To establish ISO 9001:2008 in a ISO 17025 accredited Company
Timothy1
My organisation has plans to establish ISO 9001:2008 compliant system. We already have ISO 17025 compliant system. I am looking for details- what specific requirements of ISO 9001:2008 which are over and above 17025:2005's requirements? If you can share your thoughts I will appreciate that / if you have a matrix comparing both the standards, please let me know (We do testing & calibration)
Tim
harry
Re: To establish ISO 9001:2008 in a ISO 17025 certified Company
My organisation has plans to establish ISO 9001:2008 compliant system. We already have ISO 17025 compliant system. ..........................
Do you need to? Check this thread and the document provided in post #1: Accreditation to ISO 17025:2005 meets ISO 9001:2008 QMS requirements
It is provided in the appendix area of ISO 17025
Timothy1
Thanks Harry for your response. It is my mistake. I should have clarified better. Initially our organisation was doing only Calibration services for Pressure & temperature measuring instruments, which is under 17025. Recently we got into Repair & manufacture of the Pressure & temperature measuring instruments for which we are planning to have 9001 certification. wonder what will be the significant gaps in the system due to the requirements from 9001. Any inputs will be helpful
Tim
dv8shane
Tim
IMHO The first thing will be to define the repair, and manufacturing processes separately. Some examples; determine the points for testing, quality procedures for manufacturing and define standard repair processes, with set goals for time to bench time in repair and completion for repair etc etc. Calibration will be interactive with both, such as using calibration or calibrated tooling to prove the unit is repaired or ready for release after manufacturing.
F
Freddyfred
Good thinking. It maybe easier to start 9001 and then look at the gaps between them. If you are in So Cal I do have a friend that can help you if you need a consultant.
Z How to Establish a TS 16949 QMS in an ISO 9001 Registered Company? IATF 16949 - Automotive Quality Systems Standard 2
C The organisation shall Establish, Implement & Maintain a Procedure(s)? ISO 14001 ISO 14001:2015 Specific Discussions 21
C How to establish an effective ISO/TS16949 System? IATF 16949 - Automotive Quality Systems Standard 2
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
O How to establish Datum Planes with two cylinders? Various Other Specifications, Standards, and related Requirements 0
H How to Establish and Document Competence of Employees in a Small Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K Historical Data to establish Control Limits Manufacturing and Related Processes 4
R Does "establish, implement and maintain a procedure" require a Document - OHSAS 18001 Occupational Health & Safety Management Standards 1
S How to establish a Sampling Plan from the Rework percentage? AQL - Acceptable Quality Level 6
G Characterization Studies: Analyzing Data to Establish Conclusions Statistical Analysis Tools, Techniques and SPC 1
F FAA Letter of Need to establish Continuing Need Federal Aviation Administration (FAA) Standards and Requirements 1
B Airbus to establish assembly line in United States AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
G NADCAP - How do I establish if a process is covered? Manufacturing and Related Processes 3
D Establish a Documented Procedure (4.2.3) vs. Establish Process (7.6) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q How to Establish Microbiological Limits in Foods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R How to establish Quality Objectives per TS 16949 Clause 5.4.1 Requirements IATF 16949 - Automotive Quality Systems Standard 7
K How to establish critical limit for Critical Control Points (CCPs) Food Safety - ISO 22000, HACCP (21 CFR 120) 7
L Criteria to Establish a Relevant Due Date for Closing Corrective Actions Internal Auditing 8
Z How to Establish a Process in Terms of more Added Value? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Can we establish system documents with VIDEO or HUMAN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T How to Establish Internal Quality Control Planning APQP and PPAP 4
T How to establish KPI Disposal and Follow Up Process Quality Tools, Improvement and Analysis 7
G Quality Policy Requirements - Establish and implement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C How should I establish Quality Systems in my small company Manufacturing and Related Processes 7
C Do I have to establish a software validation procedure? Qualification and Validation (including 21 CFR Part 11) 11
C How to establish a Design History file (DHF)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
R Anyone know how to establish one piece flow in apparel industry? Lean in Manufacturing and Service Industries 9
M How to Establish criteria for acceptance of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Ajit Basrur FDA on path to establish offices in China US Food and Drug Administration (FDA) 0
H Is it possible to establish a new subforum for TL9000? TL 9000 Telecommunications Standard and QuEST 7
Z How to Establish Quality Manual Not Following the Structure of the Standard? Quality Management System (QMS) Manuals 3
Z How to Establish Quality Policy Based on Vision of Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q How can I Establish a New Medical Device Laboratory? ISO 13485:2016 - Medical Device Quality Management Systems 12
Z How to Establish Simple and Efficient Procedures and Operating Instructions Document Control Systems, Procedures, Forms and Templates 16
A Establish a New Quality System based on Lean - Starting A Late Career in Quality Lean in Manufacturing and Service Industries 7
R What statistical method to establish a specification? Statistical Analysis Tools, Techniques and SPC 16
T How to establish the 4M (Man Machine Method Material) change control Manufacturing and Related Processes 5
A How to establish linkage between specs/control plan/FMEA/process flow? Document Control Systems, Procedures, Forms and Templates 10
Douglas E. Purdy Acceptability of Perishable Tooling - How do you establish the standards/requirements Various Other Specifications, Standards, and related Requirements 2
apestate Job Shop Inspection and Test - Where should we establish inspections? Why? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
Raffy Do we need to establish Quality Objectives per department? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Geoff Cotton Taguchi quality loss function - How do I establish the 'Consumer Loss' element? Quality Tools, Improvement and Analysis 6
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
