Tie-wrap pull test to verify contact retention
V
Vthouta
Did anyone execute tie-wrap pull test to verify contact retention???
If yes, Could anyone let me know on how to conduct cable-tie wrap pull test??
Recently, we had a rejection on one of the PCB board that has a ty-wrap installed to one of the inductor.
Ty-wrap: http://www.amazon.com/TY24M-Stainless-Military-Specified-MS3367-5-9/dp/B00B2EYBDK
http://www.tnb.com/ps/fulltilt/index.cgi?part=ty24m
Data sheets and technical specifications are available at the above links.
Thanks in advance
Vik
V
Vthouta
I'm not sure on how it was installed, but they have reported it as tie-wrap broken. We manufactured 400 units in the same way and our customer reported only one broken tie-wrap in the entire lot. Couldn't deduce whether it was an operator error or had a nick on the wire during installation which led to broke during shipping.
Sean Kelley
Can the customer provide more detail such as a photo or maybe even return the failed part? From your description I interpret it as a broken tie meaning there was something weak such as a void in molding perhaps or some other reason that could make it break under load.
The most likely cause was that the wrap was nicked when the excess was cut off. The strength of these wraps are high enough to damage your PCB and components if cinched too tight.
V
Vthouta
Sean - Unfortunately, we didn't get any picture and when the board was send to troubleshooting our team has scrapped the tie-wrap and fixed it with new one. It was so late that I couldn't get the broken tie-wrap to my desk.
Miner- Right now, I've been trying to document the CA for this issue. As part of the corrective action, I wanted to test a few samples by conducting the pull test and make sure we are getting right parts sourced to us. In this way, out customer would have more confidence instead of stating human error or probable nick on the tie-wrap might have led to this issue.
I'm assuming pull test data will satisfy the corrective action and gives us more confidence on supplier, trying to be proactive rather than reactive.
I appreciate your quick responses.
somashekar
There is no meaning in a corrective action without an analysis and finding the root cause...
When you test a locked tie-wrap in a pull test, you may get a very high value at break or stretch, further leading you no where.
When pulled and locked (Perhaps with more force then necessary), the tie-wrap will be in stress, and a small incession from any sharp edge can snap it off. :2cents:
S Tie Wrap Tensioner Tool Calibration Requirement General Measurement Device and Calibration Topics 2
S In a risk analysis, how can we tie mobile app security breach to ISO 14971? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Context SWOT tie to ISO 9001:2015 Cl. 6.1 Risk and Opportunities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Tie in Context - Interested party - Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M What is the lightest material to make a Strong and Light Ratchet Tie Down Strap Manufacturing and Related Processes 1
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
R MS90387-1 Tension Verification Tool for Cable Tie Gun Manufacturing and Related Processes 1
S Do you tie a Nonconformance (NC) into the last Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Function of a Change Number in our ECN / document vault program as a tie-in Problem Solving, Root Cause Fault and Failure Analysis 3
D Is there a need to tie NC found during internal audit to relevant ISO clauses? IATF 16949 - Automotive Quality Systems Standard 13
R Layered Audits - Where to tie the layered audit process back to FMEA & Control Plan FMEA and Control Plans 10
F Generic Check List - What part of the standard can I tie these inputs and outputs to? IATF 16949 - Automotive Quality Systems Standard 7
N QS Training - Trying to tie training in with job descriptions Training - Internal, External, Online and Distance Learning 1
N QS Training - Am trying to tie training in with job descriptions QS-9000 - American Automotive Manufacturers Standard 2
J Source for calibration stickers - Narrow "For Reference Use Only" wrap-a-round General Measurement Device and Calibration Topics 4
P Need Tape Spec for MSCH 62 Full Tape Wrap & MSDC 13-B Spot Tape Various Other Specifications, Standards, and related Requirements 3
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
K Cord anchorage pull test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
8 Creating Flow and Pull Game Lean in Manufacturing and Service Industries 1
M Informational FDA Panel: Too early to pull textured breast implants over cancer risk, need more data Medical Device and FDA Regulations and Standards News 0
D minitab macro to pull access query with parameters Using Minitab Software 1
A The Pull System and how Quality Control fits in Quality Manager and Management Related Issues 11
D Manual Tensile Testing Pull Rate Speed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Is there a standard for Pull Test for Ultrasonic Welded Parts? Manufacturing and Related Processes 4
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D IPC WHMA-A-620A vs. UL UL468A - Pull Test or Crimp Height Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Electrical Cable Harness Quality Control - Sampling Plan for Pull Test Manufacturing and Related Processes 4
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T The best way to pull some meaningful stats from a really big project? Using Minitab Software 3
D Mixed Level Pull Simulation - Stock Evolution and Machine Load Lean in Manufacturing and Service Industries 3
2 MIN/MAX - Oversea Supplier Raw Material Supermarket Pull Systems Lean in Manufacturing and Service Industries 3
T How do I control web-based asp forms/rpts that write to and pull from an Access DB Document Control Systems, Procedures, Forms and Templates 4
C Analyzing Attribute Data - Mechanical Pull Testing of Joint Statistical Analysis Tools, Techniques and SPC 15
S Wire Pull Tensile Testing - Splice with multiple wires Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Protocol for Validating Pull Tester and Force Gage Qualification and Validation (including 21 CFR Part 11) 9
J Reduction of Pull Off Test Inspection Frequency - Capability Query Quality Tools, Improvement and Analysis 1
A Marketing & Distributing Definitions - FDA to pull non-510k devices off the shelves Other US Medical Device Regulations 2
E Push or Pull Induction and Competency Training Method for New Employees Training - Internal, External, Online and Distance Learning 3
C Gauge R&R %Tolerance Template for One-sided Tolerance - Wire Pull Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Z In-Process Pull Test - UL-486 or EIA-364-38? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Pull test standard? Wires coming off the electrodes at the weld ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L What kind of Gage R&R is needed for a Pull Test Machine? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
W How do we make a Pull System if operations are in different buildings? Lean in Manufacturing and Service Industries 11
A Kanban cards for single pull - Looking for template Six Sigma 2
C Sample Size in Destructive Pull Test and Interpretation of Test Result IATF 16949 - Automotive Quality Systems Standard 5
A Xbar-R chart question - Wire Pull Test - Different Wire Sizes Statistical Analysis Tools, Techniques and SPC 12
L Kanban cards - Trying to initiate a true Pull System - Fastener Products Lean in Manufacturing and Service Industries 3
H Destructive Tensile Pull Test Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
E MSA requirement for destructive Pull out test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
