Third party auditor mentions no grace period for calibration
Hi Guys,
I have a question relating to this post.
Our internal procedure regarding calibration intervals states that our standard calibration interval is 12 month +/- 1 month. This is to allow an extra 30 days if an external calibration provider is unavailable to be onsite within the 12 month period. This has been our practice for at least 15 years, and we recently had an auditor question that practice. The auditor stated it was unacceptable, but was unable to provide any clauses in ISO17025, ISO9001, or ISO13485 stating that factoring in a "grace" period was unacceptable.
The quality manager and I have looked through other various specs and resources to find some verbiage that either say we can extend our calibration interval an extra month if needed, or that we can't extend the calibration interval, but it seems to be a giant grey area. We are conforming to our procedure, but the auditor believes that our practice is wrong. Does anyone know of any specs or standards that has a definitive statement regarding this?
Hi Guys,
The person who makes the assertion (the auditor in this case) bears the responsibility to support it. You should stop looking for support for an idea that doesn't need it, and politely tell the auditor to put up or shut up.
Sidney Vianna
Post Responsibly
Calibration intervals, including potential grace periods can only be determined intelligently, on a risk based basis. As I mentioned in another, recent post
That's an area where the ill-defined RISK BASED THINKING should be used to the fullest. There are so many variables, such as tolerances involved, criticality of the characteristic being measured, criticality of the product, potential for product recall, ease of verification/calibration, use conditions, environmental conditions, etc...
I've seen processes where before every shift, all of the fixtures, inspection, test and measuring devices in an (high volume) assembly line were verified. Reason being, the organization wanted to contain any potential nonconforming product from further processing.
Tagin
Several years ago, our ISO 9001 auditor actually suggested to us that it would be prudent to include a grace period for our calibrations (we had none at the time).
outdoorsNW
While you do not state which standard the auditor is using, I am going to assume ISO9001.
The ISO9001 standard allows you to set the calibration period. The standard allows you to set a calibration period of two years or longer if reasonable (such as you have no calibration failures or the tool is not used for the final quality check on a feature or process). In your case you are effectively setting the period as 13 months. The risk is higher with longer periods, but if there are no failures you can save some money.
Since you documented the period as 13 months, the auditor is wrong.
I have worked in large systems calibration periods were 3, 6, 12, 18, and 24 months depending on the item. The 3 and 6 month periods were for heavy use items that could not reliably go 12 months without calibration.
As a side note, if you are having many calibration failures without a known special cause, such as a dropped tool (assuming the tool is not used until it can be checked), then the auditor might be able to write you up under ISO9001 section 7.1.5.1. But if you are having many failures, likely many tools are out of calibration by month 10 or 11, so the argument about the extra month is a moot point.
dwperron
Hi Guys,
I'm curious as to what you put in your calibration records as the due date for the next calibration. Do you have it due in 12 months or 13 months?
17025 addresses this issue in that you need to have a due date or interval defined.:
6.4.13 Records shall be retained for equipment which can influence laboratory activities. The records
shall include the following, where applicable:
e) calibration dates, results of calibrations, adjustments, acceptance criteria, and the due date of the
next calibration or the calibration interval;
13485 is similar:
7.6 Control of monitoring and measuring equipment
As necessary to ensure valid results, measuring equipment shall:
a) be calibrated or verified, or both, at specified intervals...
Using your grace period method you don't define / specify a due date or interval.
If you mean to have a 13 month interval then state it, don't imply it. Nothing wrong with that.
Yes, you can have a QMS that allows you to extend the interval, but you still need to define when the calibration is due.
Sidney Vianna
Post Responsibly
What if the interval is set in a non traditional manner? Something like "a micrometer must be calibrated, after 50 instances of normal usage?" So, if the device gets used once a week, it would be almost a year, before re-calibration is due. If the device gets used once a day (assuming 5 business days/week), the device would be re-calibrated after 10 weeks.
A pre-established "time interval" is not smart, in my opinion. I checked the ISO/TS 9002:2016 document and they offer the following pearl of wisdom, concerning this subject:
dwperron
Galaxy 32 was asking about the requirements in ISO 17025 and 13485 concerning calibration intervals.
Both require you to define the calibration interval, and 12 ± 1 month is not an interval.
If the interval is 50 uses then you need to keep a record of the number of uses, and the calibration is due after number 50. Not at the end of the month of the 50th use.
Your quote from ISO 9002 concerns the choice of an interval based on risk of the measuring device being out of tolerance, not on the risk of it being outside of its calibration interval. It is telling you that if the measurements you make are critical to your process then you should determine a calibration interval commensurate to that risk. But you still need to choose and define an interval.
Rameshwar25 Min working experience for IATF 16949 third party auditor IATF 16949 - Automotive Quality Systems Standard 5
Anerol C Becoming an IATF 16949 Third Party Auditor Career and Occupation Discussions 12
Mikishots AS91X0 Third Party Auditor Cycling and Changing Auditors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
E Third party auditor's statement about SPC - Steel Making - EAF Statistical Analysis Tools, Techniques and SPC 11
N How do I become a Third Party Auditor? Career and Occupation Discussions 20
N Auditing our Third Party Internal Auditor Internal Auditing 18
J External third party audits Registrars and Notified Bodies 1
S Would this be a second site for the purposes of internal and third party audits? General Auditing Discussions 4
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
F Firmware as SOUP - Sensor with third party produced firmware IEC 62304 - Medical Device Software Life Cycle Processes 2
Marc Medical device vulnerability highlights problem of third-party code in IoT devices Other Medical Device and Orthopedic Related Topics 1
R UDI for US - Third Party device Repackager Other US Medical Device Regulations 9
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Looking for third party reviewers for FDA submissions US Food and Drug Administration (FDA) 2
S Regulatory strategy for Third party plugin in a PACS EU Medical Device Regulations 1
M Informational US FDA – URGENT/11 Cybersecurity Vulnerabilities in a Widely-Used Third-Party Software Component May Introduce Risks During Use of Certain Medical Dev Medical Device and FDA Regulations and Standards News 0
M Informational Updated US FDA Resources for Third Party Review Organizations Medical Device and FDA Regulations and Standards News 0
M Medical Device News FDA - Eliminating Routine FDA news 14-09-18 - Re-Review of Third Party 510(k) Reviews Other US Medical Device Regulations 0
K Tips for dealing with third party auditors General Auditing Discussions 11
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Creating a policy to evaluate the Third Party Security IEC 27001 - Information Security Management Systems (ISMS) 4
R (OOT) Measurement Equipment after the calibration at a third Party lab General Measurement Device and Calibration Topics 3
R Medical Device Cyber Security Third Party Review Other US Medical Device Regulations 6
L Medical Device Installation Records from Third Party Installer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Temporary Facility Used For Production - Use of existing Third Party Logos ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Third Party Service Provider Risk Rating Spreadsheet Risk Management Principles and Generic Guidelines 1
T Is Testing in a Third Party Facility Subcontracting? General Measurement Device and Calibration Topics 2
C Mexico Medical Device Third Party Reviewer Other Medical Device Regulations World-Wide 2
Q Third Party Audit Nonconformance for Training effectiveness IATF 16949 - Automotive Quality Systems Standard 20
J Eligibility for Third party review US Food and Drug Administration (FDA) 2
G Academic Study Investigating the Effectiveness of Third Party Audits General Auditing Discussions 2
K Third Party On-Site Servicing - Training Records Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
C Third Party Inspection and Certification Costs for a Project Registrars and Notified Bodies 7
S Incidents that occur during a Third Party Supplier Audit - Help for ISO 9001 General Auditing Discussions 23
Q Preventing Audit Finding by your third Party Registar IATF 16949 - Automotive Quality Systems Standard 5
N CE Mark and Third Party Companies Evaluation Factors CE Marking (Conformité Européene) / CB Scheme 5
J Reputable Third Party Inspection (Metrology Lab) In USA? Cam Profile Measurement General Measurement Device and Calibration Topics 5
A How to Document Third-Party Audit Nonconformities related to Legislation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J AS9100 Third Party Nonconformance Closure Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
A Gamma Validation - What should a Third Party Irradiation/Gamma Company Supply EU Medical Device Regulations 2
F Integrating Third-Party Software into Software we Provide ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
H Procedure or Program and Policies for Hosting Third Party Inspections Document Control Systems, Procedures, Forms and Templates 1
T Third Party Containment in Mexico Nonconformance and Corrective Action 6
A Template for Agreements with Third Party Sorting Houses IATF 16949 - Automotive Quality Systems Standard 2
C Learning Material for a Third Party Distribution Sales Environment Training - Internal, External, Online and Distance Learning 2
1 Third Party Certifications - Certificate of Compliance for Distributors Document Control Systems, Procedures, Forms and Templates 2
O When do you say that you are ready for Third-Party Certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 59
G Reporting QMS changes to third party auditors (certification bodies aka registrars) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Can we use Third-party 510(k) reviewer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
