To Calibrate or Not to Calibrate various Weight Scales
michaelkhart
I have a client that has weigh scales in both their receiving department and mixing department. They use the scales for overall verification of weights when materials come in and when materials are mixed together in a vat. Although they verify that the weight measurements they are getting from the scales are in the ballpark by checking with objects of known weight, they are not concerned with the level of precision for either application. The mixed materials undergo specific visual inspections later on in the process and they have never had an issue where the mixed product had to be rejected. They have assessed the risks of mixing with a weigh scale used for reference only and have decided that the cost of verification/calibration is much more than the cost due to risk of product batch failure. Therefore, since product inspection related to proper mix of materials is carried out later on in the process, they have decided to remove the weigh stations from a calibration program and label them "not calibrated - use for reference only".
Personally, I agree with their reasoning, and their right to make this decision. As long as their product quality is protected through the product inspection later in the process, the organization should be able to weigh the risks/costs of calibration. Thier ISO 9001 Registrar may not agree.
What are your views?
michaelkhart
Re: To Calibrate or Not to Calibrate
It means that they have assessed the potential probability and costs of having to reject and scrap a batch of mixed materials because they did not have the mixing room weigh scale on a formal verification/calibration program.
Duke Okes
It's not the registrar's decision. It is a business decision made by the company, with rationale they can support with data.
somashekar
Hello Michael.
There are two aspects here.
1. Statutory:
I do not know where you come from, but over here in India, all industrial and commercial weigh scales are coverd under the department of weights and measures and they are duly stamped. These have to be renewed every year by approved evaluators of the department which is a government body. Every weighscale purchased is delivered with the stamping on the label and a certificate. Please check if something similar applies in your region.
2. Requirement:
What ever be the ballpark tolerance that is acceptable, still this measure does fall under the monitoring and measurement that is undertaken and hence this monitoring and
measuring equipment (weigh scales) needs evidence of conformity of product to determined requirements. Hence calibration, and the above will meet this if such a statutory operates in your region.
samsung
They can skip calibration of the weighing scales at this stage if these devices aren't used for determining the acceptability of products or process parameters. However, it's also implied from your above statement that they are using calibrated equipment later on in the process in order to qualify the product quality.
michaelkhart
The inspection later on in the process is visual and include appropriate instructions and colour templates that look for applicable characteristics of the mixture.
Stijloor
Let's assume that due to some inadvertent mishap, the scale is off by some weight value, you would have no way of knowing..and how would that affect the process/product?
Stijloor.
samsung
Stijloor.
As the OP submitted in the first post that they are verifying the scales against some known weights.
samsung
Since the requirement of calibration falls under section 7, it's permissible to exclude calibration from the scope specifying valid justification.
D Lesser expensive to calibrate various test weights General Measurement Device and Calibration Topics 5
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
I Can I Calibrate On Demand? General Measurement Device and Calibration Topics 9
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
F Crimper Calibration - How do you Control & Calibrate your crimpers? Calibration Frequency (Interval) 13
P How to Calibrate a HP 3458A Digital Multimeter with Fluke 5080A calibrator General Measurement Device and Calibration Topics 1
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
K New Kilogram - The process we use to calibrate the standards General Measurement Device and Calibration Topics 6
D How to Calibrate any Digital Sphygmomanometer under use for 2 years in a Hospital Forum News and General Information 1
L Re-calibrate after software update? Calibration Frequency (Interval) 3
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
N Calibrate temperature on refrigerated Centrifuges? General Measurement Device and Calibration Topics 2
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
P How do you calibrate a VNA (Vector Network Analyzer) cal kit? General Measurement Device and Calibration Topics 4
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
bobdoering Who says you can't calibrate a steel rule! Funny Stuff - Jokes and Humour 17
S How can I Calibrate a Biosafety Cabinet? General Measurement Device and Calibration Topics 1
C How to Calibrate a Viscosity Tester General Measurement Device and Calibration Topics 3
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
C How to Calibrate a Medical Infrared Thermometer General Measurement Device and Calibration Topics 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
J What do you use to Calibrate 40" Calipers General Measurement Device and Calibration Topics 10
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
C Tolerance Estimation of a Load Cell I want to Calibrate General Measurement Device and Calibration Topics 9
D Procedure on How to Calibrate a External Micrometer General Measurement Device and Calibration Topics 1
B ISO/TS 16949 Section 7.6.3 - Use of Manufacturer to Calibrate IATF 16949 - Automotive Quality Systems Standard 21
W How to verify/calibrate a Neptune Water Meter General Measurement Device and Calibration Topics 4
N Laboratory that is able to Calibrate Dew Point Meter up to 60?Cdp - Needed General Measurement Device and Calibration Topics 1
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
C How to calibrate or control patterns for fiberglass General Measurement Device and Calibration Topics 4
N Scale with Internal Calibration - Do I need to calibrate? How to document this? Calibration Frequency (Interval) 8
I Need help finding an Accredited Lab that can Calibrate Brunson 76-RH Survey Transits General Measurement Device and Calibration Topics 5
M Controlling Temperature and Time - Do I need to calibrate the thermostat? IATF 16949 - Automotive Quality Systems Standard 4
D How much Tolerance do I use to Calibrate a 150kgs capacity Scale? General Measurement Device and Calibration Topics 5
N Thermocouple Inhomogeneity - Need to calibrate a roll of 50m thermocouple type K General Measurement Device and Calibration Topics 3
J Calibrate before use required? Inspection Gages and Measurement Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Traceability for Mercury Argon Calibration Source to Calibrate a Spectrometer? General Measurement Device and Calibration Topics 5
P How to Calibrate Laser Micrometer when no Calibration Company in the Country? General Measurement Device and Calibration Topics 3
S 3 Point Calibration or Calibrate to Extreme High and Low? General Measurement Device and Calibration Topics 9
C Seeking a holder/jig to calibrate large OD micrometer calipers (up to 23") General Measurement Device and Calibration Topics 8
S Is it OK to calibrate a measurement device tighter than manufacturer specifications? General Measurement Device and Calibration Topics 18
B Difference between Calibration & Verification and How to calibrate Go/No Go gauge? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W ASTM Spec or what standard is used to calibrate calipers? General Measurement Device and Calibration Topics 2
