The impact of laser power on biocompatibility of the products
Judy Abbott
Good day,
To improve the bond strength of a welded joint between a Pt (90%)/Ir (10%) coil with 304 SS wire, the manufacturer increased the laser power. Now they are seeing discoloration and rust at the joint. What is this discoloration? How can it impact the biocompatibility of the guidewire? How can I mitigate the risk associated with this change? Thanks for sharing your ideas in advance!
How could this be rust?
Is this device commercially distributed? If so, your change control process needs improvement.
Have you done testing to confirm that the bond strength in fact increases with this change?
What does your risk management documentation say about this risks associated with laser energy being to high?
Judy Abbott
Thanks! This change is not part of the manufacturing line yet. The impact of all the proposed changes has to be assessed before applying the change.R&D is testing the increase of the laser energy at this stage and they just wanted to know what is a good explanation of this discoloration and how it impacts the biocompatibility.
Well that is a relief. This could be soot or discoloration due to heat. As for biocomp, I can't really answer that because I don't know much about those materials. Sorry.
planB
Judy,
the discoloriosation could be attributed to physical and/or chemical modifications at the laser joint. EDX and SEM could provide you with a first clue what is happening at the welded joint. In case this is a pure surface phenomenon, an additional grinding/polishing step might address this issue.
In term of biocompatibility, you may want to re-investigate your inorganic leachables and extractables profile (e.g. via ICP) commensurate to nature of body contact of the affected component, and confirm that you do not introduce any new biological hazards. In case you introduce new manufacturing steps (grinding/polishing), you may want to consider the impact of these (new/changed) processes experimentally as well according to ISO 10993-18.
Hope this helps,
Judy Abbott
Judy,
Hope this helps,
Thanks a lot for your advice! That would be my starting point.
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
S Impact to clinical evaluation of MDCG2022-14 EU Medical Device Regulations 2
S Changing PCB Assembler and impact on QMS and MDD CE Certificate EU Medical Device Regulations 2
J Impact Testing--Is conversion between Izod and Sharpy Possible? General Measurement Device and Calibration Topics 3
A SaaS SaMD - Impact QMS ISO 13485:2016 - Medical Device Quality Management Systems 2
I Work Instruction Update- IATF Impact IATF 16949 - Automotive Quality Systems Standard 6
Edward Reesor Impact of Health Canada Summary Reports Canada Medical Device Regulations 4
S MDD to MDR - Tallow Derivatives Impact EU Medical Device Regulations 1
N EU MDR and its impact on existing Registrations EU Medical Device Regulations 1
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
L Impact on 510(k) to use an additional manufacture US Food and Drug Administration (FDA) 0
R Impact of changing manufacturer post clinical investigation CE Marking (Conformité Européene) / CB Scheme 3
Ed Panek Corona Virus impact on Supplier Audits and Received Parts ISO 13485:2016 - Medical Device Quality Management Systems 4
F Will the EU postpone 2017/745 MDR Implementation - COVID-19 Impact Medical Device and FDA Regulations and Standards News 11
R Revalidation machine line and Stability Studies impact. Medical Device and FDA Regulations and Standards News 3
M MDR Impact on MDSAP Countries Other Medical Device Regulations World-Wide 16
Watchcat Impact of MDR on Availability of Medical Devices in EU EU Medical Device Regulations 5
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
G Is impact test according to IEC 60601-1 applicable for HAND-HELD equipment if also classified as BODY-WORN? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A IEC 60601-1 Impact test on glass touch controller IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
qualprod The Perfect audit? External Audit causes a significant negative impact in a company General Auditing Discussions 9
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E MDR Article 117 / Impact to New Marketing Authorization Applications Other Medical Device Regulations World-Wide 1
C Lithium battery powered Medical Device - 15.3.3 Impact test, broken enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Impact of an MDSAP certificate with all countries coverage Other Medical Device Regulations World-Wide 8
Edward Reesor Canadian News article on impact of MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 10
qualprod Propose Aspects to evaluate risk impact? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
qualprod Risk impact can be modified? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Brexit - European Commission - The impact of the Brexit per March 29, 2019 EU Medical Device Regulations 3
B The impact of IoT in ISO documentation IT (Information Technology) Service Management 1
J Business Impact Analysis SOP Business Continuity & Resiliency Planning (BCRP) 2
T GDPR impact on ISO 9001 and Quality ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Raffy What is the first step in doing PIA (Privacy Impact Assessment)? IEC 27001 - Information Security Management Systems (ISMS) 3
Sidney Vianna IATF 16949 Areas of Impact - Rules 5th Edition Document (February 2017) IATF 16949 - Automotive Quality Systems Standard 0
I Biocompatibility Impact on Autoclaved Silicone Other Medical Device Related Standards 3
R Tensile Test Strain Rate - Impact on the Test Results Manufacturing and Related Processes 3
K Thoughts on the impact of the General Data Protection Regulation? Medical Information Technology, Medical Software and Health Informatics 5
Q Risk Impact - Risk Assessment Sample/Method per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Difference between Environmental Impact and Risk ISO 14001:2015 Specific Discussions 7
M 15.3.3 Ball Impact Test requirements in IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Charpy impact test - Mill cert for API 13CrL80 coupling stock material with is PLS 2 Oil and Gas Industry Standards and Regulations 1
K TS 16949 Planning Phase: Raw Materials purchased from Distributer and the PPAP impact IATF 16949 - Automotive Quality Systems Standard 3
A Product Impact When Thread Rings Require Adjustment General Measurement Device and Calibration Topics 9
Marc What companies think climate change will have a material impact on their business? Sustainability, Green Initiatives and Ecology 38
K IEC 60601-1:2012 - Impact Assessment for changes from IEC 60601-1:2005 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
K Business Impact Analysis Questionnaire - Financial Implications Business Continuity & Resiliency Planning (BCRP) 1
Howard Atkins Rules 4th Edition Areas of Impact for Client Consideration IATF 16949 - Automotive Quality Systems Standard 1
S Exploring the Impact of Changes in ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
Q Complete Company Restructuring & Impact on ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
