Thread gages -using the NOGO end correctly.
  • Thread starter jane_ackerman - 2010
  • Start date
Wes Bucey
#21
Re: Thread Gage - No-Go end - No-Go end is allowed to enter the part up to 1.5 turns
The current edition of the Machinery’s Handbook is the 27th. How old is that 23rd edition?
As for the standard being discussed, yes, one gaging requirement for the Unified Thread is specified in ANSI B1.2, but the gaging requirement is also specified in BS 919; JIS B 0255; JIS B 0256; SAA AS 3635; and an ISO standard that I can not identify at the moment. Then there is a similar list of requirements for NPT, NPTF, ANPT, BSPP, BSPT, ACME, Buttress, Metric, Whitworth, Trapezoidal and other threads.
Use requirements for thread gages vary based on the standard that defines them. When a part is designed, the standard requirements for the threads should be stated on the print. Gray areas in the standard, if critical, need to be further defined on the print. I believe that, if you check the wording in the ANSI B1.2, for example, you will find wording defining the use of the NOGO gage which states something to the effect of: Shall not enter the part not more than 1-1/2 to 3 turns, unless otherwise specified by the customer. This wording covers short parts or long parts or specific product requirements not obvious to the maker of the component part, as long as engineers fully define the component requirements, and quality professionals review the standards for their specific idiosyncrasy.
Absolutely, Wayne! I'm old, semi-retired and rarely have need for a more recent version when many things are available via internet. I think I may have some editions in boxes in the garage which go back to the 60's and 70's! Hence my mention of WHICH edition!
The operative phrasing throughout the years has always been some version of "use common sense! If you have only 2 threads in a thin sheet metal panel, reference to three threads is invalid."
Wayne
Gage Crib Worldwide
#22
Jim & Wes,
What are you guys doing up so late. I thought it would be hours before you caught my remarks.:D You guys are fast!:applause: I don't intend to offend, I just have never learned how to be socially appropriate.:eek:
#23
WOW! This has turned into an awesome discussion!!!
Thanks so much to all of you who have done some research and provided the quotes and sources.
Wes,
Since there are various standards based on thread type, how about simply:
"Thread Gages - How many turns allowed for no-go end?"
Again, a huge thanks to all who have provide input.
Jane
Charles Harvey
#24
I looked this up in my copy of the ANSI/ASME B1.2-1983 std. It appears that Wes's quote from the Machinery Handbook of several days ago is a direct quote of section 4.2.1 (page 13) of B1.2-1983. The wording is identical.
Wes Bucey
#25
Wes,
Jane
How about
"Thread gages - using the no-go end correctly"?
#26
That works for me.
M Greenaway
#27
Just to add to the confusion.....
I recall being taught that all the stress in a thread is handled by the first 3 pitches, hence allowing this to go oversize one would imagine would weaken the strength of the fastener ??
Maybe ??
jeremyridley
#28
New to this forum...My company just got me a Pratt & Whitney Super Mic to bring our calibration back in house. I have procedures for just about every thing I need except NPTF plugs. I know I have to measure pitch diameter at the gaging notch, and major at the small end. I have a 3/4 TPF master and flat tapered probes. Is there anything fundamentally wrong with what I have so far? What is the Measure Over Wire formula? What else is needed to be able to certify this gage? I already have the pipe thread standards. I would greatly appreciate the help with this.
Stijloor
#29
Hello Jeremy! Welcome to The Cove Forums. :bigwave: :bigwave:
It is weekend and I am sure that the Metrology/Calibration experts here at The Cove will respond next week.
Look at this thread: "How to properly check (British Standard) threads?"
This thread has some good posts and other links to topics that may be of interest to you.
I hope this helps you to get started.
Stijloor.
Wayne
Gage Crib Worldwide
#30
How about
Wes, I see that the name of this thread has not been changed. :agree1:Your suggestion: "Thread gages -using the NOGO end correctly." is good for the preceding discussion; however; the discussion of pipe gage calibration really needs its own thread.
R Using thread plug gages with helical coil inserts General Measurement Device and Calibration Topics 21
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
K Calibration Requirements for Thread and Ring Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Sealed in Wax Thread Gages - ISO 9001 Clause 7.6 Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Calibration Frequency of Thread Gages use for Aluminium and Stainless Steel Products Calibration Frequency (Interval) 6
S Special Gages for Measuring Pre-Heat Treat Thread Size Measurement Uncertainty (MU) 3
S Selecting Wires for Measuring P.D. of Thread Gages General Measurement Device and Calibration Topics 9
F Standard regarding the wear of Thread and Plug Gages. General Measurement Device and Calibration Topics 10
T Correct use of NPT (National Pipe Thread) Thread Gages General Measurement Device and Calibration Topics 15
B Hard Gage Rentals - Thread Gages or Thread Rings General Measurement Device and Calibration Topics 3
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S NPT Thread Calibration Method - NPT Taper Thread Plug Gages General Measurement Device and Calibration Topics 9
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
Wayne Screw Thread Major and Minor Diameters - Parts vs. Gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Q Will the Certificate of Accuracy that comes with thread gages satisfy ISO9001? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
G Calibration of 200 sets of Thread Ring Gages - Return them to the manufacturer? General Measurement Device and Calibration Topics 19
S Torque Limits for Thread Gages General Measurement Device and Calibration Topics 1
G API REG Pin and Box Threading - Minimum Gages Needed - Thread, Plug and Ring gauges? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
M Calibration requirements for pins, thread gages, etc? General Measurement Device and Calibration Topics 2
P Thread Ring Gages - Discrepancies - Is the manufacturer specification wrong? General Measurement Device and Calibration Topics 3
M Thread Gage Calibration Software to look up requireds/specs for thread gages Calibration and Metrology Software and Hardware 48
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M NPT thread gauging and the "rapping" process Manufacturing and Related Processes 1
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
Marc Printable Discussion Thread View Elsmar Xenforo Forum Software Instructions and Help 0
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
S Unique ID Required for Thread Gage Replacements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Thread recommendation for Cast Iron part Manufacturing and Related Processes 1
K Thread callout - M22 x 1.0-6H 0.100R Thread Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
