Theory and Practice Behind Expecting a Distribution for my Data (specially the normal
U
Uchiha
Hello everyone,
Cheers for the good work around here :D
My question is probably quite basic: how do we proceed - theoretically and by experience/practice - to say that the measurements of such characteristic should follow such distribution?
I am particularly interested to know the generic procedure (the actual analysis idea), and would like to see it applied to the case of the normal distribution...
As a background, our customer gave us a table with a list of different characteristics (basically dimensional and geometrical tolerances) and the corresponding distributions expected. Apart from the question whether the table is correct or not and that we could eventually discuss some specific cases if we have solid understanding of our process, I am wondering on which basis such a table was made?
I know that theoretically the central limit theorem is used to expect the normality of some data, but I don't have enough experience to understand its application on specific cases... Example: why would the data from a dimensional tolerance with two specification limits follow a normal distribution (question from the CLT point of view)? What are the independent random variables we're considering in this case?
Many thanks in advance :thanx:
Darius
Re: Theory and Practice Behind Expecting a Distribution for my Data (specially the no
Wellcome to the cove
:2cents: IMHO, the best is to check by practice, but there are some cases where non-gausian distribution is expected, ie. the case where is a physical limit and if the data (time) depend on delays. The problem with defining it theorically is that depends on whe variation we are allowing to happen in our process. I have seen processes that althought the relationship is well documented, the data doesn't show it because of the tight control done upon it.
TheGoldenBlazer
The central limit theorum states only that the distribution around the sample mean is normal, not that the data itself is distributed normally. So if you have a set of data lets say:
1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 3, 3, 4
Although it should be 30+ data points according to the central limit theorum, this is just a quick example. Graphing this data by itself will not result in a normal distribution as can obviously be seen, but if you take the mean of the data, 1.67, and graph the deviaiton from the mean, using standard deviations, the curve will approach normality. (With only 15 points it won't be perfect, but at least you can see what it's getting at)
Steve Prevette
Deming Disciple
Given that this has been posting in the "SPC Monitoring . . ." thread, I do want to make my standard statement that SPC does not rely upon Normality for it to function. Non-normal data will work fine with SPC.
There are theorectical reasons to use certain distributions, such as Poisson for counts of objects, Binomail for go-no go testing, Exponential for time between failures, Chi Square for contingency tables, Log Normal for measurements of exposure. Beta-Gamma gets even more interesting in Reliability analyses (and the infamous "bathtub" curve).
Now, whether or not the underlying distribution of the data is important depends upon what you are trying to do with the data. Again, SPC is robust enough to be relatively free of effects of the underlying distribution.
U
Uchiha
I agree with you.
I see. I admit that I do not have enough knowledge to discuss this item.:bonk:
But in order not to go in a much wider scope than the original question, let's get back to the specific case of the normal distribution in the context I described.
Let's suppose you are my customer and you provide, like I said, a table with a lot of information, among which you state that if I, your supplier, have a dimensional tolerance with two specification limits, it should follow a normal distribution. Also let's avoid discussing for now special cases in which this assumption may not be correct and focus only on case(s) where IT IS correct .
Now the question is: I, your supplier, want to know how did you proceed to reach such conclusion... There are definitely theoretical and practical reasons and explanations... These are precisely what I am trying to understand... (and I still think that the CLT is probably involved in the theoretical explanation... Else what would explain such assumption?)
Understood :)
But allow me to ask the following (although this is out of the scope of the original question): does this mean that when using SPC, knowing, or not, the distribution my data should follow and the distribution it is actually following makes no difference as for the way I deal with my control charts (standard deviation, control limits, capability indexes...).
Excuse my ignorance if I am asking a trivial question...
:thanx:
Darius
:DNot trivial at all, Donald Wheeler show in his book (and others I think) "Advanced topics in statistical process control", that as Steve said, SPC works fine for many different types of distributions....., but
Beware of patterns, not all patterns will work, giving false alarms if you configure your system to detect and Donald Wheeler (on the same book) told that he recommended not to use transformations, because it could be more difficult to understand for the most of the users.
The question about capability indexes is another wave, as you may know these indicators use the mean and standard deviation, there are two ways that can address the problem of non-gausian distribution best:
* As I readed on some articles is to transform the data using box-cox (comparing the results using montecarlo simulations with different kinds of distributions).
* Non-parametrical indicators.
And remember that indicators are just that, are oversimplifications that permit us to evaluate our process (an histogram and an SPC chart told me more), and as I readed somewhere "You Can't Manage What You Don't Measure", maybe are not perfect but have their use, so..., do you need to have more precision (than using the standard formulas)?
Let's suppose you are my customer and you provide...a table with a lot of information, among which you state that if I...have a dimensional tolerance with two specification limits, it should follow a normal distribution...let's focus only on case(s) where IT IS correct.
to answer this specific question: You are looking for an explanation that doesn't exist.
The central limit theorem only applies to the distribution of sample averages so if your customer is using this to say that any characteristic with two spec limits must have a Normal distribution, they are mistaken. It is a common misunderstanding...but popularity doesn't make it correct.
Depending on the process - and material - used to generate the characteristic there may be practical scientific reasons to expect a distribution that is somewhat symetrical with high frequency of occurences at the median value and low frequency of occurence at the outer 'tails'. This is commonly referred to as the 'bell shaped curve'.
BUT many processes are simply not homogenous by their very nature and these processes will not result in a Normal or bell shaped curve. The sources of non homogeneity are often not 'thought of' by those with only a theoretical knowledge of the process or limited practical experience with the process. These sources are often 'buried' in the specific details and nuances of the process. The ONLY way to really know is to run the process and take the data.
There is NOTHING inherently wrong with a process that is expected to be bell shaped but that isn't. These processes can still be very stable and capable.
There is no inherent value in a process being Normally distributed...bell shaped processes can be unstable and incapable.
The 'Normal distribution' is not a law of physics. It is a man made model. It can be useful, but it is not some magical, ordained, neccessary thing.
Bottom line: There is no reason to state - either theoretically or practically - that a process with two spec limits must or should be Normally distributed.
bobdoering
Stop X-bar/R Madness!!
It is true, the generic term SPC (statistical process control) will work with any distribution. However, Shewhart charts rely on the process variation to come from independent, random data. All of the examples from Shewhart and Wheeler utilize show a vast number of distributions that work - if those requirements are met. When that is not true, those charts may not be appropriate, but other SPC techniques should be.
bobdoering
Recognize this, also: measuring what you can't react to doesn't help control your process. When picking the variable to chart, the use of a CNX analysis is handy. You have much more value in charting something you can adjust for, than something that is "noise" and you have no control over. If that is all you are charting, it will just trigger your sorting mechanism.
bobdoering
A big 3 auto manufacturer has come out with a chart of "expected distributions" for processes that will not be normal even under controlled conditions. One of the items listed is "Grinding process with auto correction", and indicates the expected distribution is "uniform". Wow.....so close (but much closer than before). Actually, it should say "Grinding process with auto correlation", because auto correction actually generates a normal distribution from overcontrol.) Also, more specifically it is the continuous uniform distribution - quite different from discrete uniform distribution.
I wonder how this was called to their attention.....
hogheavenfarm Affirmations - the theory in practice Imported Legacy Blogs 0
M Lean Time Line (History and Theory) Lean in Manufacturing and Service Industries 5
S Lean or Six Sigma or TOC (Theory of Constraints) - How to decide Lean in Manufacturing and Service Industries 6
S Organizational Complexity Theory - What makes organizations complex Quality Manager and Management Related Issues 4
S What is Normal Theory? Statistical Analysis Tools, Techniques and SPC 24
B En Number - Reference that explains En Numbers Theory & Application General Measurement Device and Calibration Topics 7
I TRIZ (Theory of Inventive Problem Solving) Methodology - Is there training available? Misc. Quality Assurance and Business Systems Related Topics 6
O Queueing Theory - Required Time to Load a Container Human Factors and Ergonomics in Engineering 10
A Theory of Constraints - Can anyone explain something? Six Sigma 6
Marc Definition Theory of Constraints (TOC) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
J Good Free Handbook For Statistical Theory Statistical Analysis Tools, Techniques and SPC 2
S Shainin DOE - Paired Comparison? Background of this theory? Binomial distribution? Six Sigma 16
J Symmetry vs. Position - Symmetry uses the same theory as Position, right? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
B Sampling Questions - Theory behind the use of sampling techniques Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C A new meaning of Planck's theory - Profits!!! Coffee Break and Water Cooler Discussions 12
Marc Anyone Remember B. F. Skinner? The father of Reinforcement Theory Philosophy, Gurus, Innovation and Evolution 13
Kevin Mader Integration of Quality Function & Statistical Theory Preventive Action and Continuous Improvement 20
Marc Demonstration Of Pavlov's Theory of Bureaucracy Philosophy, Gurus, Innovation and Evolution 1
Marc Calibration Uncertainty Philosophy - Reality vs. Basic Theory (& Guardbanding) Measurement Uncertainty (MU) 7
Marc Calibration to a Known Standard - Theory 101 General Measurement Device and Calibration Topics 10
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
R Regulatory Affairs Certification (RAC) prep - Practice test versus actual exam Professional Certifications and Degrees 1
S Selling Clinical Practice Advice Other US Medical Device Regulations 7
M Good Clinical Practice (GCP) - ISO 14155 vs. ICH Other ISO and International Standards and European Regulations 10
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Looking for China Good manufacturing practice China Medical Device Regulations 1
F Recommended practice for furnishing Technical Procedures ISO 17025 related Discussions 1
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
M Medical Device News TGA Consultation: Good Clinical Practice Inspections Program Medical Device and FDA Regulations and Standards News 0
J Good Laboratory Practice: online training course recommendations? US Food and Drug Administration (FDA) 0
T MDR on Good Laboratory Practice (GLP) - Pg 110, section 6.1 (b) EU Medical Device Regulations 1
A What does a good business practice Process Audit look like for AS9100D? Process Audits and Layered Process Audits 9
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
Q Source of practice to Evaluate Risks? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
U Good Documentation Practice (GDocP or GDP) - Labels and Attachments Document Control Systems, Procedures, Forms and Templates 2
Q Is it normal practice to lubricate Ring Gages before use? General Measurement Device and Calibration Topics 17
J Sampling Plan Questions from the CQE Practice Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L ISO13485 past practice labeling vs customer requirement Other ISO and International Standards and European Regulations 2
A Personal names in docs - Goes against every documenation practice I know! Document Control Systems, Procedures, Forms and Templates 30
bio_subbu NBOG Publishes revised best practice guidance documents (Nov 2014) EU Medical Device Regulations 1
W Audit Protocol Manual which describes best practice Auditing Standards General Auditing Discussions 1
D Number of Internal Auditors Best Practice Quality Manager and Management Related Issues 18
A Industry best practice about Post-Market Surveillance and Risk Analysis ISO 14971 - Medical Device Risk Management 6
somashekar Is it a good practice to have Air Conditioner in the Gym Hospitals, Clinics & other Health Care Providers 2
M Safe Work Practice vs Safe Work Procedures - Differences Occupational Health & Safety Management Standards 6
