Tolerance of Position - Pattern of Holes at MMC - Datum Feature Reference
optomist1
A Sea of Statistics
Hi To All,
When using a a tolerance of position control on a pattern of holes at MMC and using this as a Datum Feature Reference, must a diameter symbol be used in the tolerance portion of the feature control frame?
Seems rather obvious, I need to be sure....
Regards,
Marty
True Position
Re: Tolerance of Position - pattern of holes
Hi To All,
Regards,
Marty
If you wish the tolerance of the pattern to be a circular zone are around the basic dimensions, yes.
David DeLong
Hi To All,
Regards,
Marty
Marty:
If the pattern of holes are round, then the diametrical tolerance zone symbol is most appropriate. When I see a drawing with a pattern of round holes without the diametrical tolerance zone symbol in the feature control frame, I just feel that the Designer made an error.
If the holes are not round, let's say slotted, then the diametrical tolerance zone is not appropriate and should not be use.
optomist1
A Sea of Statistics
Thank you David and TruePosition,
Studying for the Technologist exam...so I need to be clear. If given the previously described scenario; if a Diameter symbol is NOT USED, is the call-out technically incorrect?
Or is there a grey area?
Thanks again
Marty
David DeLong
No, it is not wrong if we are still talking about a round hole. It means that the tolerance zone is square (X & Y axis) rather than round.
Good luck on the exam. It is really quite tough.
