Thread Plug Gauge Tolerances
hmandic
Could someone help me point me in the right direction, or explain to me how to determine what the tolerances are for Go/NoGo thread plug gauges. I know that they reference pitch diameters and I am familiar in how they are measured, but I can't seem to find anything that helps me when it comes to what these pitch diameters' tolerances are when measuring. I'm trying to set up, and/or correct our calibration system characteristics for each of the gauges as I'm not sure that what was originally inputted is correct.
Any help is greatly appreciated. Thanks!
Cheers!
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove! :bigwave:
According to Alpha Thread Gage Inc., thread gages are made to Class X tolerances. Their web page has a table showing tolerance by size and feature.
I have no affiliation with Alpha Thread Gage.
dwperron
Cheers!
The ANSI/ASME B1 series of documents are available. They are the bible of thread measurements.
M Thread plug gauge validation/certification ASME vs Asian JJF standard Manufacturing and Related Processes 0
CaliperJim Double Ended Thread Plug Gauge Calibration General Measurement Device and Calibration Topics 9
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
SATHYABALARAMAN Thread Plug Gauge - NO-GO Rejection Criteria General Measurement Device and Calibration Topics 4
M Thread Plug Gauge Design - Width of flat of crest of thread Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R What do "GO" and "NO GO" of a thread plug gauge check? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
P Thread plug gauge failed calibration - Must I remeasure everything measured with it? General Measurement Device and Calibration Topics 23
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
D Indysoft Calibration Software Thread Plug Template Help General Measurement Device and Calibration Topics 2
T Inspecting Full Thread Depth with a Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
L TiN Coated Thread Plug Gauges General Measurement Device and Calibration Topics 12
F Standard regarding the wear of Thread and Plug Gages. General Measurement Device and Calibration Topics 10
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
P Use of ANSI Standard for Metric Thread Plug Gage? General Measurement Device and Calibration Topics 1
R Thread Measurement - Basics on Thread Plug and Ring Calibration General Measurement Device and Calibration Topics 5
L Pitch Diameter for a Thread Setting Plug 4.3750-8 ACME-2G, GO/ NO GO General Measurement Device and Calibration Topics 6
L UN Class 5 Tolerances - Thread Setting Plug Gage 7/8-9 UNC 5 General Measurement Device and Calibration Topics 23
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S NPT Thread Calibration Method - NPT Taper Thread Plug Gages General Measurement Device and Calibration Topics 9
B Method for Calibration of Thread Plug Gauges General Measurement Device and Calibration Topics 13
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
T Johnson Thread View System - Measures many characteristics on a thread plug gage General Measurement Device and Calibration Topics 13
Q 'GO' & 'NO GO' Thread Plug Gage Standard Various Other Specifications, Standards, and related Requirements 17
R Calibration Check Points for ACME & LPT Thread Plug & Rings General Measurement Device and Calibration Topics 5
R Using thread plug gages with helical coil inserts General Measurement Device and Calibration Topics 21
G API REG Pin and Box Threading - Minimum Gages Needed - Thread, Plug and Ring gauges? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
S Why Does a Thread Plug No Go Gage Mean Fail? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
E Counting turns for thread depth, government work Manufacturing and Related Processes 16
M Orthopedic Bone Screw Thread Profile Checking... Magnification? Other Medical Device and Orthopedic Related Topics 1
CaliperJim Screw Thread Micrometer Anvil Calibration General Measurement Device and Calibration Topics 7
A Thread after coating fail Go gauge. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
Zero_yield Thread Necromancy Coffee Break and Water Cooler Discussions 10
R Calibrating Solid Thread Rings with HILO master General Measurement Device and Calibration Topics 1
B Calibration of Thread Gages with Metric Standards with Conversion to Imperial Units General Measurement Device and Calibration Topics 3
G G11 5/8" Thread Manufacturing and Related Processes 0
Miner Reported content: Post in thread 'Form of real time study for establish shelf time' Document Control Systems, Procedures, Forms and Templates 1
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 6
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
