The Preventive Action Demystified
somashekar
The Preventive Action (PA) has always been at the center of confusion and has been also seen as an extension of the CA, because of the common term CAPA that is mostly in use. It has taken years to clarify (hopefully) that the CA does not have to be followed up with a PA. PA in itself was left to the wild imagination of the MR, if I may say so, to manage during an audit process. At other places some had gone to the extent of capturing any and all possible actions as PA without perhaps proper linkage.
Let’s see how the new ISO 13485 helps us in understanding this. At clause 0.2, the standard limits the concept of risk to safety or performance requirement of the medical device, or meeting the applicable regulatory requirement. The Preventive Action clause 8.5.3 also tells that the action taken does not adversely affect ability to meet regulatory requirement, or the safety and performance of the medical device. Taking these clues and understanding that potential nonconformities are possible risks., when we go through the standard, we can see a lot of situations where the PA are to be taken. When these are suitably recorded and linked to the PA documented procedure as appropriate to the organization, lot of clarity will emerge towards what the Preventive Action is…
Making a simple list will capture the PA areas which I can see as following …
Control of documents [specifically the g) and h) in 4.2.4] / Human resource (more specifically a trained and competent regulatory officer) / Infrastructure (like Clean room, Pure water system, ESD work areas, specified work environment) / Contamination control / Notification of changes in purchased products (comes from FDA 21 CFR 820) / The controls of production and service provisions / Cleanliness of products / Validation / The specified particular requirements / Feedback process / ..
When you can link these said practices (your practices) as applicable to you into your PA documented procedure, you are done. Your PA are bright, clear and demystified.
Comments …..
Sidney Vianna
Post Responsibly
Preventive actions and the requirements contained in ISO 9001 (through 2008 Edition) have led to some of the longest and most contentious threads we've had in The Cove.
ISO 13485:2016 8.5.3 is very close to the requirements from ISO 9001:2008. The fact that the TC 210 decided not to use the HLS template and maintained PA's as part of the requirements, while the TC 176 dropped the requirements and rationalized explicitly and at length why 9001:2015 was devoided of a PA section exposes a major weakness in the standards development process.
QMS experts clash with Medical Device QMS experts. Why is PA (as prescribed in 13485:2016 8.5.3) necessary while, it is not a requirement of 9001:2015 (and all the sector standards based on it, such as AS9100:2016, IATF 16949:2016)?
The fact that this thread was created, trying to shine a light on something that, for over a decade and a half, "experts" from TC 176 and 210 are unable to crack the code they themselves created show how (in my opinion) trying to demystify PA is Mission Impossible.
randomname
Preventive action (per ISO 9001:2008):
1. Determine potential nonconformities and their causes (identify risks)
2. Evaluate the need for action to prevent them (assess risks)
3. Determine and implement any actions needed (treat risks)
4. Review effectiveness of those actions (monitor risks)
This is the risk management process!
Mortalis
It is part #4 that we struggle to demonstrate. How do you show the effectiveness of something that prevents something from happening that never happened?
Marcelo
By defining exactly what you did not want to happen, how actions you did to prevent it from happening, and the methods you are gonna use to check that the actions to prevent did work.
It's not only "it did not happen so it's ok", but more like "the actions I did were ok and in the end what I did not want to happen didn't.
Something that the "preventive action" lacked, but risk management has, is the need to verify if the actions did not have an impact on other stuff.
Ronen E
Problem Solver
Moderator
Corrective actions (I know we're discussing preventive actions, patience please) are targeted at correctly identifying root causes and then eliminating them. Step #1 in verifying effectiveness is ensuring that the identified root cause was elimienated.
The same can be done with preventive actions. Has a root cause been identified? Has it been elimienated?
Whether or not a root cause has been correctly identified (and there are no others) is a different, tougher question. In CAs it can be answered empirically. In PAs you have to use org's best analytical resources.
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
R Evaluating the need for preventive action Preventive Action and Continuous Improvement 3
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
M Training in 8D Problem Solving as a Preventive Action? Problem Solving, Root Cause Fault and Failure Analysis 9
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
R Preventive Action - confusing ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Preventive Action - How to call the prevention when there is not a clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Evaluating Effectiveness of a Preventive Action after Closure Preventive Action and Continuous Improvement 7
A Preventive Action and Risk Assessment Audit Process Audits and Layered Process Audits 5
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
B Struggling With Writing PA (Preventive Action) Procedure Preventive Action and Continuous Improvement 11
E Can anyone share a Preventive Action Form or Template ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Customer Complaint Preventive Action Assistance Preventive Action and Continuous Improvement 3
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
MarilynJ6354 Definition Improvement Suggestion vs. Preventive Action - Clear Definitions and Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
B Near Miss = Preventive Action Request (PAR)? Miscellaneous Environmental Standards and EMS Related Discussions 1
M Boosting a Preventive Action System Quality Manager and Management Related Issues 2
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
R Does FDA require monitoring competitor device failures for preventive action? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
B Certification Body insist on evidence of Preventive Action during Stage 2 audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P Lessons Learned Identification - Potential Preventive Action Responsibilities Preventive Action and Continuous Improvement 4
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
T Action plan: How to manage actions, preventive actions and opportunities of improv? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Preventive Action Process question - ISO 9001 Clause 8.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
6 Preventive Action - Help Needed. Input for Training and Sustenance Preventive Action and Continuous Improvement 3
L Non Conformity (Nonconformance) Report & Preventive Action Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
