Thermal Mapping Concepts - Drug store with dimensions 75m x25m x13m
Mohammed Gouda
Dear friends,
i am confused about the thermal mapping .....
i want to learn more about themal mapping and validation of test spaces...
the main question is:"can i ues 2 diffrent systems in data logging in the same test?"and what is the evidence on that?"
ex:i made a thermal mapping for a drug store with dimensions 75m x25m x13m....and i used two systems,one of them is 10 thermocouples type "T" with a scanner...and the second one was data loggers with temp. sensor Pt-100,is the mixing between these two systems applicable or not??:bonk:
*notice that both systems were calibrated.
please send me your openions to can understand the correct concept in thermal validation...
Hershal
Metrologist-Auditor
Re: Thermal mapping concepts
the two systems can compliment each other. The uncertainty is lower on the PT-100, but then the "T" thermocouples can be used as support for those results.
Mohammed Gouda
so...there is no problem from usage of two systems...
but if i have only a few data loggers with PT-100 sensor,what is the best locations (configuration) that i can exploit the low uncertainity of them ??
Hershal
Metrologist-Auditor
You may have to tak muliple efforts, for example one day at one end, high-middle-low, then the center, then the other end.
It will take longer but that may be what you have to do with limited amounts of PT-100's.
alex.Kennedy
The following letter was drafted for an existing customer of ours in Egypt, it answers some of your questions.
This is largely common sense.
You are required to validate the temperature that the product is subjected to, so you are only interested in the product storage areas. Hot air stratifies – heat goes up – cold goes down – so you want the two worst cases – top and bottom.
Examine the air flows around the warehouse, where air is exiting is not usually a problem. Where air is entering – is it affecting the warehouse temperature? Is it a permanent condition that requires verification, or is it a short term aberration?
For a standard 30m by 30m by 8m (100 x 100 x 25 feet) warehouse or store, with a standard temperature requirement of eighteen degree centigrade plus or minus six, I would consider the following adequate;
Where the following location are given it actually means - the nearest product storage point to.
Top shelf & bottom shelf – in each corner of the warehouse
Top shelf & bottom shelf – in the middle of the warehouse external walls.
Top shelf & bottom shelf – in the centre of the warehouse.
This gives eighteen recording points which would be adequate for this size of building. Areas around permanent inflows would have to be defined and addition sensors set to verify how this flow was affecting (the local) shelf temperature.
Shelf areas out with specified temperature, should be painted red and placarded ‘NOT TO BE USED FOR REGULATORY CONTROLLED PRODUCT.’ (this is not legislation, but we have done it often, and visiting regulators have always accepted it).
What ever you do, ensure it is document and warehouse staff, are trained accordingly. Also made certain it appears in their training records.
The type of sensor is completely irrelevant, just as long as its calibration is current and traceable to national standards (USA – NIST & UK UKAS). What governs the sensing system you use is the temperature range your product requires. For instance, if you have an extremely critical product, that required a storage temperature of twenty degrees centigrade, plus or minus one degree. You would require the mapping system to be one factor more accurate, i.e. accurate to plus or minus zero point one, of a degree. In reality a temperature range like this would be unworkable in the typical warehouse.
In practice whatever your storage temperature range is, there will be a tolerance and your mapping system has to be a one factor more accurate. I.e. a set point of twenty degrees centigrade plus or minus four degrees, would require a mapping system accuracy better than plus or minus zero point eight degrees.
(This takes account of all uncertainties, basic FDA accuracy repeatability requirement is one to four).
For ease of use the easiest to use by an enormous margin is the self contained data logger. Eighteen of these in a warehouse will hardly be noticed; there is no wiring and minimal interference with warehouse operations.
Just do an initial reference calibration by subjecting them all (along with a precision calibrated temperature indicator) to a temperature above and then below the range you expect to use, and documenting any error between their readings and that of the calibrated indicator. At the end of the testing, repeat this simple check calibration, and it become your ‘pre’ and ‘post’ check that all your sensors were correct, before and are still correct, after your mapping task.
The mapping should be carried out during the extremes of local environmental conditions, which usually equates to mid summer and mid winter. If you are mapping humidity you must verify that the system being qualified can cope with the full range of ambient conditions. For this reason the PQ has to be executed in phases, in order to demonstrate that the internal warehouse conditions can be maintained regardless of the seasonal variations in the local climate.
You can in general apply these fundamentals to all hot and cold storage or processing enclosures.
Alex Kennedy
Mohammed Gouda
is there any references or SOPs for this ???
i have only 1 reference but i want a standards for validation....
"C[1].C.Chan, et al - Analytical Method Validation and Instrument Performance
Verification"........
Talaat
Dear Mohammad Gouda,
Finally please send to me as soon as possible all document or data base related in this subject specific on the the using of the measuring different systems in the thermal mapping.
Talaat
D Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping? Manufacturing and Related Processes 7
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
E Solder thermal profiles for PPAP - Automotive IATF 16949 - Automotive Quality Systems Standard 1
V Regrinding Material - Thermal properties Manufacturing and Related Processes 4
x-files [Thermal Power plant KOSTOLAC, SERBIA] Sucessfully certified to ISO 50001 Sustainability, Green Initiatives and Ecology 1
x-files [Thermal powerplant] Why "Generation of electricity" is a special process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
x-files Thermal Powerplant - 7.5.3 Identification and Traceability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
x-files [Exclusions] 7.3 Design and development vs. Thermal Powerplant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
x-files Global Timeline Plan of IMS/QMS Activities for a Thermal Power Plant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Acronym CTE - Coefficient of Thermal Expansion Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O AECQ 200 Revision D vs. Revision C - Thermal Shock & Thermal Cycling Other ISO and International Standards and European Regulations 2
U Is there such a thing as 1-part thermal cure epoxy? Manufacturing and Related Processes 11
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
M Transport Vehicle Thermal Regulation - How would you interpret this requirement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Transformers and Thermal Cutouts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R If two thermal cutouts required for water cooling system? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
O Thermal Shock Test with conditions specified in AEC-Q200 Various Other Specifications, Standards, and related Requirements 3
M Diebond adhesive blowholes seen after thermal curing on chip to plastic bottle mount Manufacturing and Related Processes 4
somashekar The Plasma Thermal Destruction and Recovery (PTDR) Waste-to-Energy Technology Sustainability, Green Initiatives and Ecology 4
S AMS2771 - Soak Time Interpretation (Thermal Conditioning) - T6 or T61? Manufacturing and Related Processes 8
T International Reference or SOP for the Thermal Validation of Incubators, Cold Rooms General Measurement Device and Calibration Topics 2
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
C Thermal Accelerated Aging Test(s) for Epoxy Reliability Analysis - Predictions, Testing and Standards 6
S Oven Qualification - Thermal profile during the OQ of a vacuum oven General Measurement Device and Calibration Topics 6
somashekar Hazardous waste rules - India - Carbon paper and thermal transfer printer ribbons Miscellaneous Environmental Standards and EMS Related Discussions 7
T Standard for "Simulating Long Term Effects on Materials / Thermal Disinfecion" needed Other ISO and International Standards and European Regulations 3
T Detergents for Washer-Thermal Disinfector of Plastic Materials ISO 13485:2016 - Medical Device Quality Management Systems 3
E GMW3172 - Thermal Shock and PTC cycles required to validate an electronic system Reliability Analysis - Predictions, Testing and Standards 2
J Temperature cycling thermal chamber accuracy and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GMW3172 - Electrical/Electronic - Temperature cycling and Thermal shock Customer and Company Specific Requirements 4
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
J Definition Defect Mapping - Here is my definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Z 21 CFR and Annex 11 mapping document Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
R Process Mapping for a BPMS (Business Process Management System) vs ISO Process Maps, Process Mapping and Turtle Diagrams 1
M PDCA cycle - Process mapping - Environmental ISO 14001 ISO 14001:2015 Specific Discussions 1
R Process Mapping a Civil Infrastructure Construction company Process Maps, Process Mapping and Turtle Diagrams 4
Q Guidance Needed For Mapping Career Path Career and Occupation Discussions 5
L Mapping the loan lending bank process Process Maps, Process Mapping and Turtle Diagrams 7
R PPM, Pictorial Process Mapping, Templates Manufacturing and Related Processes 5
M Value Stream Mapping Calculations Process Maps, Process Mapping and Turtle Diagrams 5
S ISO14001:2015 Factory Process Mapping ISO 14001:2015 Specific Discussions 7
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
J Agenda of Value Stream Mapping workshop required Quality Tools, Improvement and Analysis 1
R VSM - Value Stream Mapping (catheter manufacturing unit) Customer Complaints 10
A Mapping of IEC 62304 artefacts (SRS, SAD, etc) to the 820.30 phases IEC 62304 - Medical Device Software Life Cycle Processes 5
