Three ISO 17025 Questions
isolisa
Hi All:
I need a little assistance with the ISO 17025 Standard. My company is ISO 9001:2008 Certified, so here are the questions:
1.) It appears that I need to create a "sub-Quality Manual" for our Calibration Lab, complete with it's own Quality Policy Statement.
2.) It seems as if we need to hold at least one additional Management Review just for the Calibration Lab?
3.) Can I modify my current Company Standard Procedures to accommodate 17025 (i.e.: Contract Review, Purchasing, etc.), or do I need to recreate the wheel?
Annex B in the Standard has me a bit perplexed; it appears that one can go either way on documentation. Any help would be greatly appreciated.
Lisa
qusys
Re: ISO 17025 Questions
Hi Lisa,
I would like to know if you are trying to apply for ISO17025 and if it is necessary for your business too.
Are you a Lab that provides external services?
If not , ISO 9001 is enough.
To have ISO 17025 is a cost and should be part of strategical decision too.
To respond to your question 1 and 2 , it needs a manual for your Lab if you will pursue ISO 17025, including management reviews of hte related activities and process.
Hi All:
Lisa
isolisa
Yes, we do calibration work, for our product line. At this point, we're looking at going after accreditation. Of course, to a small company (25 people), cost is a big factor :) I'm trying to get all my ducks in a row before I discuss this further with the Company President.
It looks as if there will be extra paperwork, as anticipated. But if I can wedge a good chunk of the requirements into existing paperwork, that's less maintenance along the way....
qusys
Which kind of calibration work do you perform? What type of production do you do?
Does you Lab calibrate gages ( such as powermeters, voltmeter, hoscillope and so on ) that the technicians use when they perform maintenance activities on equipment?
If so it is not required ISO 17025 , because Lab is only internal.
You shall only respond to 7.6 clause of ISO 9001.
On the other hand, ISO TS 16949 for automobile sector has more stringent clauses of Laboratories requirements.
Hope this helps
Hi All:
Lisa
Unless you are planning to have your internal cal lab accredited under 17025, there is no need to create a new system for it. You can put it all under the general aegis of your 9001 QMS.
isolisa
Our Cal lab would be certified (btw, it does fall under the realm of our 9001:2008 Cert). We manufacture (and calibrate) Calibrators; our customers send product in for us to Recals.
I'm guessing that this accreditation would be to appease the foreign customer base. It doesn't seem like getting the paperwork in order would be *too* time consuming, but I'm not sure. If I need to write specific procedures just for our Cal Lab for 17025; that's two sets of doco that needs to be controlled, etc. yuk.
Sarge
Hello Lisa,
It sounds like I am in a situation similar to yours. We are investigating 17025 as an internal testing lab for only our company and then expanding to the calibration of our products delivered to or serviced for our external customers.
Some other things that need to be considered are:
• traceability of your standards
• proficiency testing to prove the competency of your technicians
• validation of your procedures
These are by no means insurmountable obstacles but they things that need to be considered when weighing the ROI of accreditation.
Hope this helps,
Sarge
CalRich
isolisa,
I worked in a situation just like yours - the main company ISO 9001 registerd and the calibration lab ISO 17025 accredited. We (unfortunately) in the lab maintained a separate quality system. It was in one sense not so hard because there were only 10 people involved, thus document control and record keeping wasn't so hard. Later on, there was need for the company's testing lab to become 17025 accredited as well. That accreditation, however, was tied to the main QMS.
Ideally, it's better to have the "Company X quality system" and include all of the standards applicable for the company. Since many common standards (9001, 16949, 17025...) all require certain fundamental elements (document control, management review, etc.), it seems better to marry them all into your one corporate QMS. You just have to take into account there ARE differences in them. (ISO 17025 is a competency standard, for example. It's not just another flavor of 9001.) Ensure you are meeting the intent of each standard in your company management system.
If you can pull it off, merge it with your existing QMS.
Hershal
Metrologist-Auditor
Isolisa, some hopefully simple answers.
First things first. Get to a training session on ISO/IEC 17025, so that you have a good grasp on the application of the Standard. Also, make sure you have and read the Standard.
Also, get training on measurement uncertainty. It is a requirement for accreditation for calibration.
You almost certainly will need a manual for the lab itself. Where the ISO 9001 manual ADEQUATELY addresses the topics in ANS/ISO/IEC 17025:2005, then piggy-back on that. However, you will find that much of the time, that will not be the case, as 17025 has specificity in requirements that 9K does not. Address those differences in the lab manual.
You will need an internal audit and Management Review prior to any accreditation assessment, and should do them anyway to make sure everything is implemented. Now having stated that, both can dovetail onto the parent audit and review; however note that there are requirements for the lab. The audit must include not just the QMS, but also the technical component of the lab. The Management Review can be included in the parent's review, but note that 17025 has a prescriptive agenda in Clause 4.15.1, and the topics must be easily identifiable within the review if combined with the parent.
Lower level procedures can be modified, and should make it a bit easier for you. Remember, 17025 may well have additional specific requirements that must be taken into account.
One last point. Regarding accreditation, there are six internationally recognized accreditation bodies (ABs) based in the US. Do NOT sign with ANY of them until you have had some in depth discussion with ALL of them. And make sure that you are talking with technical folks, not just sales people. Remember, the assessment requirements include technical review so you should have confidence and comfort that the AB understands your needs.
Hope this helps.
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Beginner in ISO 45001 here! Three questions Occupational Health & Safety Management Standards 6
L Templates for three ISO 13485:2016 SOPs ISO 13485:2016 - Medical Device Quality Management Systems 8
D Gap Analysis - Three months until our ISO/TS 16949 3rd party surveillance audit IATF 16949 - Automotive Quality Systems Standard 4
A Recertification of ISO 9001 QMS? Three year cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
Marc ISO 9001 Three Year Recertification Audit Requirement(s) - Complete Reaudit Registrars and Notified Bodies 6
I Three Combined Systems - An IQMS if you will - OHSAS 18000, TS 16949 and ISO 14001 ISO 14001:2015 Specific Discussions 10
C ISO 14001 Requirements - Three Basic Questions Miscellaneous Environmental Standards and EMS Related Discussions 2
B Toyota PPAP Process - Three Questions APQP and PPAP 3
R Problem solving activity - Three hours to fix the issue Manufacturing and Related Processes 15
S How to number and control translated SOPs - Three languages Document Control Systems, Procedures, Forms and Templates 4
I Flatness - Rectangular part using the three jack method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B Variable Gage R&R - Two operators instead of three Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
Marc Hackers unleash smart Twitter phishing tool that snags two in three users IEC 27001 - Information Security Management Systems (ISMS) 7
M Three final products in one biocompatibility test? Other Medical Device and Orthopedic Related Topics 2
R FDA released three guidance documents for Medical Devices - August 2014 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Is it mandatory to revise MSDS every three years? ISO 14001:2015 Specific Discussions 3
E ANOVA for Taguchi method - Four factors and three levels and nine runs (Minitab) Using Minitab Software 6
Ajit Basrur India marks three years since last polio case Hospitals, Clinics & other Health Care Providers 2
S Three Questions on Finished Medical Device Traceability, Labeling and Packaging US Food and Drug Administration (FDA) 3
C Optimize One Response with Three Variables Using Minitab Software 8
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
B Three Sub-Companies - Is One Quality Manual Enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Three Best Practices and Lessons Learned in APQP APQP and PPAP 1
H Do we need all three AS9102 forms if we manufacture only Piece Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I Analysing the data from three different cavities of one mould Quality Tools, Improvement and Analysis 4
P Monitoring Production Defects - Three simple questions Six Sigma 3
L I have four groups to compare, and each group has three samples Using Minitab Software 4
N What are three kinds of flow in Lean or Six Sigma? Lean in Manufacturing and Service Industries 4
B What is the psychology behind three rings? Customer Complaints 8
Marc Customer Service - Three Stories About Improving Customer Service Funny Stuff - Jokes and Humour 3
J Calibration of Micrometer Reading up to Three Decimals General Measurement Device and Calibration Topics 3
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
T Constant for a M3x.35 Set Plug using the "Three-Wire Method" Calibration and Metrology Software and Hardware 2
AnaMariaVR2 FDA has issued three Warning Letters... US Food and Drug Administration (FDA) 13
F Differences among three locations with respect to mean selling price - Minitab help Using Minitab Software 2
R How to determine the reference voltage for three-phase transformer? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
Marc Three Email Topics Funny Stuff - Jokes and Humour 3
S Best wire size for 'three wire method' to measure pitch dia. of asymmetrical thread General Measurement Device and Calibration Topics 2
L Proposal to Senior Management - Three options for our new CAPA process Quality Manager and Management Related Issues 2
N DFM, DFA and POKA YOKE - Are these three related? Manufacturing and Related Processes 4
Marc Three-Inch Device Detects 3,000 Types of Viruses and Bacteria World News 0
P Panic time! Audit in three days! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Top Three Reasons why TPM (Total Productive Maintenance) Initiatives Fail Manufacturing and Related Processes 39
Hershal Only THREE foods - Informal sharing of tastes Coffee Break and Water Cooler Discussions 17
P Determining Sample Size - Filling a bag with three different types of candy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
T Gage R & R Study "Best Practices" - More than three operators? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S The Three Jars! Brain Teasers and Puzzles 4
M Chi Square Help - One of my variables has three possible results Using Minitab Software 15
