Hello all,
I have some problems encountered and need your advice:
1. The special characteristic that appeared in control plan which shall be sourced from customer input / defined as special charateristic in FMEA first, isn't it? Any other sources?
2. Are there any problems if we defined the special characteristic in control plan and work instructions only?
3. Per our current practice, I will define which process parameter / product specification should be classified as special characteristic, then base on the severity and occurance then further classified them as "Critical" or "Significant", any problem for our currance practice? Or just simply classified them as specical characteristic first, then base on the Severity and Occrance to further classified them as " Critical" or "Significant"?
Thank you in advanced for your inputs.
