The Implications of ISO9001 - Quality Improvements vs. Customer Pressure
Jackie Eeles
I am interested in whether the implications of ISO9000 registration differ between companies who seek quality improvements as opposed to those under pressure from customers to attain registration.
I would be grateful for any comments about this subject.
Jackie Eeles
Don Winton
Here are my thoughts.
ANY registration should be a portion of a continuous improvement effort. Registration, in and of itself, does not improve a organizations’ position.
...as opposed to those under pressure from customers to attain registration.
There is a distinct difference between ISO registered and ISO compliant.
I know folks, that you cannot become ISO compliant, just shorthand for here.
Regards,
Don
I think this is pretty self evident - if you force a company to comply, the compliance will typically not be 'significan't - the tenor of the company in general typically will not change. I say 'typically', because some companies do 'get the idea'.
Companies seeking better quality, whether thru ISO9000 or other tools and/or philosophies like TQM are on the track anyway.
Ask your self:
What's the difference between a person (or company) being forced as opposed to a person who wants to do something which is not necessarily popular.
Don stated it well - that latter company (does it to improve) has a philosophy of continuous improvement.
Kevin Mader
One of THE Original Covers!
Jackie,
I believe that if you are pressured, you are less likely to embrace the positive benefits ISO can bring. When mandated by the Customer, the suggestion is that you are not running your company well. So if you get ISO Registered, then everything will be fine. Pure imagination.
Organizations who embrace the positive aspects of ISO (as well stated by both Marc and Don) are interested in doing things better and are on the Continuous Improvement course. For that matter, ISO Registration becomes an ancillary benefit since the goal they seek is much higher than that of a documented QS.
Just some of my thoughts. Back to the group...
[This message has been edited by Kevin Mader (edited 04-12-99).]
Don Winton
…because some companies do 'get the idea'.
This is too often rare. Take the QS 9000 mess. Companies are forced to become registered to QS 9000 to supply that market. But, what percentage actually become registered to improve its position and what percentage become registered because they are under pressure from customers to attain registration. I suspect the latter is much higher.
Sadly, true. With much good stuff in the ‘quality model’ that is ISO 900x, why is so much of its potential ignored? Because organizations fail to see it as a model, they see it as a solution. Bull!
Agreed, pure imagination indeed.
Yea, sorta like the icing on the cake.
Just the ramblings of an Old Wizard Warrior.
Regards,
Don
Christian Lupo
Here's another perspective on the QS-9000 mess, key word being "another" and not necessarily "right" or "good"
It's a lot harder to "fake" Qs-9000 registration than it is to "fake" ISO -9001 registration. By "fake" I mean instituting a quality add-on just to get a certificate. Unlike ISO, QS requires the use of FMEA, control plans, documented continuous improvement, and SPC. There is no doubt in my mind that if QS didn't require (FMEA, SPC, CI, etc..) we (an ISO certified company) would not have them. You can still fake these initiatives, but it soon becomes apparent that you are spending just as much time faking these programs than you would if you gave them due diligence. I will admit that being forced to have them is not the ideal situation, but if we were not forced to institute these programs, they would never be implemented. At first (FMEA, SPC, CI, etc..) these programs were token, but they are now proving their worth. In addition, these programs keep me employed. I'm convinced that a lot of companies would have QC based quality systems if they were not forced by ISO/QS. I bet there's a lot of other quality professionals who are glad companies are forced to get ISO or QS.
Maybe a topic for another forum, but good auditors should be able to distinguish the difference between a good quality system and a fake quality system. IMHO auditors should concentrate on the root cause of the problem: commitment to quality by management. I haven't met too many quality mangers who want (or institute) a fake quality system. Inadequate quality systems are usually the result of the limitations placed on the quality system by the decision makers.
Kevin Mader
Christian,
Sadly you are right. Too bad. ISO has become transparent. Registrars out for the bucks destroyed a good concept.
Regards,
Kevin
Don Winton
Christian,
Good thoughts. I like ‘em.
As far as ‘mess’ goes, my only thought was to illustrate the difference between voluntary compliance and non-voluntary compliance.
It's a lot harder to "fake" QS-9000 registration than it is to "fake" ISO-9001 registration.
Under the assumption that companies are trying to ‘fake’ registration (there are a lot of ‘em out there), this statement is true. As more opportunities for failure are available, the law (statistics) states that the probability of noncompliance is higher.
I would (have?) considered these programs not token at all, unless the company implementing them thought them as such. I have always found them to be of extreme value (My FMEA course was late 70’s or early 80’s vintage. Cannot remember which. 60’S left overs).
... but good auditors should be able to distinguish the difference between a good quality system and a fake quality system.
Christian, agreed, in part. But, as an assessor (not an auditor), my function is two-fold. Am I assessing against a standard or am I assessing against the company’s readiness? If I am assessing against a standard, my function is to determine compliance (not noncompliance) against that standard ONLY. If my function is to determine a company’s readiness, THEN it is my place to determine their conformance to expectations. The difference between the ‘letter of the law’ versus the ‘intent of the law,’ so to speak. If an organization asks me to assess against ISO 900x, then my function is to determine if they are in compliance, not to determine if they are ready for the next level.
...auditors should concentrate on the root cause of the problem: commitment to quality by management.
I disagree here. An assessor’s job is to determine compliance within the scope of the audit, no more, no less. Root cause analysis is not an assessor’s function. The scope is the key. If the client requests additional details as to readiness, then that is outside the scope of the assessment, which may, or may not, constitute a conflict of interest. Perhaps I am wrong!
Kevin, I agree in part. I see and hear all the time of things that registrars should or should not do this or that. But, I would hesitate to clump them all in one bunch. As anyone who have read my writings know, I have no (none) love for the current process, but it is all we have (and I definetly do not like the RAB set-up). I would LOVE to see a system that regulated all registrars against some set of metrics that would level the playing field, so to speak.
Any volunteers?
Kevin Mader
Don,
I'm sitting on my hands. Just to clarify, I did not mean to suggest that all Registrars are guilty, or share equal guilt, in letting the standard become transparent. I was making reference to the group who place $$ in front of the good of what the standard represents. I guess you could say that all things are likely to experience fallout of this sort, so realistically, none of us should be surprized. Still, my optimistic indifference can occasionally be replaced by my pessimistic cynacism.
Don Winton
Why? All opinions welcome.
Yea, I see your point. I have no love for the current registration process in general and the RAB in particular. The registration process has been bastardized into a money making machine, in which, IMHO, the RAB shares blame (key word share). When I first started the ISO thing (circa 1991), it was OK, but now I am completely skeptical about it. Too old and too many years, I am afraid.
Good. It is well to have balance.
Regards,
Don
