Thread Ring Gages - Discrepancies - Is the manufacturer specification wrong?
P
pancho-2007
Hopefully someone can explain this one in more detail. We have a supplier that makes our Antenna end plugs for us and they have a spec of 6.7945 - 6.9723 tolerance on an M7x1 size. However my Ring Gage M7x1.0 6g GO gage is 6.324. Why would there be such a discrepancey for the sizes? From what I can see all calibrated by an A2LA lab uses the 6.324 as the standard for GO tolerance. Is the manufacturer spec wrong??
Hershal
Metrologist-Auditor
Your accredited cal provider does not set the specs for the go/no-go, they only report the measurement.....and they rely on external sources for that requirement.....
It is possible the manufacturer made a mistake.....contacting them with the question may be the best first step.
Hope this helps.
Hershal
Cordon - 2007
Found this in some old notes of mine, used to do incoming inspection.
-M7x1.0 6g 6.974/6.794 (.2745"/.267")
-go gage 6.324
-no go gage 6.212
Hope this helps!
Wayne
Gage Crib Worldwide
pancho said:
We have a supplier that makes our Antenna end plugs for us and they have a spec of 6.7945 - 6.9723 tolerance on an M7x1 size. However my Ring Gage M7x1.0 6g GO gage is 6.324. Why would there be such a discrepancy for the sizes?
I think that you are talking apples and oranges.
The supplier specification of 6.7945/6.9723mm is most likely the major diameter.
Your M7x1.0 6g GO Ring Gage has a pitch diameter of 6.324mm.
What is the class-of-fit specified on the print?
What is the specified pitch diameter on the print?
What is the major diameter specified on the print?
For pitch diameter there are many choices allowed in the thread standard.
Allowance for the pitch diameter: e; f; g; or h
Grade for the pitch diameter: 3; 4; 5; 6; 7; 8; or 9
For major diameter there are a few less choices allowed in the thread standard.
Allowance for the major diameter: e; f; g; or h
Grade for the major diameter: 4; 6; or 8
Other than choices in the standard, major diameters are some times reduced for mechanical reasons by design engineering.
See below the thread specifications for the most common class-of-fit used in he USA, 6g.
Pitch diameter tolerances and other data for M7.000 X 1.000-6g external thread:
Allowance class is................................. g
Tolerance grade for pitch dia. is.............. 6
Tolerance grade for major dia. is.............. 6
Number of starts.................................. 1
Metric Inch
Pitch is......................... 1.000 0.03937
Major dia. is................from 6.974 0.27457
to 6.794 0.26748
Pitch dia. is................from 6.324 0.24898
to 6.212 0.24457
Allowance is....................... 0.026 0.00102
Major dia. tolerance is.......... 0.180 0.00709
Pitch dia. tolerance is.......... 0.112 0.00441
Best wire size is................. 0.57735 0.022730
Constant is....................... 0.86603 0.034096
Max. width of flat at minor dia.. 0.250 0.00984
Min. width of flat at minor dia.. 0.144 0.00567
Max. flat form minor dia......... 5.891 0.23193
Measurement over wires, go........ 7.19003 0.283072
Measurement over wires, no go.... 7.07803 0.278663
The helix angle is....................... 2.881
Or if you prefer 2 Degrees 52 Minutes 53 Seconds
Data generated by: http://www.ring-plug-thread-gages.com/catalogs/thread_check/software.htm
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
K Calibration Requirements for Thread and Ring Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
G Calibration of 200 sets of Thread Ring Gages - Return them to the manufacturer? General Measurement Device and Calibration Topics 19
G API REG Pin and Box Threading - Minimum Gages Needed - Thread, Plug and Ring gauges? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Thread Ring Gauge Specifications General Measurement Device and Calibration Topics 3
S Thread Timing - Ring Gage Frustration General Measurement Device and Calibration Topics 11
C Adjustable Thread Ring Gage Calibration General Measurement Device and Calibration Topics 8
D ISO/Metric Solid Thread Ring Calibration General Measurement Device and Calibration Topics 1
R Thread Measurement - Basics on Thread Plug and Ring Calibration General Measurement Device and Calibration Topics 5
J Thread Ring Gauge UNJ vs UN General Measurement Device and Calibration Topics 11
L Calibration of ring thread gauge with master gauge: How to calculate Uncertainty? General Measurement Device and Calibration Topics 1
Q Tolerance Set Plugs to Calibrate Thread Ring Gage - Question General Measurement Device and Calibration Topics 4
U Calibration House - Where I can get a PG 13.5 Gut thread ring gage calibrated? General Measurement Device and Calibration Topics 1
D New thread ring cannot be threaded onto the truncated part of the master General Measurement Device and Calibration Topics 4
J Calibration, should we.... Go-No-Go, thread, pin, and ring gauges QS-9000 - American Automotive Manufacturers Standard 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M NPT thread gauging and the "rapping" process Manufacturing and Related Processes 1
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
Marc Printable Discussion Thread View Elsmar Xenforo Forum Software Instructions and Help 0
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
S Unique ID Required for Thread Gage Replacements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Thread recommendation for Cast Iron part Manufacturing and Related Processes 1
K Thread callout - M22 x 1.0-6H 0.100R Thread Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
4 In-House Thread Wire Calibration General Measurement Device and Calibration Topics 5
E External Thread Cosmetic/Appearance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Thread Gage Training? Training - Internal, External, Online and Distance Learning 3
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
A Product Impact When Thread Rings Require Adjustment General Measurement Device and Calibration Topics 9
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
D Roll Form Thread Standard Manufacturing and Related Processes 7
