Tolerance intervals (?) question - Flow Rate Probability Range
Ronen E
Problem Solver
Moderator
Calling all expert statisticians --
After practising engineering / R&D for quite some years and researching this topic quite a lot (though not as much as I would have liked to - the knowledge, opinions, arguments and theories seem almost endless, and I'm not a statistician), I feel my understanding is still not good enough. What seems to be even worse is that my everyday engineering questions are usually phrased in terms a little different from those mathematicians and statisticians seem to favour, so I'm never 100% sure I use the right concepts / tools and apply them correctly. There is a particular type of situation that seems to recur with some variation, so if any of you could help me establish more clarity on it I'd be grateful. I've researched it quite a lot over the years but I can't achieve certainty (pun intended).
Suppose that a medical device, going through Design Verification, is regulating flow rate. It has a specified nominal rate, and an a-symmetrical tolerance. I only have a very limited number of units available for testing (say, up to N=10), but multiple runs on each unit are possible (though the total number of runs should also be kept low - say, max. 30). I don't know anything about the population's distribution, STD or else, and I wish not to make any assumptions in that regard. I also want to complete the testing in a single run, i.e. I can't rely on an iterative process. I want to be able to run the testing (e.g. obtain 10 data points) and complete the following if possible:
I don't mind it if the limits are very far apart (even 0 for LL) and I understand that in order to make the estimate more accurate I might need much larger sample sizes. That's not the issue.
In simple words, I want to be able to answer the question(s) "What is the flow rate range (LL to UL) that at a 99.9% probability (practically certainty) any unit sampled from the population will fall within (excluding outliers)?" [and the same for lower probabilities]. If I need to declare some Alpha or Beta (or make other policy/risk decisions) that's fine, but then I'd like to be able to express their meaning in similar/laymen terms, i.e. "Alpha is the probability that once in a while a unit will exhibit a flow rate outside the stated limits, while Beta is the probability that..." (I realise this might be wrong, it's just an example).
If you could describe or refer to a technique allowing the above, and maybe quote a paper or a book chapter that develops / elaborates on it, that would be great. I'd really like to be able to support any such practise with rather mathematically/statistically-rigorous arguments (as opposed to rules-of-thumb / best accepted practises / empirically demonstrated results etc.), even if I won't be able to follow every little step along their development without obtaining a statistics PhD first...
If you feel that answering this question properly is something that requires a significant amount of time / research, and that payment would be required for keeping it fair - I'd like to know that too.
TIA,
Ronen.
Ronen E
Problem Solver
Moderator
I forgot to mention one important point - the analysis method I'm looking for should be simple, not rely on a statistical analysis software package (Excel is fine though), and not require fitting with one of the standard distributions (e.g. Normal). I'd like people with no formal engineering / science background to be able to undertake it if possible.
GRP
Until you get a reply from an expert statistician I will direct your attention to an article from Dr Wheeler, manuscript 189 "An Honest Gauge R&R study" page 16. You can probably download the article for free from the net.
I am out of my depth with this stuff for now, but I think the probable error is a way to address your question. While this is related to measurement systems, probably you can adapt it somehow to defining specifications for each desired probability.
I hope I have pointed you more or less in the right direction.
Ronen E
Problem Solver
Moderator
@GRP Thanks for taking a stab at it.
I read the entire article (Thanks Al), and although it is quite appealing to me in its own right, I'm quite at a loss as to how I could use its concepts and tools in my specific quest.
Perhaps the term "Tolerance interval" and the table I presented are a little confusing, so please let me emphasise that in this context "Tolerance interval" is the statistical term that relates to estimation (of a population) and should not be confused with manufacturing/engineering tolerances (i.e. cut-off limits for product acceptance).
In the process I described I assume that the measurement system is already validated for the application and found to have satisfactory GR&R. Now a set of datapoints is collected off a sample and I'm looking for a statistical inference that can be made and backed.
Thanks!
chris1price
I think there is a statistical principle here - if in doubt read everything by Donald Wheeler !
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
J Non-Normal Distribution Data - Tolerance Intervals and Minitab Using Minitab Software 7
J Tolerance Intervals - Descriptive or Inferential? Statistical Analysis Tools, Techniques and SPC 2
D Tolerance intervals - Asked to provide a tolerance for a manufacturing process Capability, Accuracy and Stability - Processes, Machines, etc. 1
L How to calculate tolerance intervals for non-normal data? Reliability Analysis - Predictions, Testing and Standards 13
Statistical Steven Non-Symmetrical Tolerance Intervals for setting uncentered process specifications Statistical Analysis Tools, Techniques and SPC 4
M Geometric Tolerance Power Point Presentation. Manufacturing and Related Processes 3
H Position Tolerance with MMC and MMB Manufacturing and Related Processes 0
A Nested ANOVA MSA - Excel sheet with bilateral tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
dhuot1990 Out of Tolerance for Weights Manufacturing and Related Processes 3
F Tolerance Acceptance Criteria General Measurement Device and Calibration Topics 3
M Definition of Characteristics Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Quantity Discrepancy Tolerance Standard(s)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Simulate Tolerance Range with Real Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Tolerance and MPEs for Re-calibration Manufacturing and Related Processes 0
S GD&T Bonus Tolerance OOS Capability, Accuracy and Stability - Processes, Machines, etc. 2
WEAVER Can you determine exact date an instrument went out of tolerance? General Measurement Device and Calibration Topics 10
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
I Profile tolerance with a positional tolerance to a hole ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A % STUDY VARIATION VS. % TOLERANCE Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 31
A +0/-.001 Tolerance question - Feature size is 1.249 +0/-.001 - Actually measures 1.2493 (.0003 OHL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
L Validation without Tolerance Qualification and Validation (including 21 CFR Part 11) 0
Q Acceptable Tolerance - how to derive? Measurement Uncertainty (MU) 16
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
