To ensure that document changes are identified...
G
global citizen
Is Document revision history being implied as a requirement here? I am planning to create a spreadsheet to show the revision history for our documents. However, I am reading that some say it is not required. But how do you identify the changes if you don’t have a record of it? How do you have a record of document revision history if you ‘forget’ the previous revisions?
I was thinking of doing what some say showing the changes in bold or italic text but if we are going to remove some portions of a document as a revision, then there is nothing to bold or italicize. Therefore, a log would be needed. Also, down the road, in tracking Improvements, wouldn’t document history be relevant to show on how much you have changed the system and are improving?
Any inputs? Thanks!
:read:
SteelMaiden
what will work best for you? Some folks save copies of each version for reference, some folks have selected some key documents that they want to save a copy of each version. Some have a listing of the changes right with the documents (last page or whatever) some just summarize the changes in a data base.
So, you have to work with what you have. You create the system that will best work for you and your employees. Again, don't make this so difficult that nobody would ever be able to step in and do your job if they needed to. Make sure the system makes sense, and people understand at least the basic concepts.
I will tell you what I am doing now, (although we will soon be moving to another system). This does not mean it is the only way to handle revs, nor does it mean it is the best. It just works for us and works well.
Revs are denoted within the body of the document by placing a | (pipe symbol) at the point of revision. The actual changes are summarized in our document control database. If something was removed, we insert a quote of the removed text. If added, we say Added "xyz" in whatever section. We do have some specific documents that we save a copy of each version for in a folder called obsolete documents, for reference only.
ccochran
GlobalCitizen,
Steelmaiden's advice is right on the mark, as usual. Here are some additional thoughts. There are 3 main purposes for identifying changes to documents:
1) Letting document approvers know what has changed, so they know what they're being asked to approve.
2) Letting document users know what has changed, so they don't have to search through the document and guess what's new.
3) Creating a history of what was done in the past, just in case we get into a bind and need to know this.
Purposes 1 and 2 will be closely tied to whatever format your deliver your documents in. I have always used a cover sheet of some sort, even with electronic documents, and this creates a quick and easy place to identify changes. I've also seen change histories at the end of documents. The technique of weaving the changes into the body of the document (with bold text, cross-outs, whatever), while brilliant in theory, doesn't really work that well. Firstly, it requires that people search through the document and see what changed, which is exactly what you're trying to avoid. Secondly, people often screw up the 'track changes' faeture and the document becomes a mess. Thirdly, it adds a level of complexity to the document that's not really necessary.
Personally I would recommend that you put a "Changes in the current revision" section on the cover sheet of each document, or a "Change History" at the end of each one. There are, of course, many other ways to meet this requirement, but these are the 2 ways that seem to work with the least hassles and most effectiveness.
Happy doc controlling,
Craig
V
Valeri
What we use: red/bold/italic for changes and strikethrough text for anything to be removed. We have a change history in each page identifying the rev.#, section revised, change made and date.
H
halfhog
Hope this is the best place for this.
I am at odds with a superior on the best way to handle the creation and format of work instructions. Through trial and error we have found that what works best for the shop as far as work instrcution go is to have them short, detailed enough to follow and be successfull but without all of the following as part of the instruction itself; "The document has to be in our standard format…it has to have a header, rev level, rev history, etc…those are all requirements." The revision page on the front follwoed by the Scope, Purpose etc.. is not pertainent information to them. They need steps to follow period. I belive that a short title at the top and putting the rev level on the last page at the bottom(footer) would be sufficient and maintaining a spreadsheet of changes NOT attached to the actual work instructions is the way to go and still satisfy requirements. any feedback is greatly appreciated
Note: we are ISO9001:2000 / AS9100 certified and are having our first recertification audit tomorrow through ffiday.
Stijloor
I am at odds with a superior on the best way to handle the creation and format of work instructions. Through trial and error we have found that what works best for the shop as far as work instruction go is to have them short, detailed enough to follow and be successful but without all of the following as part of the instruction itself; "The document has to be in our standard format…it has to have a header, rev level, rev history, etc…those are all requirements." The revision page on the front followed by the Scope, Purpose etc.. is not pertinent information to them. They need steps to follow period. I believe that a short title at the top and putting the rev level on the last page at the bottom (footer) would be sufficient and maintaining a spreadsheet of changes NOT attached to the actual work instructions is the way to go and still satisfy requirements. any feedback is greatly appreciated
You can use any format you want.
If the information helps the employee to be:
  • Safe
  • Effective and
  • Efficient
then the work instruction has met its intent.
Stijloor.
ccochran
Halfhog,
I agree with you. Keep work instructions as lean and concise as possible. Certainly don't add sections like purpose, scope, definitions, etc, unless they are absolutely necessary. One of the biggest documentation mistakes I see is the tendency for companies to think that all documents must all look the same with the exact same format. I would strive to keep work instructions to a single piece of paper (real or virtual) and as graphic as possible. A cover sheet could be forsaken in favor of a slightly more detailed header or footer. The approach you described sounds perfect. Now you just have to educate your superior. For whatever it's worth, I've attached an old article of mine entitled "Lean Management System," which addresses some of the paradigms you're facing.
Good luck,
Craig
howste
Thaumaturge
Sounds great! I don't like people to have to wade through pages of stuff to get to the information they're looking for. Give it to them in a format that allows them to find the information they need as quickly as possible so they can get back to doing the real work.
Z
zancky
Hi, all good comments,
May I add one point of view about "Is Document revision history being implied as a requirement"?.
Some customers require to keep data for 10 years, but data are nothing if You don't have a copy of all procedures and related documents You used to generate them. So for some documents like drawings, measuring protocols , customers specifications in force etc, You need to keep on all the versions, no way.
howste
Thaumaturge
It sounds like you have a medical device or pharmaceutical background? In ISO 13485, there is an explicit requirement to maintain at least one copy of controlled documents for at least as long as the affected records. If you are already doing this, then you don't necessarily need a change log. However, a change log (summary) is a lot easier to use to quickly identify what the changes were. What do the system users need? That's the question...
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N How to ensure our employees don’t grab and use the wrong materials Manufacturing and Related Processes 11
Moumen H Controls to ensure that Quality Plans are accurate APQP and PPAP 2
Sidney Vianna IATF bringing stakeholders together to ensure Transition by the 2018-09-14 deadline IATF 16949 - Automotive Quality Systems Standard 10
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Digitising Existing Documents to ensure regulatory compliance Document Control Systems, Procedures, Forms and Templates 6
D AS9100 7.4.1 vs 7.4.3 - Ensure purchased product conforms to specified requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Ball Bearing V-Blocks to ensure Lobing and Roundness are Minimal Manufacturing and Related Processes 1
H Methods to Ensure that we are Purchasing what we've Designed Benchmarking 16
T MSA - Repeating Gauge R&R to ensure effectiveness over time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T How to ensure Inventory FIFO (First In First Out) by Suppliers Supplier Quality Assurance and other Supplier Issues 1
B How does an organization ensure valuable employees are taken care of? Career and Occupation Discussions 10
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M AS 9100 Transition Checklist to ensure all areas of the new REV C are covered AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Do I need a QMS and what do I need to ensure my QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M What is the best way to ensure retraining when changes occur? ISO 9001 Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Q How to ensure quality on the supplier? Supplier Quality Assurance and other Supplier Issues 4
Sidney Vianna How do philanthropic foundations ensure their projects are properly managed? Coffee Break and Water Cooler Discussions 1
S How do you ensure compliance with 4.3.2 - Legal & other requirements? ISO 14001:2015 Specific Discussions 31
S How to Ensure Compliance with Noise Exposure Limits? Occupational Health & Safety Management Standards 11
B How to ensure Configuration Management and Control manually AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T How to ensure that counterfeit goods do not enter into our supply chain? Misc. Quality Assurance and Business Systems Related Topics 15
N Note interpretation - Ensure that the preservation of the product has been consider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Stijloor Toyota to extend development time to ensure quality World News 0
P 5 Ways to Ensure Mediocrity in Your Organization Lean in Manufacturing and Service Industries 2
E Protection 7.6 e - How do you ensure the application of this requirement? General Measurement Device and Calibration Topics 3
D How to Ensure Suppliers are meeting all RoHS Requirements RoHS, REACH, ELV, IMDS and Restricted Substances 8
G Inspection by Attributes to ensure a 99% Confidence in a Customer Contract Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I ISO 9001: How to ensure Long Term Internal Benefits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
T What Verification Method can I use to ensure Supplier Implemented Preventive Action Nonconformance and Corrective Action 14
Ajit Basrur How to Ensure DNA Free parts - Molded Parts for Labware ISO 13485:2016 - Medical Device Quality Management Systems 2
F Supplier Audit Form - Process reviews at suppliers to ensure quality Document Control Systems, Procedures, Forms and Templates 5
J Ensure customer confidentiality - TS 16949 Cl. 7.1.3 Confidentiality Various Other Specifications, Standards, and related Requirements 7
B What Process will ensure defect detection? Nonconformance and Corrective Action 12
K TS 16949 Training - How can I ensure competence? IATF 16949 - Automotive Quality Systems Standard 8
C What should a temporary, remote location have in place to ensure OSHA compliance? Occupational Health & Safety Management Standards 14
J MSA - Is ISO 10012 the standard we are looking for to ensure the FDA will be happy Other ISO and International Standards and European Regulations 3
B Method to Ensure Latest Customer Specifications (Documents of External Origin) Customer and Company Specific Requirements 2
D Understanding ?to ensure the changes are identified?? Revision Status of documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Recurrence of NC - What do you do to ensure that non-conformities do not recur? Nonconformance and Corrective Action 8
B Reviewing corrective action - How to ensure that root cause analysis is correct Problem Solving, Root Cause Fault and Failure Analysis 5
F How do I ensure QSR compliance in an FDA company within 12 months ISO 13485:2016 - Medical Device Quality Management Systems 33
D Electronic Documents and Forms - How can I ensure forms are entirely completed? Document Control Systems, Procedures, Forms and Templates 4
J 7.6 Process to ensure m and m is carried out IATF 16949 - Automotive Quality Systems Standard 3
M Frequency of Measurement Systems Analysis to Ensure Suitability General Measurement Device and Calibration Topics 9
H I see the word 'ensure' in standards - How do I comply? Misc. Quality Assurance and Business Systems Related Topics 1
