At my working place, we keep a standards board of all the common fasteners that are used. At that phase, the QC inspector is required to pull the fastener off the board and fit test each threaded hole and sign it off as a step on the operation sheet.
what Siijloor says.... is it high volume and/or high precision?
We make threads all day long every day, but the volume isn't so high nor the process so automated that we can't do it manually. Also the capabilities we gone so far as to calculate show that sampling is acceptable.
