Thread gages -using the NOGO end correctly.
  • Thread starter jane_ackerman - 2010
  • Start date
ScottK
Not out of the crisis
#11
Re: Thread Gage - No-Go end - No-Go end is allowed to enter the part up to 1.5 turns
Who changed my thread subject name?
I didn't include the last part that states "No-Go end is allowed to enter the part up to 1.5 turns"
I'd appreciate that being removed, as it is not a true statement and I didn't include it in my original post.
Thank you in advance.
mods tend to do that to give as much info as possible in the title.
Don't take it personally, but don't be afraid to question authority either :)
CarolX
#12
Jane,
We frequently rename thread titles to aid in the search function. If a user comes in looking for no-go gaging on threads and 1.5 turns , they will be directed to this excellent thread.
My appologies if you were offended.
I do thank you for an excellent thread. A lot of great information in your original post.
#13
Jane,
But if such a search would still find this thread, even if the title hadn't been changed, no?
#14
Perhaps it could be changed to reflect that the "no-go end may enter based on the thread type"?
Just a thought... to make it more of a true statement.
Thanks.
#15
Perhaps it could be changed to reflect that the "no-go end may enter based thread type"?
Thanks.
I think perhaps a question mark at the end might clear it up.
Wes Bucey
#16
Get me a consensus of what you want the thread title to be and I will change it to reflect the consensus opinion.
How about "ANSI Unified thread plug gage - How many turns allowed for no-go end?" (Confirm we refer to ANSI Unified thread?) There is a Standard ANSI B 1.2.
My 23rd edition of Machinery's Handbook says (p1642) "NOT GO (H1) Thread Plug Gages. NOT GO (H1) thread plug gages when applied to the product thread may engage only the end threads (which may not be representative of the complete thread.) [deleted for space] . . . acceptable when the NOT GO (H1) thread plug gage applied to the product internal thread does not enter more than three complete turns. The gage should not be forced. Special requirements such as exceptionally thin or ductile material, small number of threads, etc., may necessitate modification of this practice."
H
H. Majhenich
#17
We make precision parts in our plant. Some of our parts have threads only 1-3 turns long. The 'Nogo' must not go in at all. I would think that it is all a matter of common sense, w/ the max of 3 turns on larger parts.
Wayne
Gage Crib Worldwide
#18
... I've always contended that "industry standards" that aren't officially codified and controlled, (A) can't be referenced on a drawing and (B) are generally useless. ...
Jim, I assume that when you speak of “industry standards” not being officially codified and controlled, you are speaking of the unofficial rule-of-thumb, not the ANSI/ASME/ISO/SAE standards. These are codified, can be controlled and are referenced on drawings.
#19
I understand, hence the scare quotes around "industry standards."
Wayne
Gage Crib Worldwide
#20
Get me a consensus of what you want the thread title to be... How about "ANSI Unified thread plug gage - How many turns allowed for no-go end?" (Confirm we refer to ANSI Unified thread?) There is a Standard ANSI B 1.2. My 23rd edition of Machinery's Handbook says...
The current edition of the Machinery’s Handbook is the 27th. How old is that 23rd edition?
As for the standard being discussed, yes, one gaging requirement for the Unified Thread is specified in ANSI B1.2, but the gaging requirement is also specified in BS 919; JIS B 0255; JIS B 0256; SAA AS 3635; and an ISO standard that I can not identify at the moment. Then there is a similar list of requirements for NPT, NPTF, ANPT, BSPP, BSPT, ACME, Buttress, Metric, Whitworth, Trapezoidal and other threads.
Use requirements for thread gages vary based on the standard that defines them. When a part is designed, the standard requirements for the threads should be stated on the print. Gray areas in the standard, if critical, need to be further defined on the print. I believe that, if you check the wording in the ANSI B1.2, for example, you will find wording defining the use of the NOGO gage which states something to the effect of: Shall not enter the part not more than 1-1/2 to 3 turns, unless otherwise specified by the customer. This wording covers short parts or long parts or specific product requirements not obvious to the maker of the component part, as long as engineers fully define the component requirements, and quality professionals review the standards for their specific idiosyncrasies.
R Using thread plug gages with helical coil inserts General Measurement Device and Calibration Topics 21
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
K Calibration Requirements for Thread and Ring Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Sealed in Wax Thread Gages - ISO 9001 Clause 7.6 Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Calibration Frequency of Thread Gages use for Aluminium and Stainless Steel Products Calibration Frequency (Interval) 6
S Special Gages for Measuring Pre-Heat Treat Thread Size Measurement Uncertainty (MU) 3
S Selecting Wires for Measuring P.D. of Thread Gages General Measurement Device and Calibration Topics 9
F Standard regarding the wear of Thread and Plug Gages. General Measurement Device and Calibration Topics 10
T Correct use of NPT (National Pipe Thread) Thread Gages General Measurement Device and Calibration Topics 15
B Hard Gage Rentals - Thread Gages or Thread Rings General Measurement Device and Calibration Topics 3
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S NPT Thread Calibration Method - NPT Taper Thread Plug Gages General Measurement Device and Calibration Topics 9
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
Wayne Screw Thread Major and Minor Diameters - Parts vs. Gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Q Will the Certificate of Accuracy that comes with thread gages satisfy ISO9001? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
G Calibration of 200 sets of Thread Ring Gages - Return them to the manufacturer? General Measurement Device and Calibration Topics 19
S Torque Limits for Thread Gages General Measurement Device and Calibration Topics 1
G API REG Pin and Box Threading - Minimum Gages Needed - Thread, Plug and Ring gauges? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
M Calibration requirements for pins, thread gages, etc? General Measurement Device and Calibration Topics 2
P Thread Ring Gages - Discrepancies - Is the manufacturer specification wrong? General Measurement Device and Calibration Topics 3
M Thread Gage Calibration Software to look up requireds/specs for thread gages Calibration and Metrology Software and Hardware 48
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M NPT thread gauging and the "rapping" process Manufacturing and Related Processes 1
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
Marc Printable Discussion Thread View Elsmar Xenforo Forum Software Instructions and Help 0
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
S Unique ID Required for Thread Gage Replacements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Thread recommendation for Cast Iron part Manufacturing and Related Processes 1
K Thread callout - M22 x 1.0-6H 0.100R Thread Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
