The Role of the Process Audit in ISO 9000 Internal Audits
M Greenaway
#11
Jim
How do you get over the problem that not all ISO9001 requirements will be documented in the QMS ?
It seems that the desktop review you talk of is just to confirm that certain 'documentation' exists. Isnt documentation just a very small requirement of the standard ?
For example the question of competency, we have no procedure on competency, hence a desktop review will not identify that we address this issue, and if we only audit procedures to determine implementation and maintenance, then again we will not touch on this issue.
M Greenaway
#12
Jim
If this 'compliance checklist' is only looked at by the desk checker, how do we determine implementation and effectiveness ?
You argument appeared to be that someone checks the documents to the standard, then someone else checks the working practice to the documents. This argument is based on 'documents for everything' which as you say is very old hat.
Also the statement 'we, (as part of normal good management) make sure that we are doing what we'd said', is based on the huge assumption of 'normal good managers' existing and doing their job properly, which is such a massively blind assumption you might as well spread the whole assumption to everyone and everything in the system, and not bother to audit at all, as it is the purpose of the audit to determine this (and other things).
Craig H.
#13
Jim Wade said:
"The trick is to provide a document that the registrar considers 'part of the QMS' but we know it isn't really - because we don't need it for
our management system to operate well and no-one else (other than the desk-checker) will ever see it. That document slavishly spells out each 9001 requirement and specifies how we will handle it. It is essentially a compliance checklist."
Ours is called the Quality Manual. The old clause-by-clause approach has its advantages. The main user of this document is our third-party auditor.
M Greenaway
#14
Exactly Craig
Its a re-creation of the useless Quality Manual isnt it !
Why have such a document, and why have such a pointless audit ?
M Greenaway
#15
Jim
You say you only work with companies with committed managers, which I guess always do everything right, but our audit is also a statement of compliance (not just non-compliance).
So even if we have the best managers in the world who always do everything right, isnt it healthy to have someone independently confirm that everything is continuing OK ?
Is it healthy to think that our managers will always do everything right, even if they are the most committed people we know ?
Craig H.
#16
Back to the original question, may I restate what I gather the problem at hand is and offer a solution?
If I have read this right, the problem is that Raffy's organization is about to get caught in an impending audit with no internal audits recorded. Right?
It is up to you, Raffy, to determine the frequency of internal audits (at least for 9000). So, why not do one big one, right now? Not only will you cover your requirements, you will have a chance to make sure the "shalls" are covered - sort of a preassessment. If you can do this along with having some "value added" findings, maybe you can sell upper management on the idea of more frequent audits.
I knew I was uncomfortable with the idea of relying on customer audits, but couldn't figure out exactly why. Now, I know - what are the customers auditing to? Their approach will be from their prospective, NOT what is best for your company and its QMS.
In a way, I wish we could call quality audits something different. The word "audit" conjures up images of the IRS (the US tax/inquisition agency) audit. In a way, quality auditing can be a more exact use of the "Management by Walking Around" management method, or am I oversimplifying??
M Greenaway
#17
Yes Jim, it is managements job, and the tool they can use is internal auditing - as the purpose of this is to report to management.
We cant just 'accept' that management do a great job can we ?
F
Fire Girl
#18
Very interesting!
Here's my 2 cents...
I just had this very discussion with my auditor. He looked at how I had my internal audit procedure set up. He asked, do we run our business how the standard is layed out? Nope, not really. He recommended that we audit by process as it is more realistic. A series of processes is what we do. He suggested that we show that we are meeting the standard. It's ok to still do traditional internal audits but he felt that we would get more out of internal auditing if we audited by job traveler, purchase order, all kinds of different ways. As long as all the elements are being covered in some way shape or form... well done.
Fire Girl
#19
If we add a product audit into the mix
Product Audits: Focus is on product compliance to established specifications and/or industry standards. Verification consists of an inspection of manufactured product against the requirements for that product.Were as Process Audits Focus is on the manufacturing process. Verification consists of a comparison of actual practices against applicable process documentation. Inherent to all process audits is an assessment of the competence of the Operator to properly and consistently execute the process using the system . Which leaves us with, Quality System Audits: Focus is on the application of Documented Systems that provide the umbrella of procedural support for the Company. Basically its a Level 1, 2 & 3 audit each used to monitor specific requirments of each level with the system audits being Level 1, and the Process audit being level 2, and the Product audit being level 3. All which are aimed at customer satisfaction thru continious improvment
:frust:
There is a distinct difference. Hope this helps....
M Greenaway
#20
Interesting document attached from the AIAG, who have a lot to do with QS9000, and now TS16949 (which is based on ISO9001:2000), regarding the 'new' approach to auditing processes.
As the third paragraph points out you now have to audit a process, and then check back to the relevant requirement of the standard, rather than trawl through the standard line by line looking for evidence of compliance.
Sorry, did I miss something ? That is how I have audited for years !!
C Role of Breast Tissue Expander in Breast Reconstruction process. Medical Information Technology, Medical Software and Health Informatics 0
S Process Owner role in Problem Investigation/Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 9
V Defining Quality Assurance's Role in R&D (Product and Process Development) Design and Development of Products and Processes 11
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
S Role of a Quality Engineer in APQP process APQP and PPAP 11
A PRRC effective role and activities EU Medical Device Regulations 1
L Implementing the PRRC role in a company EU Medical Device Regulations 7
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
B What is the role of Quality Engineer in APQP and PPAP APQP and PPAP 3
R Role of quality compliance in SAP Software Quality Assurance 2
Z Role of economic operators (EO) post the EU MDR Date of application in May 2020 EU Medical Device Regulations 1
T New role Quality Manager IATF 16949, new company, advise how to get started IATF 16949 - Automotive Quality Systems Standard 2
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
A Audit purpose - case study - What is the role of SQE in such case? General Auditing Discussions 3
M Informational Webinar: The role of the TGA in digital health Medical Device and FDA Regulations and Standards News 0
A Leadership Role in Designing QMS - Upper Management Support Quality Manager and Management Related Issues 16
H Clinical investigation - Role of Notified Body (NB) EU Medical Device Regulations 6
B Interview Presentation for Quality Engineer Role Next Week! Career and Occupation Discussions 21
Edward Reesor Role of increased regulatory costs in increasing risk ISO 13485:2016 - Medical Device Quality Management Systems 10
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
supadrai Forced into Regulatory Affairs Role - Where do I begin? Career and Occupation Discussions 4
Kronos147 Quality Manager's Role in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D Document approvers by role or by name Document Control Systems, Procedures, Forms and Templates 8
G Role of Remote Locations IATF 16949 - Automotive Quality Systems Standard 1
K New Quality Manager Role Quality Manager and Management Related Issues 13
R Registrars offering to perform Second Party Audits - Have they failed their role? Registrars and Notified Bodies 105
G Quality/Regulatory role in Automotive industry Career and Occupation Discussions 1
K What is Quality's and Engineering's role within FAI's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Role of Contract Manufacturer - MDRs (Medical Device Reporting) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
K What is the role of the Six Sigma Black Belt? Six Sigma 9
J Quality Manager's role in Customer and Supplier Complaints Customer Complaints 10
R Role of Product Development in OSHAS 18001 Occupational Health & Safety Management Standards 6
V Interviews - How to differentiate your deliverable/role for potentially being hired Career and Occupation Discussions 9
N Role of Quality Function in Approving Work Instructions Document Control Systems, Procedures, Forms and Templates 4
K The Role of Management and Human Resources Training Courses Training - Internal, External, Online and Distance Learning 0
D Designing a Training Course called "Role of the Laboratory Quality Manager" Training - Internal, External, Online and Distance Learning 13
S What is the role of "Reviewer" and "Approver" in the preparation of procedures? Document Control Systems, Procedures, Forms and Templates 9
T Person in charge's role or responsibility in ISMS? ISO 27001 IEC 27001 - Information Security Management Systems (ISMS) 3
sagai Role and Use of Non QMS Standards and Guidances in the Medical Industry 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
L QMS for Service Company - Top Management wants to take the role of QMR Quality Manager and Management Related Issues 5
K Equivalent role of QP (Qualified Person) in FDA Regulations Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
R Role of Qualified Person (QP) in Contract Manufacturing Pharma Business Quality Manager and Management Related Issues 2
V Best way to represent "Role Clarity" Quality Manager and Management Related Issues 3
C At what stage does Design Control play a role in Medical Device Development ISO 13485:2016 - Medical Device Quality Management Systems 2
K The role of mid level managers in a Quality System Manufacturing and Related Processes 9
P Role of Quality within an Organization Quality Manager and Management Related Issues 3
P Quality Engineer's Role in Tracking MRT Metrics & PDT Metrics Customer Complaints 2
P Quality Engineer's Role in Cost Management (including UMC) Misc. Quality Assurance and Business Systems Related Topics 3
C Role and Benefits of PIC/S (Pharmaceutical Inspection Cooperation Scheme) Other Medical Device Regulations World-Wide 2
