Greenraisin said:
I have really gotten a lot out of this forum and all of you who participate. I was curious, though, who all of you are and what you do. How about letting us know a little bit about you and your background?
1. Name
2. Job Title or explanation of what you do
3. Industry you're in or have been in
4. Company you work for and location
5. Length of time in quality function
6. Something personal that sets you apart
7. Your pet peeve in quality
8. If you could change the world of quality, what would you do?
1. Greg Carnahan
2. Sr. Quality Engineer - Primary responsibility is for QMS setup & operations. Previously been QA Engineer, Quality Systems Mgr, QS 9000 Coordinator, Sample Coordinator, Cost Estimator.
3. Automotive Supplier - Have worked with Gray Iron, machining, fiberglass, heat treat, molded rubber for vibration control, HVAC tubing fabrication, metal stamping, welding, assembly, molded rubber precision sealing, aluminum foundry and die cast.
4. HLI - Wabash Indiana
5. 13+ years in Quality and I have been in manufacturing for 27 years almost all of it tied to automotive in form or another.
6. I had no intention of going to college until 10 years after HS, which I barely survived, I enrolled in 1984. I completed my BS in Business Administration in 2000 - 16 years later - & graduated Summe Cum Laude.
7. I have many, but will list two. 1- Those that only do enough to get by. 2- Failure to contain when something goes wrong.
8. Erase the alphabet soup acronyms - Make everyone understand the basics - Require all persons with an MBA to have demonstrated competence at actually having made something.
