Tolerance for Cpk purposes on certain diameters
Golfman25
#11
Re: Tolerance for Cpk purposes
If you are doing drawn stamping, do you start with (for example) ID tooling large to allow the stamping die to wear to the small side, or is your material influence variation so large that it masks tool wear?
Bob, Thanks for your help and insight.
Our runs are 10k - 50k parts, so we don't run into a lot of tool wear issues. We will run into galling which requires a polish of the punch from time to time. We set the die using different punches (or slightly modifing the punch we have) in an attempt to account for the material variability. We look for that fine line where the punch and material react to get us as close to the nominal dimension as possible, and then we run. Even so, a tiny fluctuation in the material will cause a potential problem. For example, the material thickness changes .0005, well that is .001 on the part and you're using half your tolerance on that alone.
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
P Profile Tolerance and CPK Manufacturing and Related Processes 3
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
F How to Calculate Cpk with only a Minimum Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 11
G Cpk vs. "Bad" Parts - Unreasonable Diameter Tolerance and a 1.67 Cpk Statistical Analysis Tools, Techniques and SPC 22
E Asymmetric Tolerance - How does an Asymmetric Tolerance affect the Cpk/Cp calculation Using Minitab Software 3
G Cpk Calculation - Tolerance to maintain 1.33 & 1.67 Cpk respectively Capability, Accuracy and Stability - Processes, Machines, etc. 17
S Percent of Tolerance - Cpk - Low lot sizes (40-60 pcs.) Statistical Analysis Tools, Techniques and SPC 4
L Calculating Cpk on a single sided (unilateral) tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 28
S Determining Cpk on a single sided tolerance dimension Capability, Accuracy and Stability - Processes, Machines, etc. 3
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
