Thread micrometer questions, discussion regarding MU and calibration.
apestate
Hello forum
I am trying to maximize the potential of our thread micrometers. The official nomenclature is probably "interchangable anvil screw thread pitch diameter measurement micrometer" or something, you know the type.
I have a question regarding thread distortion of form. Let's say I have a thread plug with a pitch diameter of 1.000" and 8 threads per inch. If I set my thread mic to read accurately on this thread plug and then measure a different thread plug with a pitch diameter of 1.000" and 32 threads per inch, will the thread mic read accurately?
If the distortion of form error is very small, then I could set all our pitch mics using a 1" pitch diameter thread. If the distortion of form error is significant, I would imagine the real deal would be having master thread plugs at 1" pitch diameter in all the thread leads that we use, 8, 10, 11, 12, 13, 14, 16, 18, 20, 24, 28, ad infinitum.
Does anyone see where I'm going with this? I want thread micrometers to have very low MU factors and be very accurate. As it stands, I'm finding discrepancies all the time. Zero setting with a thread mic standard and measuring a thread plug yields .0005" discrepancy, same discrepancy going from thread plug to thread plug of different pitch.
Is distortion of thread form with varying pitch a factor here?
G
Grizz1345
My experience has been that each time that you change the anvil and spindle you need to recalibrate the thread mic. I have never been a big fan of pitch mics as the "touch" used can make the difference of pass or fail. It is a quick way of getting close and then check with wires.
Have a great day.
apestate
You are correct, the feel factor of pitch diameter micrometers is substantial. I suppose I should look into this as the source of .0005" error more critically. We do class the pitch diameter mics as +/- .001" instruments, and that's tricky because most class 2 english threads have a tolerance of around .005".
Is the distortion of form error a significant source of inaccuracy? In the hypothetical situation posted above, how would you figure the error created by the distortion of form as measured by a pitch micrometer?
G
Grizz1345
I believe to check the distortion of form you would have to use an optical comparator. We have actually had hardware come from a vendor with the wrong included angle in the threads. I hope this helps.
W Thread Micrometer Standard Tolerances General Measurement Device and Calibration Topics 4
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
apestate Thread micrometer setting standard - Who makes Thread micrometer setting standards? General Measurement Device and Calibration Topics 5
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M NPT thread gauging and the "rapping" process Manufacturing and Related Processes 1
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
Marc Printable Discussion Thread View Elsmar Xenforo Forum Software Instructions and Help 0
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
S Unique ID Required for Thread Gage Replacements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
P Thread recommendation for Cast Iron part Manufacturing and Related Processes 1
K Thread callout - M22 x 1.0-6H 0.100R Thread Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
4 In-House Thread Wire Calibration General Measurement Device and Calibration Topics 5
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
E External Thread Cosmetic/Appearance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Thread Gage Training? Training - Internal, External, Online and Distance Learning 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
A Product Impact When Thread Rings Require Adjustment General Measurement Device and Calibration Topics 9
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
D Roll Form Thread Standard Manufacturing and Related Processes 7
M Thread Gage Longevity Question General Measurement Device and Calibration Topics 6
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
N Free iPhone app - Screw Thread Calculator After Work and Weekend Discussion Topics 0
D Indysoft Calibration Software Thread Plug Template Help General Measurement Device and Calibration Topics 2
K Qualifications I need to adhere to for Thread Gage Calibration Calibration Frequency (Interval) 1
T Inspecting Full Thread Depth with a Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
