To set frequency to review documents in ISO 9001 7.5?
qualprod
Hello everybody.
Now in the standard in 7.5 Documented information.
I don´t see an exact clauseb to raise a NC, this is the case.
In my QMS there is a procedure to manage changes 6.3, into it there are mentioned
some positions which existed in the past, now they are different.
At auditing the QMS we found that this document is obsolete regarding the positions mentioned there.
This document was created in 2015 in the 2015 version.
Could this nc raised against 7.5.2 c) review and approval for suitability and adequacy.?
or how can this issue be managed?
Into the QMS, I think we have to establish at certain frequency to review all the documents
to ensure them for adequacy.
I remember in the 2008 version, existed in the users some ideas focusing to review all the documents.
Any idea?
Big Jim
ISO 9001:2015 doesn't require a specified interval or even that the organization needs to have a specified interval. Anything in 9004 is guidance and are not requirements.
As for the obsolete documents the term obsolete as far as documented information is not mentioned in the 2015 version of ISO 9001:2015. A nonconfromance case could probably be easily made for 7.5.3.1a for "suitable for use".
qualprod
Marc is 9001 : 2015
Jim, but really do you think this case will deserve to raise the Nc?
The point is, because this document was not used for long time, it was "forgotten" and nobody
noticed the errors.
Other point, the "suitable for use" term, which means to have the documents reviewed, in your opinion, will be recommended to
have established somewhere into the QMS as a task to ensure all documents are reviewed?
Big Jim
Suitable for use would seem to mean just that. Something obviously "forgotten" but found in use would certainly not suitable for use. It doesn't matter how or why or what the good intentions may be.
Without knowing more fully the circumstances I would not say that it is a slam dunk nonconformance, just that a case may be able to be made for it.
John Broomfield
A lot of folk don’t realize that by changing the organization they are also changing the system.
Most managers would also agree that “failure to keep the documented parts of the management system up to date with changes in the organization” is a nonconformity worthy of correction and corrective action.
Regular reviews of the continued accuracy of system documentation may limit the decay. Better still may be to connect the process for organizational changes to the upkeep of system documents.
Failure to plan upkeep of the system may be a better clause (10.1a for example) if this is a system wide (chronic) problem instead of an isolated document control issue.
Tagin
Using an interval essentially means you are scheduling to fix all the broken things on a periodic basis. :)
Make it part of the HR onboarding/offboarding/role-changes process to review relevant QMS docs for any needed updates, so they occur when the change happens, and not later.
qualprod
I have seen two practices somewhere in companies.
1- When auditing every process, the process owner is asked to show their documents, thus, adequacy is reviewed.
2- Monthly the QMS responsible, take documents of every process, print them, goes with every process owner and
ask he/she the review for adequacy. In case the need to update or cancel a document, this is the moment.
Regards
John Broomfield
qualprod,
1 uses the auditor to help control the process for the upkeep of the system documents. This limits the freedom of the auditor to verify the effectiveness of the process (and the manager's monitoring of this process) for keeping the system documents up to date.
2 On this I agree with Tagin.
qualprod
Thanks Tagin
Could you explain how the HR onboarding/offboarding can be more effective than in other processes regarding
the adequacy of documents?
Tagin
Thanks Tagin
This suggestion was specifically referring to the OP's issue of personnel/role changes not being reflected in the QMS documentation. By making those personnel change processes incorporate a document review it would (hopefully) prevent personnel/role changes from causing QMS documentation issues. (I'd also add, as I think about it, personnel/role changes should probably also be reviewed for effects on organizational knowledge.)
A more general approach would be identify all such areas where change occurs that could affect QMS documentation and build similar reviews into those processes. (Essentially, there's a Check-Act piece missing from these kinds of changes.)
An even broader, more uniform approach would be to pipeline all changes (including personnel changes) through a company-wide change management system. That might be impractical, and perhaps cumbersome. An alternative might be some system to gather changes as they occur and forward them to Quality so they can review potentially affected documentation.
A scheduled interval review is a Check-Act. But it has two deficiencies that are apparent:
1) it presumes that incorrect documentation is acceptable for X period of time, and presents minimal risk,
2) detection of incorrect documentation is not now based on known actual changes in the processes; instead it relies on the detective skills of the reviewer and how obvious or not the mismatch is between the documentation and the actual current processes.
A scheduled interval review would however provide some potential protection against unintended changes; e.g., where processes 'drift' over time and soon the incorrect way becomes the 'the way we've been doing it'.
J Appropriate In-Process Monitoring Frequency for 2X per day Change Set-Up. Statistical Analysis Tools, Techniques and SPC 3
R Gage R&R Frequency - Are your GR&R's on a set schedule? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
G CE marking of MD and IVD set EU Medical Device Regulations 3
J How to Set Microbial Limits in Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 3
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
B Set RH spec from dewpoint spec General Measurement Device and Calibration Topics 2
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
N When to record values if a spec for a mfg process is set Manufacturing and Related Processes 3
Marc Time Zone - Set your Time Zone Elsmar Xenforo Forum Software Instructions and Help 1
D As a newcomer to QMS, I really appreciate how ISO is set up. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C IATF 16949 Cl 8.5.1.3 - Verification of job set up IATF 16949 - Automotive Quality Systems Standard 4
D How to set equipment calibration/verification criteria General Measurement Device and Calibration Topics 1
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
G What to Check - Set Up vs. In Process Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N The known set of all root causes Nonconformance and Corrective Action 11
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
G Training Employees about Quality - Philosophy / Mind set Misc. Quality Assurance and Business Systems Related Topics 1
renenatasha MDD Classification for Pressure Monitoring Set CE Marking (Conformité Européene) / CB Scheme 1
U Are all manufacturers required to set up eMDR system? Other US Medical Device Regulations 4
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
E How to use the Standard Error and how to set the error limits? Reliability Analysis - Predictions, Testing and Standards 2
C Implementing a set of bore gages at a machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S How to set up the Accupoint 2 ATP sanitation monitoring system Quality Assurance and Compliance Software Tools and Solutions 1
L How do I set a limits to cfu in an ISO class 7 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 2
4 Quality vs Production on CMM Set Up Requirements Manufacturing and Related Processes 1
A What is the definition of Installation that requires Record Keeping vs Set-up 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G AS9120 - What should we be expecting once we set forth into becoming certified? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A IEC 60601-2-24 Question: Free Flow Clamp on Set? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Lowest Acceptable Grade for Master Gage Set Calibration and Metrology Software and Hardware 1
L How to set up a basic electronic test equipment calibration laboratory General Measurement Device and Calibration Topics 3
Q Inquire TS 16949 standard - Clause 7.5.1.3 Verification of 'Job Set-Up' IATF 16949 - Automotive Quality Systems Standard 8
M AS9100C Document Control for Machine Set Up Work Instructions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Insufflation Tubing & Filter Set Product Classification question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M New Calibration Laboratory Set Up Measurement Parameters and Equipment General Measurement Device and Calibration Topics 4
B How to set Cleanroom Alert and Action Limits as part of Microbiological Evaluation Quality Assurance and Compliance Software Tools and Solutions 8
F How to set-up a Dual Company QMS (Quality Management System) Quality Manager and Management Related Issues 2
R Can the same Biocompatibility Report for Infusion Set be used for its Components? ISO 13485:2016 - Medical Device Quality Management Systems 7
insect warfare How is the Management Review structure of your company set up? Management Review Meetings and related Processes 5
AnaMariaVR2 Legal Flash: 8 Regulations set to impact the Pharma & Biotech Industry in 2013 US Food and Drug Administration (FDA) 0
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
