akehrer said:
That's true. I had the issue come up when I wanted to do the pmf for the Binomial Distribution and couldn't represent the combinatorial. I still think having LaTex avaliable would be good.
Aaron
OK you may be right. But I suggest Marc have a good look at the pros and cons against the effort put in to install LaTex (and likely maintenance). At least have a good look at the current bug list (I presume there is one).;)
Scott Catron
True Artisan
#34
discovered templates
I wanted to increase the size of the alphabetical index that's on the main page and the top of each 'letter' page. (I have sometimes hit the wrong letter because they were pretty small - no, I was never very good a video games, either) I found a way to do that, but then I had 27 pages to change.
I thought there had to be a better way - and there is - Templates! Templates are an easy way to put the same content across many pages.
Here's how they work, make a page called [[Template:name]] where 'name' is the name of the template you want to make. On this page, make whatever it is you want to repeat. Then, after saving the page, the wiki markup for a template is {{name}} - this will insert the content that is at [[Template:name]].
So I've made a template for the alphabetical index: [[Template:Indexalpha]], pasted in the larger index mark-up, then I still had to insert {{Indexalpha}} into 27 pages, but if we ever want to change the format of the index, we onlyl have to modify the Template page and it will propigate to wherever {{Indexalpha}} is on a page.
Scott Catron
True Artisan
#36
Kyle Hamar posted the following to my talk page at the wiki. I thought it was a good question and that we all should hash it out.
"Where do you see the wiki needing priority attention? Do we have a set of guidelines or other framework to follow for structure?"
I've been thinking about this also and was wondering if we should develop a 'to-do' list for everyone to work off of.
Here's what I see as priorities:
1. Formatting the glossary pages so that they have a consistent look.
Using Abilene Paradox as an example, at the glossary level, there is the term itself which links to a page for the topic. Terms with pages are blue, those without are red. We need to get rid of the red links.
After the term is a one-sentence summary. Anything more should be on the page. If there's not a lot more, that's fine, but we should have something for each term so that the glossary pages all look the same.
2. From there, we should expand the pages to include other pages to help explain each term. Taking Abilene Paradox as an example again, on the page are also red and blue links that are not in the glossary, but help explain Abilene Paradox (Paradox and Groupthink in this case). Whether we want to include them in the glossary is up for debate, but it adds to the wiki when concepts are explained.
3. A good-looking main page. I've been working on it (increase size of glossary strip, adding to the 'Do you know' section) but my wiki-fu hasn't progressed to using nice-looking tables and other fancy formatting. I can fake it enough by copying what others have done.
Anyway, that's my two cents. We need input from others and then Marc can define some guidelines or prioritize a to-do list.
Scott
Marc
#37
That sounds good to me.
I plead guilty to falling behind on the wiki. I got busy here and have to dedicate a few days to it.
As to the tables and such, that's how I have been learning stuff other than what you have pointed out - Looking at the code in other wikis.
I
isoreader - 2006
#38
Judging by the last sentence of your point number 1, the higher priority is not the "look" but the content. To this I would agree.
However as far as the "look" goes, my suggestion is to remove all the Blue or Red linking from the main glossary word and simply have them as Black Bold. For those words with more information and with its own page, change the link in the index with a substitute word(s) such as "More..." eg.
Acceptable Quality Level - aka AQL - The maximum percentage or proportion of non-conformities in a lot or batch that can be considered satisfactory as a process average. More...
If this is "more" acceptable then lets hear it and we can work on changing it.
Scott Catron
True Artisan
#39
I'm not sure this is the best way to go. The more our format matches well-established wikis (such as Wikipedia) the more accessible it will be for users.
There's no reason we cannot expand upon any of the terms in the glossary - even a little bit - so that each term has a page of its own. Seeing red links will motivate editors to create pages.
I'm also worried about 'definition creep' if we switch to the format you suggest, folks may just start adding to the definition without an easy way to get to a page for it and glossary pages will start to bloat.
It just seems like there would be less maintenance or administration involved if we keep it the way it is for now.
Anyway, just my thoughts, Marc can make the call.
Marc
#40
I really want the words to be links rather than just bold black text. In part I'm looking at this from an SEO position. The page title (such as Gage_R&R) generated when a word changes to blue plays a good role in search engine relevance.
When this was started it was a raw list with brief definitions, which is fine. But I would like the raw word to link to its own page where we can address details. If you use 'More...' search engine relevance due to the page title is lost.
Last night I started a reply to Scott's post 36 above but my friend stopped by and I never sent the reply (forgot and closed browser after talking for an hour or so...) What I was thinking of is sub-page 'outline' structure such as a procedure has.
I was thinking something like:
===Definition===
===Links to Forum Discussion Threads===
===Links to External Web Pages===
----> Last night I had some better details as I had thought this out a bit (too bad I screwed up and forgot to send what I'd written). I'll try to focus on it again, but this should help relaying the idea.
Scott Catron Elsmar Cove Quality Assurance BOK (Body of Knowledge) Wiki Forum News and General Information 82
Marc GDPR - EU Directive 2016/679 and the Elsmar Cove Discussion Forum Elsmar Cove Forum ToS and Forum Policies 3
N When they make the movie " Elsmar Cove " .... After Work and Weekend Discussion Topics 17
BradM Why I am so appreciative of the Elsmar Cove Coffee Break and Water Cooler Discussions 7
Marc Plagiarism in Elsmar Cove Forum Posts Elsmar Cove Forum ToS and Forum Policies 0
M Thank you Marc and the Elsmar Cove Moderators and Members! Coffee Break and Water Cooler Discussions 10
BradM The Greatness of Elsmar Cove Coffee Break and Water Cooler Discussions 1
B Any forum at par with Elsmar Cove for Network and System Administration? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
somashekar Father of Elsmar Cove hits second SILVER Covegratulations 16
N Elsmar Cove Forum - What an amazing place Coffee Break and Water Cooler Discussions 8
K Is reading the Elsmar Cove a legitimate work related activity Coffee Break and Water Cooler Discussions 19
somashekar ~~ The Elsmar Cove Birthday - Online for 17 years! ~~ Covegratulations 16
Richard Regalado Elsmar Cove BCP - Continuity of the forum when disaster strikes Business Continuity & Resiliency Planning (BCRP) 11
H Happy Birthday to the Elsmar Cove Forum - January 2012 Covegratulations 25
harrysons Thanks to Elsmar Cove - Successful TS16949:2009 Certification Covegratulations 10
BradM Happy Birthday Elsmar Cove!! 15 Years old Covegratulations 44
G What should an Elsmar Cove X-mas tree look like? Coffee Break and Water Cooler Discussions 1
J What Has The Elsmar Cove Done For You?? Coffee Break and Water Cooler Discussions 30
H Elsmar Cove Statistics Found Online Coffee Break and Water Cooler Discussions 2
S Quality Policy - What is the Elsmar Cove's Quality Policy? Elsmar Cove Forum ToS and Forum Policies 8
P What is the meaning of your Elsmar Cove Forum User Name? Coffee Break and Water Cooler Discussions 58
B In terms of age, who are the youngest and oldest Elsmar Cove forum members? Coffee Break and Water Cooler Discussions 112
somashekar Elsmar Cove reference in your CV 's ... Coffee Break and Water Cooler Discussions 8
N Cabot Cove vs. Elsmar Cove Coffee Break and Water Cooler Discussions 7
Marc Privacy - Elsmar Cove Privacy Policy and Statement Elsmar Cove Forum ToS and Forum Policies 0
Marc Privacy Policy - Elsmar Cove Privacy (and Cookie) Policy - 090405 Elsmar Cove Forum ToS and Forum Policies 4
ScottK Elsmar Cove iPhone users After Work and Weekend Discussion Topics 39
BradM The Elsmar Cove Coffee Shop Coffee Break and Water Cooler Discussions 359
Coury Ferguson Happy Birthday Elsmar Cove - 13 years online Coffee Break and Water Cooler Discussions 19
Marc General Elsmar Cove Forum Participation Rules and Guidelines Elsmar Cove Forum ToS and Forum Policies 22
Marc Your Opinions and thoughts about the Elsmar Cove forum - Why do you visit the forum? Forum News and General Information 50
D ASQ Members in Elsmar Cove ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 64
Marc Elsmar Cove 'Sparklers' Coffee Break and Water Cooler Discussions 24
hogheavenfarm LinkedIn users-Elsmar Cove Group formed Coffee Break and Water Cooler Discussions 37
Marc If the Elsmar Cove Forums and Web Site was Yours, What would you do to Improve? Forum News and General Information 59
Paul Simpson Would the Elsmar Cove be on your CV / Resume? Career and Occupation Discussions 26
B Elsmar Cove Forum Graphics Coffee Break and Water Cooler Discussions 5
RoxaneB Elsmar Cove Sparklers - A Free Wellness and Healthy Lifestyle Resource Coffee Break and Water Cooler Discussions 5
E Memorable moments on the ELSMAR COVE Coffee Break and Water Cooler Discussions 45
J Would you recommend the Elsmar Cove to your Certification Body (CB) auditor? Career and Occupation Discussions 35
Ajit Basrur The number of ISO13485 posts in the Elsmar Cove forums ISO 13485:2016 - Medical Device Quality Management Systems 12
Ajit Basrur Starting the Elsmar Cove - The Elsmar Cove Forum History Forum News and General Information 2
Marc Elsmar Cove Forums Link Listed in Wikipedia.org Coffee Break and Water Cooler Discussions 6
Tim Folkerts Elsmar Cove Anagrams Coffee Break and Water Cooler Discussions 44
W Is a reading room a good idea for the Elsmar Cove? The Reading Room 40
D Is there is a forum like The Elsmar Cove for AS9100? Book, Video, Blog and Web Site Reviews and Recommendations 2
Marc TOS (Terms of Service) - Elsmar Cove Forum Registration and Use TOS Elsmar Cove Forum ToS and Forum Policies 2
Marc Quality Digest 2004 Salary Survey - Yearly Elsmar Cove Poll - Where do YOU stand? Career and Occupation Discussions 17
Wes Bucey Attitudes and Intimidation in Elsmar Cove forum Posts Elsmar Cove Forum ToS and Forum Policies 62
Marc Elsmar Cove Members who are Training Providers Training - Internal, External, Online and Distance Learning 40
