Thermoplastic Elastomer Tolerance Table - ISO 3302 / RMA tolerance question
QMMike
I've been looking for a consistent, universally accepted tolerance table for thermoplastic elastomers. RMA and ISO3302 pretty much have the rubber industry covered, how about thermoplastic elastomers. The RMA book specifically states, "The information in this chapter is not intended to apply to thermoplastic elastomers." Is there a standard that does?
Stijloor
Re: ISO 3302 / RMA tolerance question
Mike,
ISO 3302-2:2008. This is what the abstract says.....
Abstract
ISO 3302-2:2008 specifies the following geometrical tolerances for moulded and extruded solid rubber products, including those with metal inserts:
flatness tolerance;
parallelism tolerance;
perpendicularity tolerance;
coaxiality tolerance;
positional tolerance.
The tolerances are primarily intended for use with vulcanized rubber but may also be suitable for products made of thermoplastic rubbers.
Emphasis mine.
Am I close?
Stijloor
Jeff Frost
You should be looking for ASTM (or ISO) specifications specific to the thermoplastic you are trying to control. When I worked for a maker of spring energized thermoplastic seals we had a number of small mom and pop (and a few large aerospace) o-ring suppliers always requesting cure dates for the seals we supplied.
For those of you who may not know, the cure date is the date raw rubber is vulcanized to form the rubber part. Thermoplastics contain no rubber so they are not vulcanized.
QMMike
Mike,
Emphasis mine.
Am I close?
Stijloor
Thanks, I didn't even notice that statement! After further looking at my RMA book, it does state that in the molded section, but then it states in the extruded section that "this chapter is not intended to apply to thermoplastic elastomers"... this one would most interest me, as we extrude thermoplastic but do not mold it.
C PPAP Submissions for Thermoplastic Resins (Bulk Material) APQP and PPAP 3
J ISO 48 - Rubber: Vulcanized or Thermoplastic Other ISO and International Standards and European Regulations 1
N ISO 34: Rubber, vulcanized or thermoplastic - Determination of tear strength Other ISO and International Standards and European Regulations 1
C Certificate EN 10204 for Elastomer (materials other than metals)? CE Marking (Conformité Européene) / CB Scheme 6
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
A Calibration tolerance for data logger General Measurement Device and Calibration Topics 3
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
kedarg6500 Excel spreadsheet for Unilateral Tolerance Study wanted Excel .xls Spreadsheet Templates and Tools 2
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
