Tier 2 & Tier 3 Documents Numbering scheme (Level 2 and Level 3) documents
Steelwoman
#21
We use a different but VERY simple numbering process, which is the TYPE of procedure followed by a number, then we reference the applicable section of the standard within it. EXAMPLE: Our Lab procedures are LB-01 etc - our Temper mill procedures are TR-01 etc, our Doc/Data are AD-01 (administrative), etc. Makes it easier to FIND/remember what is what, each operation (machine) knows what their procedures are under on our Intranet; a brief table of contents makes it clear what is what for an auditor. Seems to work really well.
E Wall
Just Me!
#22
Okay, I'm in with my 2cents :)
Our Format:
Level 1 - Quality Manual/Quality Policy
Level 2 - QC Procedures
#ing examples: Take the 4 off the ISO Element number and use: QCP-0100, QCP-0500, QCP-0502, QCP-1400, etc...[I just chose randomly for examples]
Level 3 - Work instructions, SOPs, Drawings, etc....
CWI-05-QAD-0001 (Columbus Work Instruction-ISO element 4.5-Mgmt responsibility to what department-sequential # start with 0001)
SOP-000 - The authorization block identifies department, key process, parent document, how many copies posted, approval signatures, title, etc..
Drawings - Heck the Engineers don't even know how they're numbering them anymore - from my 3 years here...it seems they just go from 111### & up
Level 4 - Forms
CF-Q-05 (Columbus Form - Department - numerically sequential number) Revisions go up numerically as well
I still have not decided what to do with the clause scheme change - I certainly don't plan on renumbering everything so I'll fill in with gap measures.
Trakman
#23
Energy,
Yes I can understand that someone changed our favourite recipe and suddenly we are lost. Our magnificient brilliance goes away. We are getting registered to the 9001:94 standard, so my time is also limited to cling to the 94 version elements.
As a suggestion, take the new standard and put it into a flowchart, taking advantage of the fact that there is a pattern to each top level section.
Example; 7.0 Product Realization: starts at planning and ends with production/service, and with the old familiar IMTE at the end.
Do the flowchart (in Visio or your pet program) and stick it onto the wall above your monitor.
Look at it and Think about it for a few months, before you change anything.
I read an article in a business owners magazine once upon a time, and they suggested that to solve a problem;
keep thinking about it,
keep it in front of you,
ask other people for their ideas,
and it will hit you.
Keep being inventive.
Trakman.
CarolX
#24
Here's my nickel (2cents + inflation)
Policy manual - elements listed in the ISO9k/94 format
Procedures -
QP00-xx
Q=quality
P=procedure
00=year document was created
xx=sequential numbering
Work instructions
QP00-xx-WIxx
ties directly in to the applicable proceure
Forms
QP00-xx-xxx
again - ties directly to the applicable procedure.
Just another way to skin the cat.
CarolX
Steve Durr
#25
Our small company is in the process of implementing ISO-9001, and we have a fairly basic and simple Numbering System. We have two letters to designate the department that the procedure pretains to. Then we have a letter to designate the type of document, followed by a 3 digit sequential number. For example, EN-P003 would be an engineering procedure, while PR-F014 is a production form. The title of the document follows the document number.
This system seems to work all right for us.
Later,
Steve
K
KayJay
#26
My suggestion is that please do not spend much time! Just think it one second!
You could choose one of already given way.
Will you reformat D/N-system when you should upgrade to ISO9000:2000 or TS16949?
Number is just number!
Even sequence number; 001,002,003...may good enough. :D
I'm trying to make a tool that user could use for identifying document what they need and verifying their document is currently valid one.
Thanks.
KayJay
Trakman
#27
Hello Kayjay
RE: Verifying current document.
The thought dawned on me that for large manufacturing companies that support bar-code labels, a bar code label could be applied to the document. It could be quickly scanned and the display tell you if it is vaild or not. For smaller companies, (and ourselves) we rely on our document databases (project/product/management, etc...) to look up manually the document to check validity.
Keep being inventive. :)
Trakman.
N How are YOUR tier 2 documents numbered? Document Control Systems, Procedures, Forms and Templates 16
optomist1 Survey of Tier 1 & Tier 2 suppliers APQP and PPAP 6
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
J AS9104-1 Clause 18.1 (a) (b) - Organizations (contractor) shall be required to allow access to Tier 2 data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
noratkhen Eligibility to get a IATF 16949 certificate for a Tier N>3 supplier? IATF 16949 - Automotive Quality Systems Standard 25
L Informational IATF 16949 certification requirement for Tier 2/Tier 3 Suppliers IATF 16949 - Automotive Quality Systems Standard 15
J IATF Minimum Automotive Quality Management System Requirements for Sub-Tier Suppliers IATF 16949 - Automotive Quality Systems Standard 12
D Supplier Scorecard, Assessment of Pass Through Items From Sub Tier Suppliers Supplier Quality Assurance and other Supplier Issues 4
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
xfngrs CQI-19 Sub-Tier Supplier Management IATF 16949 - Automotive Quality Systems Standard 1
P Tier 2 Part Approval where Painting is Outsourced APQP and PPAP 2
Manix Automotive Warranty Process at Tier 1 Level Challenges and Development Considerations Quality Manager and Management Related Issues 2
Buckyb Boeing QMS Requirements for Tier 2 Distributors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
R Tier 2 Laboratory Accreditation IATF 16949 - Automotive Quality Systems Standard 3
M Key Supplier Risk Mitigation - Supplier Changes or wants to change Sub-Tier Suppliers Supplier Quality Assurance and other Supplier Issues 5
M Are OEM requirements (CSR) applicable to Tier 2 Suppliers IATF 16949 - Automotive Quality Systems Standard 3
J We anneal aluminum tube (tier 2, bulk material) - Does CQI-9 apply to us? IATF 16949 - Automotive Quality Systems Standard 4
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
P Problem with TS 16949 System Scope in Tier 2 Company IATF 16949 - Automotive Quality Systems Standard 3
T Diversity Vendor (Supplier) Requirements for Tier 1 and 2 Companies Customer and Company Specific Requirements 3
H Tier 1 ISO/TS 16949 Subscribers (Origin of TS 16949) IATF 16949 - Automotive Quality Systems Standard 9
B Supplier Development - TS 16949 Flow Down Requirements - Tier 2 Supplier IATF 16949 - Automotive Quality Systems Standard 13
K TS 16949 Tier 2 Customer Specific Requirements? IATF 16949 - Automotive Quality Systems Standard 9
T Reopening a Closed Division - Multi-division tier 2 automotive supplier IATF 16949 - Automotive Quality Systems Standard 7
P Must show Sub-Supplier details? Supplying a Tier 2 company IATF 16949 - Automotive Quality Systems Standard 7
V Are Customer Specific Requirements applied to the second tier suppliers Customer and Company Specific Requirements 14
M Tier II Automotive Paint Shop - questions questions questions IATF 16949 - Automotive Quality Systems Standard 9
J Chrysler Gage Standard - Gage standard for all Tier II stamping gages Customer and Company Specific Requirements 3
G Manufacturing -> Warehouse -> Tier 1/OEM - Process flow, PFMEA, & Control Plan FMEA and Control Plans 9
P Two tier objectives - ISO 14001 Objectives and Targets ISO 14001:2015 Specific Discussions 10
R Approved Vendor (Supplier) if Customer Pays Sub-tier Shipping Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Supplier PPAPs - Self Certified - First tier supplier to Ford APQP and PPAP 1
D Are FIR's performed per AS9102, either at Tier 2 or from Tier 3's? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D TS 16949 and Control Plans - Need Tier II/III follow AIAG Annex A Format? IATF 16949 - Automotive Quality Systems Standard 27
W Eligibility of Tier 2 supplier of forged parts to get TS 16949:2002 certificate IATF 16949 - Automotive Quality Systems Standard 13
B Can I use Multiple Sub-Tier Suppliers for the Same Part Number APQP and PPAP 2
M What are the Ford Tier 1 Requirements Customer and Company Specific Requirements 3
Q QS9000 Tier 2 for 12 Years - Transitioning to ISO9001 - Where do I start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
S PPAP for my tier 3 suppliers - Sub-Supplier Process Changes APQP and PPAP 16
B TS 16949 CSR for GM Tier 2 Machining Sources Customer and Company Specific Requirements 2
V Ford 2nd Tier info - Ford is asking us for a list of all of our suppliers Customer and Company Specific Requirements 29
A Definition Tier one, Tier two and Tier three suppliers? What do these mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
T Second Tier Laboratory Requirements for TS 16949 IATF 16949 - Automotive Quality Systems Standard 3
D Supplier QMS Development - Tier 3 integrated circuit supplier to automotive Supplier Quality Assurance and other Supplier Issues 4
L Are we a tier 1 or a tier 2 supplier? Supplier Quality Assurance and other Supplier Issues 3
A How is APQP flowed down to sub-tier suppliers in the automotive industry? APQP and PPAP 5
T Design responsible? Tier 2 / 3 manufacturer of steel products - TS 16949 Design and Development of Products and Processes 6
R Who is the "customer" in TS 16949? Are we are tier 2 or 3 of an OEM? IATF 16949 - Automotive Quality Systems Standard 3
F Who pays for DVP? Subcontractors or Tier 1 Supplier? APQP and PPAP 1
K PPAP basic help needed - Tier 1 automotive supplier for an electrical wiring harness APQP and PPAP 4
