The ISO 9001:2008 addendum - What would you like to add or subtract?
  • I wanna add new clause(s) on .......
    Votes: 2 14.3%
  • Subtract clause or sub clause....
    Votes: 5 35.7%
  • I don't know yet
    Votes: 9 64.3%
  • Total voters
    14
#41
clause 7.4.1 states "The organization shall ensure that purchased product conforms to specified purchase requirements"
clause 7.4.3 states " The organization shall establish and implement the inspection or other activities necessary for ensuring that purchased product meets specified purchase requirements"
correct me if I am wrong but does this not say the same? One or the other but unnecessary to state both.
Dave
C'mon, Dave, they're clearly different. 7.4.3 has more words. :read:
Paul Simpson
#45
Dave
The clauses cover some of the same ground but they are not the same in any way. Taking a simple example:
7.4.1 says the organization designs its systems to ensure the product it buys in meets its needs. That includes suplplier selection, purchasing processes and verification of the product (from 7.4.3). If the organization decides in 7.4.1 that it only buys from registered firms, only buys against a specification and monitors in house rejects then it could decide (in 7.4.3) that there is no need for incoming inspection.
Pretty much all the clauses are there for a purpose. We could all argue about the way the standard is put together (have a look at other threads for examples of how some Covers dislike the existing structure - and others defend it)
#46
:confused:
But that doesn't mean that the purpose makes sense.
Do you mean that we shouldn't want to improve it, or that it's beyond the abilities of mere mortals to make it better?
Look at it in terms of objective evidence. If 7.4.3 weren't there, would you audit any differently?
Sidney Vianna
Post Responsibly
#47
The WD2 of ISO9001:2009 states:
7.4.1 Purchasing process
Where purchased product has an effect on conformity to final product requirements, The organization shall ensure that purchased product conforms to specified purchase requirements. The type and extent of control including the selection and evaluation applied to the supplier and the purchased product shall be dependent upon the effect of the purchased product on subsequent product realization or the final product.
To the extent applicable to the purchased product, The organization shall evaluate and select suppliers based on their ability to supply product in accordance with the organization‘s requirements. Criteria for selection, evaluation and re-evaluation shall be established. Records of the results of evaluations and any necessary actions arising from the evaluation shall be maintained (see 4.2.4).
a) evaluate and select suppliers based on their ability to supply product in accordance with the organization‘s requirements
b) establish criteria for selection, evaluation and re-evaluation
c) maintain records of the results of evaluations and any necessary actions arising from the evaluation (see 4.2.1 e).
7.4.2 Purchasing information
Purchasing information shall describe the product to be purchased, including where appropriate
a) requirements for approval of product, procedures, processes and equipment,
b) requirements for qualification of personnel, and
c) quality management system requirements.
The organization shall ensure the adequacy of specified purchase requirements prior to their communication to the supplier.
7.4.3 Verification of purchased product
The organization shall establish and implement the inspection or other activities necessary for ensuring that purchased product meets specified purchase requirements.
Where the organization or its customer intends to perform verification at the supplier‘s premises, the organization shall state the intended verification arrangements and method of product release in the purchasing information.
Peter Fraser
#48
Paul
Some might argue that "shall establish and implement the inspection ... activities necessary..." (7.4.3) implies that there is a need for such activities. "Any necessary actions" is commonly used elsewhere, which gives the user some discretion.
Peter Fraser
#49
Anyone prepared to say what this means? Is it something to do with the QS of the supplier, or some (unspecified) requirement of the organisation's QS, or ...? Should it not be more specific?
Sidney Vianna
Post Responsibly
#50
This requirement has been there for a long time. Some regulatory issues might force quality system requirements. Example several of the CE-Mark related European Directives.
Another example, a supplier outsourcing a heat treat process to require the supplier to be NADCAP accredited.
Another example yet, a purchaser of calibration services might require their lab to be ISO 17025 compliant.
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
