Tolerance block on customer drawing - Major interpretation problem with customer
QMMike
Here is the scenerio. The tolerance block on my customer's drawing is +/- .010.
The dimension in question is .460min
What is your interpretation?
GStough
Re: Major interpretation problem w/ customer
How can there be a tolerance of +/- .010 when they only require a minimum? :confused:
Does the block tolerance have the disclaimer, "Unless otherwise noted"? If it does, there's your answer--the "min" callout supersedes the block tolerance. If not, I would still say that specifying "min" without an associated "max" leaves the door open on the high side. What is your measurement, and what does the customer say?
Once again, for those just tuning in, this is yet another example of why careful review of drawings at the quotation stage (contract review) is important.
RoxaneB
What does the Customer say? I mean, we can tell you our interpretation, but in the end, isn't it about meeting the Customer's requirements? I'd love to say fix the drawing, but what does the Customer need?
SteelMaiden
I'm with Gidget. You cannot have a +/- tolerance with a minimum required dimension. I would contact the customer for clarification before accepting the order.
QMMike
Any idea where to find a hard copy of this interpretation? My problem lies in drawing states .460 min. marked as a critical. This customer is typically "quirky" (for lack of a better term) with their drawings. Parts were made and readings reached .490-.525. All other critical dimensions were fine. Our customer received the parts, packed them into kits and then THEIR customer rejected them.....
You didn't say whether there was an "Unless otherwise specified" disclaimer. Nonetheless, you can't logically apply a bilateral tolerance to a unilateral specification. ".460 min" allows for unlimited variation above .460. Even if this were codified somewhere--and I don't know that it is--it wouldn't make any difference unless the customer had explicitly named the controlling standard (ASME Y14.5M, for example).
This is a matter of negotiation with the customer, and in order to avoid complications you might well end up having to eat the "nonconforming" parts. This doesn't mean that the customer shouldn't be put on notice that you are making a concession in order to maintain their happiness, and that the drawing (and any others like it) need to be changed.
Helmut Jilling
Auditor / Consultant
My interpretation as an auditor is it is a conflicting dimensional statement. It is not clear. Therefore, it should have been noted during the Contract review/APQP Print review process, and resolved then. You might have had some traction to get agreement from the customer at the time.
Since you did not, there has been a glitch (almost predictable), and now you may have an issue with a customer. Now, at this juncture, you have very little traction.
Now, you still have to resolve the conflict before you move on, but you missed the opportunity to be proactive, and may have some parts to eat, as well.
This is a good real world example of why this requirement is in the standard.
D.Scott
What has been said is certainly true. We should also acknowledge that clarity is a requirement of purchasing as well. It was stated a couple of times here that there needs to be an up-front agreement and nobody can argue with that. Those of us on the purchasing side should take a lesson from this as well. We need to be clear about what we expect from a supplier.
That aside, why was the stated tolerance disregarded? Was there no thought to requirements of 0.470 +/- 0.010? The identification of a critical minimum requirement is, or certainly could be interpreted as, consistent with those requirements. I will be interested in what the customer actually thought they would get.
Dave
Wes Bucey
Yep. The horse [Contract Review was missing] is dead - we can stop beating it.
FYI:
Typically, my experience with job shops and contract manufacturers is that they do not take an ambiguous note or dimension as carte blanche approval to FAR EXCEED the standard tolerances for the drawing. Thus said, I would have expected most shops to have interpreted the dimension (assuming no other customer interaction during Contract Review) as 0.460 +0.020/-0.000. This means the maximum part sent to the customer would have been 0.480.
K AS9102 - Tolerance Block on Enginerering Drawings to Form 3 of AS 9102 FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A No Block Tolerance in Print Title Block - Where do I get the tolerance from? Manufacturing and Related Processes 16
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
A Calibration tolerance for data logger General Measurement Device and Calibration Topics 3
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
kedarg6500 Excel spreadsheet for Unilateral Tolerance Study wanted Excel .xls Spreadsheet Templates and Tools 2
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
