To raise a NC beyond the audit scope? Two signatures were missing
qualprod
Hello to everybody
At auditing one process (sales) that is the scope, against 9001 and internal procedures.
In a document a signature was missing , clearly it is a NC, the procedures states one document have to be signed by the sales manager, after
a work order is sent to production.
But into the document, there is another requirement of signature of the Production manager (production process)
it is another nonconformity.
Can I write down the nc because the missing signature of the production manager as well? , even if the scope is to audit only sales process?
Please explain.
John Broomfield
Was this unsigned procedure in use or under review?
If in use what controls do production have to prevent use of a potentially invalid document?
qualprod
Thanks Randy and John
Yes is in use, in order for the next processcan continue, the responsible first checks if signatures appear , he ignored that, continued
with missing signatures, apparently, it was an urgency to deliver a product of the main customer.
As Randy said, if there's a requirement and it wasn't met, you have a nonconformity, regardless of the scope of the audit. Perhaps your company has painted itself into a corner by not specifying acceptable exceptions to the rule.
qualprod
So, at what extent or what cases the scope applies in an audit. ( I think the scope sets the limits)
What are the frontiers? or what criteria to follow to decide if a nc has to be writen down outside of the
audited process?
audited process?
Let's say that one fine day you're sitting at home and realize that you don't have your wallet. You surmise that you might have left it in a restaurant where you ate lunch earlier and decide to go there and see if anyone found it. While on the way there--a short walk--you see some papers lying on the ground that you recognize as yours. Although the papers are important to you, you decide not to pick them up because they're not within the scope of the present mission.
The audit scope basically defines the process(es) to be audited. As Randy suggested earlier, it's not unusual at all to find things that relate to other processes while you're auditing the scoped process. Are you suggesting that the potential (or actual) NC discovered while auditing Sales should just be ignored?
Jean_B
Look at scope as if focusing effort. You didn't go sampling to look for Good Documentation Practice errors, but this is right there, in your scope of the sales process. You didn't waste effort to find this while still conducting your audit to meet its objective.
It's the criteria set and auditor competence which should form the base of deciding whether something is to be a finding of non-conformity.
Example:
You are auditing from the quality perspective but find a non- conformity against a labour requirement you've heard of (perhaps you're subject to the same requirement, perhaps it's clear within a set of documents as the two kinds are compiled).
If you're not certain what to write against, you can't do much of anything expect look it up later. You need evidence.
If you're certain, but the audit programme/ scheme you're auditing under doesn't include it you don't have the specific or general criteria, so you can't make it an audit finding. But you can (have it) process through the applicable system's non-conformity process. Not a finding, still duly noted as it should be.
If you're certain the company should meet it, but hasn't made provisions for it in any system, make a note of the risk (not an NC, more similar to ye olde observations/recommendation), likely using reference to which kind of audit/inspection would take offence to it (and at what level).
If I'm doing an ISO audit and I find something that the FDA takes offense against but isn't strictly forbidden by the standard, I would include a caution within the report.
Luckily our system is designed to allow NC's against all regulations and standards we claim compliance to (long live the quality manual and declaration of conformity) in any of our audits. Regardless of the specific criteria we're looking at. That only leaves auditor competence.
Kirby
Example:
Just a thought regarding your example - doesn't AS prescribe that the organization should comply with and statutory and regulatory requirements (4.2, 4.4.1, 5.1.2, etc.)?
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
Q Practical Way to raise NCR's in an Assembly Workshop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Any comment, if a supplier raise an NCR to the Client? Oil and Gas Industry Standards and Regulations 5
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Performance Evaluation - Time for a Raise? Career and Occupation Discussions 4
4 ISO 14001 videos to raise awareness ISO 14001:2015 Specific Discussions 1
A Shall we raise SCAR/CAR for every defect as per our current procedure? Nonconformance and Corrective Action 4
N I Want A Raise! (joke) Funny Stuff - Jokes and Humour 2
Q Waiting for Audits to raise Nonconformity Reports? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q How raise en ECO starting from a NC - ECO after NCR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Encouraging Teams to raise Issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
O Who can raise a Corrective Action? Nonconformance and Corrective Action 7
Stijloor Goldman Posts Profit and Will Raise $5 Billion World News 2
M Thermocouples prices raise General Measurement Device and Calibration Topics 4
C Internal Audit Findings - Do I need to raise NC for amendments/revisions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S How one can raise increment request to TOP management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Asking for a Raise and Justifying a Raise Career and Occupation Discussions 30
R NCR & CAR - How to use & where to raise Nonconformance and Corrective Action 23
Marc US Airlines raise base fares - April 2006 Travel - Hotels, Motels, Planes and Trains 1
M Record Falsification - What clause to raise a non-conformity? Records and Data - Quality, Legal and Other Evidence 20
A Employee Involvement - Employees shall have the authority to raise nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T Class A PRTD beyond 300°C General Measurement Device and Calibration Topics 0
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
M Calibration certificates avowing accuracy beyond the uncertainty limits? Measurement Uncertainty (MU) 7
Hershal Star Trek Beyond (ST 13) - 2016 Coffee Break and Water Cooler Discussions 4
N "Beyond Economic Repair" - Scrapping Customer Material - DCMA Quality Manager and Management Related Issues 7
somashekar Authorization to use shelf life sensitive materials beyond its valid shelf life... Manufacturing and Related Processes 7
2 DOE to minimize Noise Contributions that enlarge the Variation beyond Part-Part Quality Tools, Improvement and Analysis 5
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Calibration and Customer 'Requirements' - Something Stupid Beyond Belief General Measurement Device and Calibration Topics 40
U Beyond words and wonderment Coffee Break and Water Cooler Discussions 1
J Taking Lean beyond 5S - Commercial Printer Lean in Manufacturing and Service Industries 10
Jen Kirley Beyond Compliance: Value-added auditing for system performance The Reading Room 9
R Beyond Lean manufacturing - Operation management / Performance improvement Lean in Manufacturing and Service Industries 1
BradM 29th Olympics in China - Beyond the opening Coffee Break and Water Cooler Discussions 82
R Getting started (beyond the standard) and getting up to speed with AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K Risk Management Portal - Beyond ISO 14971 - Incorporate $$ into the Risk Assessment ISO 14971 - Medical Device Risk Management 4
Douglas E. Purdy Beyond PDCA by Praveen Gupta Philosophy, Gurus, Innovation and Evolution 126
A Do you register NC's beyond Internal Audits? Internal Auditing 13
Casana Beyond CQE: Any suggestions to improve my knowledge further? Statistical Analysis Tools, Techniques and SPC 25
J ISO 9001 - Product ID & Traceability - Beyond our door? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N API Q1 Audit Surveillance - Questions Oil and Gas Industry Standards and Regulations 2
A Alternative to on site audit in China EU Medical Device Regulations 2
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
B Internal audit checklist Internal Auditing 5
V Internal Audit Software IATF 16949 - Automotive Quality Systems Standard 5
J Internal Audit Schedule IATF Internal Auditing 3
Mikey324 External calibration - Finding in our 3rd party audit General Measurement Device and Calibration Topics 58
C ISO 14001 Internal Audit - Opportunity for Improvement ISO 14001:2015 Specific Discussions 2
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
