The real Link between a PFMEA (Process FMEA) and the Control Plan
jshipley
Is it fair to say that the Process Failure Mode on the PFMEA is the Control Characteristic on the Control Plan?
If so does every process failure need to be addressed in the control plan?
Lastly does anyone have an excel form that would automatically tranfer PFMEA information over to the Control Plan to begin that process?
Thanks in advance,
jakes
Re: The real Link between a PFMEA and the Control Plan
Thanks in advance,
jakes
I don't have a template for you. I know that there are commercial packages that will do it, but they tend to be a little expensive.
As for the general strategy of linking the PCP to the PFMEA, the latter should be used to help determine what appears on the control plan, and the necessary controls. It's not necessary to transfer all of the operations shown on the PFMEA document to the control plan, as it may have been determined during the PFMEA process that some operations don't present risk sufficient to require continuous control. What's listed as a failure mode on the PFMEA depends on how you construct it. I like to see process failures identified as failure modes, rather than part defects (defects are the effects of process failures). The goal, after all, is to control the process.
The process/product characteristic columns on the PCP form should be used to describe what's being controlled. For example, if you're using process failures as failure modes, you would make an entry in the process characteristics column such as, "Dwell time," then give the limits (the tolerance) in the tolerance column ("30 seconds, +/- 2 seconds," e.g.). In the part characteristic column, you would describe the part characteristic(s) that might be affected by dwell time, and list the necessary controls.
jshipley
So i that case would you say that each function must be listed on the Control Plan - then on the Control Plan identify the controls for that function?
From my previous post:
(emphasis added)
The controls identified on the PFMEA are what are recorded in the control plan.
Actually, it's the other way around. The PFMEA asks for current process controls, which assumes that there is an identical or substantially similar process from which the current controls may be cited. So you're transferring the current controls from an existing control plan to a PFMEA document. In the case of a novel or unique process, there would be no existing controls to cite on the PFMEA document.
Mexicanforquality
My experience about linking these documents is that you need to assure that special characteristic listed in PFMEA are all adressed as part of your PCP. I think that there is no necessary to listing every item from PFMEA to PCP, if you think that in PFMEA you will start an exhaustive analysis of your process and you will end dismissing some failure modes and giving a close follow and action plan to anothers according to your RPN
Not necessarily. If your new process was similar to an existing process, you may have existing controls that will carry over to the new process, and into the control plan.
In addition, if no existing controls exist, and you need controls based on the RPN, you should have developed these controls as part of Recommended Actions to lower the Detection Rating. Therefore, the new controls should also carry over to the Control Plan.
I think I said that.
How can something that doesn't exist be a current process control? :confused: I agree that new process controls should be considered as "Recommended Actions," and in such a case the proposed controls should form a part of a prototype or pre-launch control plan. They don't actually become current process controls until the control plan reaches the production stage, at which point they may be cited in other PFMEAs as such. But if there are no current process controls, there are no current process controls. The appropriate entry in such a case is "none."
Alex Kobzar
I always (for manufacturing processes) copy the "Process Function/ Requirements" column from PFMEA and paste it as it is in the "Process Name/ Operation Description" of the Control Plan.
Of course all process failures (which are significant enough to require a control to be established to prevent and/or detect its occurrence) shall be present in the control plan!
A SPC Software Packages - Real Time and can link to Databases including Oracle Statistical Analysis Tools, Techniques and SPC 7
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
S Stability accelerated vs. real-time Other Medical Device Related Standards 3
S Standards for real time stability for medical devices Other Medical Device Related Standards 2
optomist1 DFMEA - Real Life Drama FMEA and Control Plans 25
R Real Example of a currently marketed Procedure Pack CE Marking (Conformité Européene) / CB Scheme 1
M FDA News FDA Safety communication – Interim Results of Duodenoscope Reprocessing Studies Conducted in Real-World Settings Medical Device and FDA Regulations and Standards News 0
A Accelerated aging and real time study EU Medical Device Regulations 2
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
M Real-time-aging Validation - ISO / ASTM Standard - Class 111 Orthopedic Implant Other Medical Device and Orthopedic Related Topics 1
shimonv Storage Conditions of 5-40 Celsius - Accelerated and real time aging - Dilemma EU Medical Device Regulations 3
P Is ISO 13485 of November 2016 Real? ISO 13485:2016 - Medical Device Quality Management Systems 4
Ninja What is the most useless {real} documented procedure you've seen? Coffee Break and Water Cooler Discussions 4
I How to sample in a real time release process? AQL - Acceptable Quality Level 4
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
O Medical Devices - Legal Manufacturer and Real Manufacturer EU Medical Device Regulations 5
R Self-Certification Is Not a Real Thing - an IAF article Registrars and Notified Bodies 13
L How to represent the ?real? or ?actual? players in organizational chart? Misc. Quality Assurance and Business Systems Related Topics 3
Marc CBS Taps the Real Stephen Colbert as Letterman's Replacement After Work and Weekend Discussion Topics 1
S Stated Accuracy of Portable CMM Arm and Real World Use Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
T Classification of Real-Time Thermocycler for CE Marking CE Marking (Conformité Européene) / CB Scheme 3
B Permissible Exclusion for Clause 7.5.2 in a Real Estate Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Real World Example of Document Control Failure Needed Document Control Systems, Procedures, Forms and Templates 5
Crusader Real World Continuous Improvement Examples for Accounting Personnel? Quality Tools, Improvement and Analysis 3
B Any swimming tips before I dive into the pond? Real estate development business Document Control Systems, Procedures, Forms and Templates 20
S What is real Innovation? (as described by ISO 9004, 2009 edition) Philosophy, Gurus, Innovation and Evolution 5
Y Advice on this real case on AQL (Acceptable Quality Level)? AQL - Acceptable Quality Level 3
S Pulling Data In Real Time From Excel using Minitab 15 Using Minitab Software 2
Sidney Vianna Mutually Beneficial Supplier Relationships in the real world - GM learned a lesson? Quality Manager and Management Related Issues 1
C Do you implement real SPC not just a paper work? Statistical Analysis Tools, Techniques and SPC 18
D Real Life Testing related to Relevance or Quantification of Test Duration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Capability Analysis in the Real World Capability, Accuracy and Stability - Processes, Machines, etc. 7
optomist1 Real World SPC Dealing with Outliers Statistical Analysis Tools, Techniques and SPC 22
J Rotating operators through experiencing Inspection - A real eye opener... Training - Internal, External, Online and Distance Learning 6
P DFX & DFLSS (DFSS) Techniques & Processes - Real world example of the usage Six Sigma 1
M Tracking Materials and Tooling - Evolving to Real Life Misc. Quality Assurance and Business Systems Related Topics 8
R Customer Rquest for Real Ppk? Get Real... APQP and PPAP 2
Marc Green Building: A Real Estate Revolution? University Of Michigan Banks On LEED Sustainability, Green Initiatives and Ecology 1
S Real-Time Production Location Technology Lean in Manufacturing and Service Industries 6
Kales Veggie Shop Floor Real Time SPC Inquiry Statistical Analysis Tools, Techniques and SPC 15
A How do you obtain real Management Commitment Quality Manager and Management Related Issues 18
O Project Documentation Submission Guidelines for Real Estate Construction Document Control Systems, Procedures, Forms and Templates 4
A Auditing sufficiency of documented quality objectives vs the real process Internal Auditing 14
Marc Flying will be a real pain now - New rules keep passengers in seats Travel - Hotels, Motels, Planes and Trains 7
J Online Monitoring of SPC Data and Charts in Real Time Statistical Analysis Tools, Techniques and SPC 12
K Belief To Faith - Great Motivator , A Real Story World News 5
G Try reading this - A real brain teaser Brain Teasers and Puzzles 16
C Shocking But Real Acronyms Coffee Break and Water Cooler Discussions 8
